Home » Eclipse Projects » Eclipse Scout » Custom login on scout(Custom login on scout)
Custom login on scout [message #1752488] Tue, 24 January 2017 07:27 Go to next message
Good morning. I am creating an application that has as basic requirement that in the screen of login it is possible to recover the password of the user. The idea would be to create a button on the login screen I forgot my password and in recovery a temporary password will be sent by email to the user. How can I do this in scout? Create a button or a link on the login screen.
Re: Custom login on scout [message #1752568 is a reply to message #1752488] Wed, 25 January 2017 03:31 Go to previous messageGo to next message
Hi Juliano
You need to override and replace the Scout LoginBox with an own extended implementation. This is possible, using the current Scout version, but not very straightforward. We improved the extensibility of the LoginBox with the next Scout Oxygen release.
Steps:
Create a new LoginBox implementation extending the Scout LoginBox:
\helloworld.ui.html\src\main\js\helloworld\LoginBox.js
helloworld.LoginBox = function(opts) {
  helloworld.LoginBox.parent.call(this, opts);
scout.inherits(helloworld.LoginBox, scout.LoginBox);
helloworld.LoginBox.prototype.init = function(opts) {
	helloworld.LoginBox.parent.prototype.init.call(this, opts);
helloworld.LoginBox.prototype.render = function($parent) {
  helloworld.LoginBox.parent.prototype.render.call(this, $parent);
  this.$resetButton = $('<button>')
  .addClass('button')
  .text('Reset password')
  .click(this._onResetPasswordButton.bind(this))
  .appendTo(this.$content);
helloworld.LoginBox.prototype._onResetPasswordButton = function(event) {
	alert('do something');
Use the _onResetPasswordButton method to perform a call to the server to send out the new password. Check out scout.LoginBox_onLoginFormSubmit() method for an example.
Then add your own login.js to create the new LoginBox instance:
helloworld.ui.html\src\main\js\helloworld\login.js
scout.login = {
  init: function(opts) {
    scout.prepareDOM();
    var loginBox = new helloworld.LoginBox(opts);
    loginBox.render($('body'));
Then to have your own JavaScript code loaded, create a new login-macro file:
helloworld.ui.html\src\main\resources\WebContent\res\application-all-login-macro.js
__include("scout-login-module.js");
__include("hello-world-login-module.js")
And finally, add your macro file to your login.html file:
\helloworld.ui.html\src\main\resources\WebContent\login.html
    <scout:script src="res/jquery-all-macro.js" />
    <scout:script src="res/application-all-login-macro.js" />
Paolo
[Updated on: Wed, 25 January 2017 06:41] by Moderator
Re: Custom login on scout [message #1752640 is a reply to message #1752568] Wed, 25 January 2017 12:23 Go to previous messageGo to next message
Good afternoon .
Thanks for the answer.
It worked out.
[Updated on: Wed, 25 January 2017 14:53] by Moderator
Re: Custom login on scout [message #1752685 is a reply to message #1752640] Thu, 26 January 2017 03:09 Go to previous messageGo to next message
juliano ferreira borges wrote on Wed, 25 January 2017 17:23
Good afternoon .
It worked out.
Good to hear! Therefore you're working with Eclipse Neon release Wink
Paolo
Re: Custom login on scout [message #1779349 is a reply to message #1752685] Fri, 05 January 2018 11:41 Go to previous messageGo to next message
I am working with the Oxygen release and I have the same question. You said it was easier with Oxygen, can you show us how would it be ?
Thank you very much.
[Updated on: Fri, 05 January 2018 11:42] by Moderator
Re: Custom login on scout [message #1779536 is a reply to message #1752488] Tue, 09 January 2018 06:45 Go to previous messageGo to next message
With Oxygen, I have found this piece of very useful code in the Spring boot/eclipse scout archetypes in SpringSecurityLoginBox.js :
tasks.SpringSecurityLoginBox.prototype.render = function($parent) {
	tasks.SpringSecurityLoginBox.parent.prototype.render.call(this, $parent);
	this.$user.attr('name', 'username');
	this.$password.attr('name', 'password');
	// Here is my custom registration link
	this.$register = $('<a>')
	  .attr('href', 'user/registration')
	  .text( 'Sign up' )
	  .appendTo(this.$form);
	this.$user.focus();
[Updated on: Tue, 09 January 2018 06:46] by Moderator
Re: Custom login on scout [message #1779538 is a reply to message #1779536] Tue, 09 January 2018 07:12 Go to previous message
Hi Stéphane
Basically with the Oxygen Release the part which instanciates the custom Login Box was optimized.
Before Oxygen you had to write this code, as mentioned in my previous posting:
scout.login = {
    scout.prepareDOM();
This code is no longer requred, because the Login Box instance is now created using the Scout object factory:
var loginBox = scout.create('LoginBox', options);
In order to override the originally registered LoginBox instance, you need to provide a custom object factory for your objects:
helloworld.ui.html\src\main\js\helloworld\objectFactories.js
scout.objectFactories = $.extend(scout.objectFactories, {
  'LoginBox' : function() {
    return new helloworld.LoginBox();
And do not forget to include all your custom java script files in your module file:
(function(helloworld, scout, $, undefined) {
  __include("helloworld/LoginBox.js");
  __include("helloworld/objectFactories.js");
}(window.helloworld = window.helloworld || {}, scout, jQuery));
The other snippets remain the same.
The SpringSecurityLoginBox is a complete example of those snippets:
https://github.com/BSI-Business-Systems-Integration-AG/SpringBoot-and-EclipseScout/tree/bb97efde3490f37057b2a019f4b030bca3697db7/org.eclipse.scout.springboot/src/main/js
Paolo
Previous Topic:Memory leak in table fields
Next Topic:Component IDs
Current Time: Wed Sep 17 10:49:23 EDT 2025
Powered by FUDForum. Page generated in 1.03960 seconds
