Home » Modeling » ATL » Metamodel constraints in ATL HOT
Metamodel constraints in ATL HOT [message #1752101] Wed, 18 January 2017 13:57 Go to next message
Hi all,
I'm writing a higher order transformation that takes a UML metamodel as input and provides an ATL transformation as output. The output transformation should verify either a model conforms to the metamodel (input of the HOT) so I need to access the metamodel constraints in OCL.
Please, does someone know how to access the metamodel constraints in a ATL? For example, for the class diagram metamodel, if a constraint asserts that two classes cannot have the same name, an ATL helper in this form should be created in the output transformation :
helper context CD!Class def: existSameName() : Boolean =
-- verification of the constraint
I hope my problem is clear. Thank you very much!
Meriem
[Updated on: Sun, 22 January 2017 07:58] by Moderator
Re: Metamodel constraints in ATL HOT [message #1752330 is a reply to message #1752101] Sat, 21 January 2017 12:33 Go to previous messageGo to next message
Anyone can help please !
Re: Metamodel constraints in ATL HOT [message #1752435 is a reply to message #1752330] Mon, 23 January 2017 12:56 Go to previous messageGo to next message
You should look in your metamodel where OCL constraints are stored? You don't have a package OCL in UML metamodel like ATL has?
Re: Metamodel constraints in ATL HOT [message #1752517 is a reply to message #1752435] Tue, 24 January 2017 11:17 Go to previous messageGo to next message
No, there isn't a package OCL in the UML metamodel. There is just text expressions embedded within classes. I want my OCL expressions to conform to the OCL metamodel in order to analyze them and apply some changes. The problem is that I don't know how to extract or reference a constraint for a given element in ATL.
Re: Metamodel constraints in ATL HOT [message #1753100 is a reply to message #1752517] Wed, 01 February 2017 15:15 Go to previous messageGo to next message
In that case, you will have to invoke the Eclipse OCL parser manually (OCLHelper?) on each OCL text snippet embedded in the UML model. EMFTVM allows you to invoke Java methods from your transformation.
Re: Metamodel constraints in ATL HOT [message #1753229 is a reply to message #1753100] Thu, 02 February 2017 14:15 Go to previous message
Hi Dennis,
Thank you for your response. Is it the case if I use a Ecore metamodel with OCL constraints using OCLinEcore editor? Should I parse the OCL constraints? I'm confused about the solution to take.
Previous Topic:Meta model transformation from one XSD source
Next Topic:Empty XMI when running a transformation from an eclipse plugin
Current Time: Sun Jul 27 03:49:29 EDT 2025
Powered by FUDForum. Page generated in 0.36787 seconds
