Home » Eclipse Projects » Eclipse Scout » [neon] double menus mobile
[neon] double menus mobile [message #1752188] Thu, 19 January 2017 09:50 Go to next message
I have a TablePage "BTablePage" with a "normal" edit menu (only for TableMenuType.SingleSelection). And as a child page there is a BDetailNodePage. As I use the BDetailNodePage in other places too, there is also an edit menu with TreeMenuType.SingleSelection as MenuType.
To prevent to get the edit menu twice when opening the BDetailNodePage below the BTablePage I have overridden computeParentTablePageMenus:
  public List<IMenu> computeParentTablePageMenus(IPageWithTable<?> parentTablePage) {
    return CollectionUtility.emptyArrayList();
This works fine on the desktop version. When opening the application on mobile and selecting a row entry the edit menu is still displayed twice. I guess this is because the displayed contents are partly from the TablePage (column values) and NodePage (children).
Where is my mistake? Or what can I do to just get a single menu in mobile as well?
[Updated on: Thu, 19 January 2017 09:51] by Moderator
Re: [neon] double menus mobile [message #1752190 is a reply to message #1752188] Thu, 19 January 2017 10:30 Go to previous messageGo to next message
I would do the following solution that is even more ergonomic.
for simplicity lets assume a PersonTablePage and a PersonPage (node-page).
1. The PersonTablePage decorates the data using the HTML decorator and AppLinkActions. It does not contain a ModifyMenu.
  protected void execLoadData(SearchFilter filter) {
//...for each loaded data row
    String personHtml = HTML.appLink("person:" + person.getPersonKey(),   person.getPersonName()).toHtml();
    //use the personHtml  app-linnk instead of person.getPersonName()
2. handle the app-link action inside the PersonTablePage.Table class
    protected void execAppLinkAction(String ref) {
      MessageBoxes.createOk().withBody(ref + " has been clicked.").show();
3. enable html styling in the PersonNameColumn
    public class PersonNameColumn extends AbstractStringColumn {
      protected boolean getConfiguredHtmlEnabled() {
        return true;
4. in the child page PersonPage keep the ModifyMenu.
That way you will have a link in the PersonTablePage for edit and a menu in the PersonPage detail page.
I added some screen shots of my personal mini-crm.
  • Attachment: table.JPG
    (Size: 93.30KB, Downloaded 108 times)
  • Attachment: node.JPG
    (Size: 53.06KB, Downloaded 134 times)
Re: [neon] double menus mobile [message #1752520 is a reply to message #1752188] Tue, 24 January 2017 11:38 Go to previous message
Thanks for the idea (and the help how to do it).
I tried it and found that I prefer the "menu" style ergonomics.
index.php/fa/28203/0/
And on mobile (as mentioned the desktop works already fine for me) the new column (with the link) does not work as expected. In the automatically generated overview with the columns listed as data, the html-content is not rendered as html.
index.php/fa/28204/0/
As I will stick with the menues this doesn't bother me though Wink .
Previous Topic:[neon] Compilation fails with "cannot find symbol" using javac
Next Topic:[general] Experiences with Search/Filter and/or pagination
Current Time: Sun Jul 27 02:23:41 EDT 2025
Powered by FUDForum. Page generated in 0.05231 seconds
