Home » Modeling » TMF (Xtext) » Xtext 2.10.0 Intellij Gradle Task [lang].idea:downloadIdea fail (proxy authentication required)
Xtext 2.10.0 Intellij Gradle Task [lang].idea:downloadIdea fail (proxy authentication required) [message #1752185] Thu, 19 January 2017 09:10 Go to next message
Hello *,
i have created a new xtext Project with intellij idea and would like to build it with gradle built Task (from parent).
At the first run the build failed because it was not able to download some resources/libraries. In my company is a Proxy Server configuration with authentication necessary.
After googling I added a file ~/.gradle/gradle.properties like:
systemProp.http.proxyHost=proxy.company.org
systemProp.http.proxyPort=4711
systemProp.http.proxyUser=...
systemProp.http.proxyPassword=...
systemProp.http.nonProxyHosts=localhost|*.company.org
systemProp.https.proxyHost=proxy.company.org
systemProp.https.proxyPort=4711
systemProp.https.proxyUser=...
systemProp.https.proxyPassword=...
systemProp.https.nonProxyHosts=localhost|*.company.org
... and the build started and worked.... when suddenly:
:DSL.ide:check ...
:DSL.ide:build ...
:DSL.idea:downloadIdea FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':DSL.idea:downloadIdea'.
> java.io.IOException: Unable to tunnel through proxy. Proxy returns "HTTP/1.1 407 Proxy Authentication Required"
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
So... This is annoying. What can I do?
Thanks for your help!
Tobias
Re: Xtext 2.10.0 Intellij Gradle Task [lang].idea:downloadIdea fail (proxy authentication required) [message #1752186 is a reply to message #1752185] Thu, 19 January 2017 09:12 Go to previous message
Complement: --stacktrace/debug/info provides no more Infos (except a stacktrace)
Previous Topic:Xtext Summit @ EclipseCon France
Next Topic:Invalid context uring Epsilon transformation execution
Current Time: Sun Jul 20 20:21:56 EDT 2025
Powered by FUDForum. Page generated in 0.03936 seconds
