CDT Remote Debugging/Launching [message #1749860] |
Tue, 13 December 2016 04:42  |
Hi everyone,
I'm trying to remote debug (or at least run for a start) C/C++ programs on a target machine. My current attempt is to use "GDB (DSF) Automatic Remote Debugging via TCF/TE Launcher". While this works with Eclipse Luna, it fails on Eclipse Neon when I specify "Commands to execute before application" (which I need to do to make the transferred binary executable) with the following message:
Failed to create script with the Commands before launch in 'C:/Users/ipc/runtime-EclipseApplication/.metadata/.plugins/org.eclipse.tcf.te.tcf.launch.cdt/prerun_temp_scripts/10-31-14-366_ttp.sh'. Possibly caused by: Failed to read the Commands before launch script template 'null'.
I'm a bit surprised I seem to be the only one with this problem. At least I haven't found any information on it. Any ideas?
Another attempt I tried before was using the normal GDB Automatic Debugging Launcher (no TCF). While this works on my Raspberry Pi as the target machine, it fails on the actual the device I need to run stuff on (Yocto Linux on an Intel Galileo Board). The file is uploaded correctly but when changing the file permissions afterwards, things go wrong again:
Error during file upload.
Failed to change file permissions in the remote system, path: /home/root/ttp
Both RPi and the Yocto Board are running the same OpenSSH server. What else could be a reason for this?
Thank you!
Martin
Re: CDT Remote Debugging/Launching [message #1770900 is a reply to message #1749860] |
Fri, 18 August 2017 10:40  |
Hello Martin,
I also see this problems in Eclipse Neon. I get the error only when I specify a user in the "Launch as a remote user" field.
Failed to create script with the Commands before launch in '/home/ocp/workspace/.metadata/.plugins/org.eclipse.tcf.te.tcf.launch.cdt/prerun_temp_scripts/09-40-14-445_myapp_test_d.sh'. Possibly caused by: Failed to read the Commands before launch script template 'null'.
If I understood you correctly then you solved the problem by downloading the tcf source and compiling by yourself. How did you compile the source? I tried to compile it using maven but could not.
/Habib
FUDForum. Page generated in 0.07725 seconds
