XText hook for model transformation? [message #1751792] |
Sat, 14 January 2017 01:58  |
This is a general question about the XText workflow.
The language I am developing contains a concept of "tag" similar in syntax and functionality to Java annotations and more specifically Xtend active annotations. I use these tags to mark language elements (class, property, method, etc.) so that the code generator generate boilerplate code automagically.
The example below is one of the code generator unit-test:
@Test
def void passingTest() {
class TestCase {
methods {
@Test shouldPass {
assert(true)
.generate
.runTest('TestCase')
The inner @Test tag marks the "shouldPass" method and is supposed to transform the AST by inserting an ancestor to the 'TestCase' class. The problem I have is that I implemented this insertion mechanism in the code generator, only to realize that the validation, which happens before generation, fails. It fails because the "assert" call refers to a method of the class to be inserted which is not yet part of the AST when the validation happens.
I feel I need to hook the insertion step after parsing but before linking.
How can I achieve that?
Re: XText hook for model transformation? [message #1751795 is a reply to message #1751794] |
Sat, 14 January 2017 02:40   |
The grammar would be:
grammar com.septentrio.infrastructure.flax.Flax with org.eclipse.xtext.common.Terminals
generate language "http://www.septentrio.com/infrastructure/flax/Flax"
Flax:
('package' name=QualifiedName)?
(imports+=Import)*
(entities+=Entity)*;
Import:
'import' importedNamespace=QualifiedNameWithWildcard;
QualifiedName:
ID ('.' ID)*;
QualifiedNameWithWildcard:
QualifiedName '.*'?;
Entity:
Tag|Class;
Tag:
'tag' name=ID
( '{' properties+=TagProperty* '}' )?;
TagProperty:
name=ID;
TagReference:
'@' tag=[Tag]
( '(' ( properties+=[TagProperty|QualifiedName] ','? )* ')' )?;
Class:
tagrefs+=TagReference*
'class' name=ID
( 'extends' (parents+=[Class|QualifiedName]','?)+ )?
( '{' sections+=Section* '}' )?;
Section:
PropertySection|MethodSection;
PropertySection:
'properties' '{' properties+=Property* '}';
MethodSection:
'methods' '{' methods+=Method* '}';
Member:
Property|Method;
Property:
class=[Class|QualifiedName] name=ID;
Method:
class=[Class|QualifiedName]? name=ID
( '(' (parameters+=Parameter','?)* ')' )?
body=Block;
Block:
'{' (expressions+=Expression)* '}';
Parameter:
Symbol:
Entity|Parameter|Member;
Expression:
Primary ( {Selection.operand=current} levels+=SelectionLevel )*;
* The duplication of the 'Parameters' fragment together
* with the syntactic predicates is messy. It would be
* better to have one single rule for both and replace
* the cross-reference with a regular ID terminal rule.
Primary returns Expression:
'(' Expression ')' |
{Boolean} value=('true'|'false') |
{Integer} value=INT |
{This} 'this' |
{Metadata} '?' class=[Class|QualifiedName] |
{SymbolReference} symbol=[Symbol] => Parameters?;
SelectionLevel returns Expression:
{MemberSelection} '.' member=[Member] => Parameters?;
fragment Parameters:
parameterized ?= '(' (parameters+=Expression','?)* ')';
The generator would be:
package com.septentrio.infrastructure.flax.generator
import com.septentrio.infrastructure.flax.helper.FlaxHelper
import com.septentrio.infrastructure.flax.language.Class
import com.septentrio.infrastructure.flax.language.MethodSection
import com.septentrio.infrastructure.flax.language.Block
import com.septentrio.infrastructure.flax.language.Boolean
import com.septentrio.infrastructure.flax.language.Integer
import com.septentrio.infrastructure.flax.language.Metadata
import com.septentrio.infrastructure.flax.language.SymbolReference
import com.septentrio.infrastructure.flax.language.Selection
import com.septentrio.infrastructure.flax.language.MemberSelection
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.naming.IQualifiedNameProvider
import org.eclipse.xtext.generator.AbstractGenerator
import org.eclipse.xtext.generator.IFileSystemAccess2
import org.eclipse.xtext.generator.IGeneratorContext
import com.google.inject.Inject
import org.eclipse.emf.ecore.EObject
import java.util.ArrayDeque
import java.util.Map
import org.slf4j.Logger
import org.slf4j.LoggerFactory
import com.septentrio.infrastructure.flax.test.Exception
class FlaxMatlabGenerator extends AbstractFlaxGenerator {
private Logger logger = LoggerFactory.getLogger('FlaxGenerator')
@Inject extension FlaxHelper
@Inject extension IQualifiedNameProvider
override def String generate(EObject it, FlaxScope scope) {
logger.debug('''BODY: «it»''')
switch it {
case scope.isAssigned(it):
scope.getVariableFor(it)
Class:
classdef «name» «generateAncestry»
«FOR section : sections»
methods «IF isTestCase»(Test)«ENDIF»
«IF section instanceof MethodSection»
«FOR method : section.methods»
«method.generate(scope)»
«ENDFOR»
«ENDIF»
end
«ENDFOR»
end
Method:
function «name»(this«IF !parameters.empty», «parameters.map[generate(scope)].join(', ')»«ENDIF»)
«body.generateInChildScope»
end
Block:
«getPreambleFor(scope)»
«FOR expression : expressions»
«expression.generate(scope)»;
«ENDFOR»
Selection:
operand.generate(scope) + levels.map[generate(scope)].join
Boolean:
String.valueOf(value)
Integer:
Metadata:
'''flax.lang.Class.fromName('«class_.fullyQualifiedName»')'''
SymbolReference: {
switch symbol {
Class:
symbol.name
Member:
if (symbol.name.equals('assertInstanceOf') && containingClass.isTestCase)
'''this.flax__assertInstanceOf''' // circumvent sealed method
else
'''this.«symbol.name»'''
default:
throw new Exception('Unhandled symbol type')
'''«IF isParameterized»(«parameters.map[generate(scope)].join(', ')»)«ENDIF»'''
MemberSelection:
'''.«member.name»«IF isParameterized»(«parameters.map[generate(scope)].join(', ')»)«ENDIF»''' }
private def String getPreambleFor(EObject it, FlaxScope scope) {
logger.debug('''HEADER: «it»''')
switch it {
Block:
«FOR expression: expressions»
«expression.getPreambleFor(scope)»
«ENDFOR»
SymbolReference:
«IF symbol instanceof Class»
«generateVariableAssignment(scope)»
«ENDIF»
«IF parameterized»
«FOR parameter: parameters»
«parameter.getPreambleFor(scope)»
«ENDFOR»
«ENDIF»
Selection:
«operand.getPreambleFor(scope)»
«FOR level: levels»
«level.getPreambleFor(scope)»
«ENDFOR»
MemberSelection:
«IF parameterized»
«ENDFOR»
«ENDIF»
Metadata:
private def generateAncestry(Class it) {
if (!parents.isEmpty)
'''< «parents.map[fullyQualifiedName].join(' & ')»'''
else if (isTestCase)
'< flax.test.TestCase'
else
'< flax.lang.Object'
private def generateVariableAssignment(EObject it, FlaxScope scope) {
val rhs = generate(scope)
val lhs = scope.newVariableFor(it)
'''«lhs» = «rhs»;'''.toString
abstract class AbstractFlaxGenerator extends AbstractGenerator {
private Logger logger = LoggerFactory.getLogger('AbstractFlaxGenerator')
val scopes = new ArrayDeque<FlaxScope>
final override def void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
for(e:resource.allContents.toIterable)
switch e {
Class:
fsa.generateFile(e.name+".m",e.generateInChildScope)
final def generateInChildScope(EObject context) {
val scope = new FlaxScope(this)
scopes.push(scope)
val text = generate(context, scope)
scopes.pop
return text
final def isTestCase(Class it) {
val testTag = containingFlax.tags.findFirst[name == 'Test']
logger.debug('''testTag = «testTag»''')
logger.debug(''' tagrefs = «methods.map[tagrefs].flatten»''')
logger.debug(''' «testTag == isSameOrChildOf('flax.test.TestCase')»''')
logger.debug(''' «testTag == methods.map[tagrefs].flatten.exists[tag == testTag]»''')
switch it {
case isSameOrChildOf('flax.test.TestCase'):
true
case methods.map[tagrefs].flatten.exists[tag == testTag]:
true
default:
false
abstract def String generate(EObject context, FlaxScope scope)
class FlaxScope {
private Logger logger = LoggerFactory.getLogger('FlaxScope')
private AbstractFlaxGenerator generator
private extension Map<EObject, String> variables = newHashMap
private int count = 0
new (AbstractFlaxGenerator generator) {
this.generator = generator
def newVariableFor(EObject it) {
switch put(it, '''v«count++»''') {
case null: {
logger.debug('''NEW VARIABLE «get(it)» for «it»''')
get(it)
default:
throw new Exception('')
def isAssigned(EObject it) {
containsKey(it)
def getVariableFor(EObject it) {
get(it)
And the stripped generator test class:
package com.septentrio.infrastructure.flax.tests
import com.septentrio.infrastructure.flax.helper.FlaxLibrary
import com.septentrio.infrastructure.flax.test.AssertionFailedException
import matlabcontrol.MatlabProxyFactory
import matlabcontrol.MatlabProxyFactoryOptions
import matlabcontrol.MatlabConnectionException
import org.eclipse.xtext.validation.CheckMode
import org.eclipse.xtext.validation.IResourceValidator
import org.eclipse.xtext.generator.GeneratorContext
import org.eclipse.xtext.generator.GeneratorDelegate
import org.eclipse.xtext.generator.JavaIoFileSystemAccess
import org.eclipse.xtext.util.CancelIndicator
import org.eclipse.xtext.junit4.InjectWith
import org.eclipse.xtext.junit4.XtextRunner
import org.eclipse.xtext.junit4.TemporaryFolder
import org.eclipse.xtext.junit4.util.ResourceHelper
import org.junit.Test
import org.junit.runner.RunWith
import org.junit.BeforeClass
import org.junit.AfterClass
import org.junit.Assert
import java.nio.file.Paths
@RunWith(XtextRunner)
@InjectWith(FlaxInjectorProvider)
class FlaxGeneratorTest {
static private TemporaryFolder matlabFolder
static private MatlabProxy proxy
static private String matlabPath
@Inject private GeneratorDelegate generator
@Inject private JavaIoFileSystemAccess access
@Inject private IResourceValidator validator
@Inject extension ResourceHelper resourceHelper
@Inject extension FlaxLibrary
@BeforeClass
def static void setup() throws MatlabConnectionException {
matlabFolder = new TemporaryFolder()
proxy = new MatlabProxyFactory(
new MatlabProxyFactoryOptions.Builder()
.setUsePreviouslyControlledSession(true)
.setMatlabStartingDirectory(matlabFolder.getRoot)
.setProxyTimeout(60000) // 1 minute
.build
).getProxy
matlabPath = 'path'.evalAsString
@AfterClass
def static void teardown() {
// proxy.exit()
* flax.test package generator test
@Test
class TestCase {
methods {
@Test shouldPass {
assert(true)
.generate
* Matlab specific code
def private MatlabProxy generate(CharSequence text) {
val resource = text.resource
resource.resourceSet.loadFlaxLibrary
val issues = validator.validate(resource, CheckMode.ALL, CancelIndicator.NullImpl);
if (!issues.isEmpty) {
val message = new StringBuilder()
.append('Validation failed with the following issues:')
.append(new StringBuilder() => [issues.forEach(issue|it.append('\n'+issue))])
.toString
Assert.fail(message)
generator.generate(
resource,
access => [outputPath = matlabFolder.getRoot.getAbsolutePath],
new GeneratorContext() => [cancelIndicator = CancelIndicator.NullImpl]
'clear all'.eval
'path'.feval(matlabPath)
'cd'.feval(matlabFolder.root.toString)
* ../build/classes/test/ ...
* ../build/resources/matlab/ ...
val jarLocation = class.protectionDomain.codeSource.location
val jarPath = Paths.get(jarLocation.toURI)
val matlabLibraryRootPath = jarPath.resolve('../../resources/main/matlab/')
'addpath'.feval(matlabLibraryRootPath.toString)
return proxy
def private runTest(MatlabProxy proxy, String name) {
'''result = runtests('«name»');'''.eval
if ('numel(result)'.evalAsDouble == 0)
throw new Exception('''Test «name» execution ended unexpectdly''')
else if ('result.Failed'.evalAsBoolean == true) {
val report = 'result.Details.DiagnosticRecord.Report'.evalAsString
switch 'result.Details.DiagnosticRecord.Event'.evalAsString {
case 'AssertionFailed':
throw new AssertionFailedException(report)
default:
throw new Exception(report)
static private def eval(CharSequence text) {
text.toString.eval
static private def eval(String text) {
proxy.eval(text)
static private def evalAsDouble(String expression) {
(expression.returningEval(1).get(0) as double[]).get(0)
static private def evalAsBoolean(String expression) {
(expression.returningEval(1).get(0) as boolean[]).get(0)
static private def evalAsString(String expression) {
expression.returningEval(1).get(0) as String
static private def returningEval(String string, int nargout) {
proxy.returningEval(string, nargout)
static private def feval(String functionName, Object ... args) {
proxy.feval(functionName, args)
The error I see happens in the validation phase:
java.lang.AssertionError: Validation failed with the following issues:
ERROR:Couldn't resolve reference to Symbol 'assert'. (__synthetic0.flax line : 4 column : 13)
at org.junit.Assert.fail(Assert.java:91)
at com.septentrio.infrastructure.flax.tests.FlaxGeneratorTest.generate(FlaxGeneratorTest.java:335)
at com.septentrio.infrastructure.flax.tests.FlaxGeneratorTest.passingTest(FlaxGeneratorTest.java:119)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.eclipse.xtext.junit4.XtextRunner$1.evaluate(XtextRunner.java:49)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.junit.runner.JUnitCore.run(JUnitCore.java:157)
at com.intellij.junit4.JUnit4IdeaTestRunner.startRunnerWithArgs(JUnit4IdeaTestRunner.java:68)
at com.intellij.rt.execution.junit.IdeaTestRunner$Repeater.startRunnerWithArgs(IdeaTestRunner.java:51)
at com.intellij.rt.execution.junit.JUnitStarter.prepareStreamsAndStart(JUnitStarter.java:237)
at com.intellij.rt.execution.junit.JUnitStarter.main(JUnitStarter.java:70)
at com.intellij.rt.execution.application.AppMain.main(AppMain.java:147)
The "assert" symbol is a reference to a method defined in the flax.lang.TestCase class:
package flax.test
import flax.lang.Class
tag Test
class TestCase {
methods {
assert(boolean actual) {}
assertInstanceOf(Class actual) {}
As you can see this class is not declared as an ancestor of the "TestCase" class definition of the unit test above. If added manually, the error message disappear, which is expected.
Does it make any sense?
Re: XText hook for model transformation? [message #1751801 is a reply to message #1751800] |
Sat, 14 January 2017 03:35   |
e.g.
override getScope(EObject context, EReference reference) {
if (reference == MyDslPackage.Literals.MEMBER_REFERENCE__MEMBER && context instanceof MemberReference) {
val e = (context as MemberReference).getEntity()
if (e != null) {
return Scopes.scopeFor(e.getMembers());
} else {
val namespaceResolvers = #[new ImportNormalizer(QualifiedName.create("BaseClass"), true, false)];
val parent = delegateGetScope(context,reference)
return new ImportScope(namespaceResolvers, parent, null, MyDslPackage.Literals.MEMBER, false)
super.getScope(context, reference)
Re: XText hook for model transformation? [message #1751842 is a reply to message #1751803] |
Mon, 16 January 2017 02:35   |
I played around and injected the following DerivedStateComputer implementation:
class FlaxDerivedStateComputer implements IDerivedStateComputer {
static val private CLASS__PARENTS = LanguagePackage.Literals.CLASS__PARENTS
static val logger = LoggerFactory.getLogger('FlaxDerivedStateComputer')
@Inject private extension SyntheticLinkingSupport syntheticLinkingSupport
@Inject private extension FlaxHelper
@Inject private extension IQualifiedNameProvider
override installDerivedState(DerivedStateAwareResource resource, boolean preLinkingPhase) {
if (!resource.contents.isEmpty)
for (class: resource.model.classes)
if(class.containsTag('flax.test.Test'))
if(!class.isSameOrChildOf('flax.test.TestCase'))
class.createAndSetProxy(CLASS__PARENTS, 'flax.test.TestCase')
override discardDerivedState(DerivedStateAwareResource resource) {
if(!resource.contents.isEmpty)
for(class: resource.model.classes)
class.createAndSetProxy(CLASS__PARENTS, StringUtils.EMPTY)
private def getModel(Resource it) {
contents.get(0) as Flax
private def getMethodsTags(Class it) {
methods.map[tagrefs].flatten.map[tag]
private def containsTag(Class it, String tagName) {
methodsTags.exists[fullyQualifiedName.toString == tagName]
private def isSameOrChildOf(Class it, String className) {
ancestors.exists[fullyQualifiedName.toString == className]
And it works fine as long as I replace the CLASS__PARENTS feature entirely with something new. Apparently I cannot mutate the multi-valued feature (class.parents = <something> is not possible) to, for example, extends it with a single reference. I assume I need to go via the SyntheticLinkingSupport.createAndSetProxy method which only support string input. This means that I need to use the syntax of my language at this point, which feels odd. I would rather use a syntax agnostic method, where for example I would simply extends the multi-valued feature CLASS__PARENTS with an EReference object built from scratch. I could not find such method.
Any idea to make this cleaner?
FUDForum. Page generated in 0.27204 seconds
