Home » Eclipse Projects » NatTable » Editor position mismatches in Groupby Nattable.
Editor position mismatches in Groupby Nattable. [message #1751759] Fri, 13 January 2017 09:59 Go to next message
I'm building a Editiable Nattable with group by, filter and sorting characteristics. While editing the value after activating the cell, the editor position is within the cell.
But When I'm editing the cell without activating the cell, (i.e.) editing at the time of the position is selected it opens the editor in different position. How can we avoid this mismatch.
Refer the video for reference.
package org.eclipse.nebula.widgets.nattable.examples._400_Configuration;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Date;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import java.util.Properties;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.nebula.widgets.nattable.NatTable;
import org.eclipse.nebula.widgets.nattable.columnChooser.command.DisplayColumnChooserCommandHandler;
import org.eclipse.nebula.widgets.nattable.config.AbstractRegistryConfiguration;
import org.eclipse.nebula.widgets.nattable.config.CellConfigAttributes;
import org.eclipse.nebula.widgets.nattable.config.ConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.DefaultNatTableStyleConfiguration;
import org.eclipse.nebula.widgets.nattable.config.EditableRule;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.data.ExtendedReflectiveColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.IColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.IDataProvider;
import org.eclipse.nebula.widgets.nattable.data.IRowDataProvider;
import org.eclipse.nebula.widgets.nattable.data.convert.DefaultDoubleDisplayConverter;
import org.eclipse.nebula.widgets.nattable.dataset.person.Address;
import org.eclipse.nebula.widgets.nattable.dataset.person.ExtendedPersonWithAddress;
import org.eclipse.nebula.widgets.nattable.dataset.person.Person;
import org.eclipse.nebula.widgets.nattable.dataset.person.Person.Gender;
import org.eclipse.nebula.widgets.nattable.dataset.person.PersonService;
import org.eclipse.nebula.widgets.nattable.edit.EditConfigAttributes;
import org.eclipse.nebula.widgets.nattable.edit.command.UpdateDataCommand;
import org.eclipse.nebula.widgets.nattable.edit.command.UpdateDataCommandHandler;
import org.eclipse.nebula.widgets.nattable.examples.AbstractNatExample;
import org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsEventLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsSortModel;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.DefaultGlazedListsFilterStrategy;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByConfigAttributes;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByConfigLabelModifier;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByDataLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByHeaderLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByHeaderMenuConfiguration;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByModel;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.ModernGroupByThemeExtension;
import org.eclipse.nebula.widgets.nattable.filterrow.FilterRowDataLayer;
import org.eclipse.nebula.widgets.nattable.filterrow.FilterRowHeaderComposite;
import org.eclipse.nebula.widgets.nattable.filterrow.TextMatchingMode;
import org.eclipse.nebula.widgets.nattable.filterrow.config.FilterRowConfigAttributes;
import org.eclipse.nebula.widgets.nattable.freeze.CompositeFreezeLayer;
import org.eclipse.nebula.widgets.nattable.freeze.FreezeLayer;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultColumnHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultCornerDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultSummaryRowHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.layer.ColumnHeaderLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.CornerLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultColumnHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultRowHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.RowHeaderLayer;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupExpandCollapseLayer;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupHeaderLayer;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupModel;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupReorderLayer;
import org.eclipse.nebula.widgets.nattable.hideshow.ColumnHideShowLayer;
import org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform;
import org.eclipse.nebula.widgets.nattable.layer.CompositeLayer;
import org.eclipse.nebula.widgets.nattable.layer.DataLayer;
import org.eclipse.nebula.widgets.nattable.layer.ILayer;
import org.eclipse.nebula.widgets.nattable.layer.LabelStack;
import org.eclipse.nebula.widgets.nattable.layer.cell.AbstractOverrider;
import org.eclipse.nebula.widgets.nattable.layer.cell.ColumnLabelAccumulator;
import org.eclipse.nebula.widgets.nattable.painter.NatTableBorderOverlayPainter;
import org.eclipse.nebula.widgets.nattable.painter.cell.CheckBoxPainter;
import org.eclipse.nebula.widgets.nattable.persistence.command.DisplayPersistenceDialogCommandHandler;
import org.eclipse.nebula.widgets.nattable.reorder.ColumnReorderLayer;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayer;
import org.eclipse.nebula.widgets.nattable.sort.SortHeaderLayer;
import org.eclipse.nebula.widgets.nattable.sort.config.SingleClickSortConfiguration;
import org.eclipse.nebula.widgets.nattable.style.CellStyleAttributes;
import org.eclipse.nebula.widgets.nattable.style.DisplayMode;
import org.eclipse.nebula.widgets.nattable.style.HorizontalAlignmentEnum;
import org.eclipse.nebula.widgets.nattable.style.IStyle;
import org.eclipse.nebula.widgets.nattable.style.Style;
import org.eclipse.nebula.widgets.nattable.style.theme.ModernNatTableThemeConfiguration;
import org.eclipse.nebula.widgets.nattable.style.theme.ThemeConfiguration;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummaryDisplayConverter;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummaryRowConfigAttributes;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummaryRowLayer;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummationSummaryProvider;
import org.eclipse.nebula.widgets.nattable.tree.TreeLayer;
import org.eclipse.nebula.widgets.nattable.tree.command.TreeCollapseAllCommand;
import org.eclipse.nebula.widgets.nattable.tree.command.TreeExpandAllCommand;
import org.eclipse.nebula.widgets.nattable.ui.menu.AbstractHeaderMenuConfiguration;
import org.eclipse.nebula.widgets.nattable.ui.menu.PopupMenuBuilder;
import org.eclipse.nebula.widgets.nattable.util.GUIHelper;
import org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import ca.odell.glazedlists.EventList;
import ca.odell.glazedlists.FilterList;
import ca.odell.glazedlists.GlazedLists;
import ca.odell.glazedlists.SortedList;
import ca.odell.glazedlists.TransformedList;
 * Simple example showing how to add the group by feature to the layer
 * composition of a grid in conjunction with showing summary values of
 * groupings.
public class _810_SortableGroupByFilterColumnGroupAndFreezeExample extends AbstractNatExample {
    private static final String ROW_HEADER_SUMMARY_ROW = "rowHeaderSummaryRowLabel";
    private ColumnGroupModel columnGroupModel = new ColumnGroupModel();
    public static void main(String[] args) throws Exception {
        StandaloneNatExampleRunner.run(new _810_SortableGroupByFilterColumnGroupAndFreezeExample());
    public String getDescription() {
        return "This example shows the usage of the group by feature in conjunction with summary values of the groupings.";
    public Control createExampleControl(Composite parent) {
        Composite container = new Composite(parent, SWT.NONE);
        container.setLayout(new GridLayout());
        // create a new ConfigRegistry which will be needed for GlazedLists
        // handling
        final ConfigRegistry configRegistry = new ConfigRegistry();
        // property names of the ExtendedPersonWithAddress class
        final String[] propertyNames = { "firstName", "lastName", "age", "money",
                "married", "gender", "birthday" };
        // mapping from property to label, needed for column header labels
        Map propertyToLabelMap = new HashMap();
        propertyToLabelMap.put("firstName", "Firstname");
        propertyToLabelMap.put("lastName", "Lastname");
        propertyToLabelMap.put("age", "Age");
        propertyToLabelMap.put("money", "Money");
        propertyToLabelMap.put("married", "Married");
        propertyToLabelMap.put("gender", "Gender");
        propertyToLabelMap.put("birthday", "Birthday");
        final IColumnPropertyAccessor columnPropertyAccessor =
                new ExtendedReflectiveColumnPropertyAccessor(propertyNames);
        // to enable the group by summary feature, the GroupByDataLayer needs to
        // know the ConfigRegistry
        final BodyLayerStack bodyLayerStack =
                new BodyLayerStack(
                        PersonService.getExtendedPersonsWithAddress(100),
                        columnPropertyAccessor,
                        configRegistry);
        bodyLayerStack.getBodyDataLayer().setConfigLabelAccumulator(new ColumnLabelAccumulator());
        // build the column header layer
        IDataProvider columnHeaderDataProvider =
                new DefaultColumnHeaderDataProvider(propertyNames, propertyToLabelMap);
        DataLayer columnHeaderDataLayer =
                new DefaultColumnHeaderDataLayer(columnHeaderDataProvider);
        ColumnHeaderLayer columnHeaderLayer =
                new ColumnHeaderLayer(columnHeaderDataLayer, bodyLayerStack, bodyLayerStack.getSelectionLayer());
        // add sorting
        SortHeaderLayer sortHeaderLayer = new SortHeaderLayer(
                columnHeaderLayer,
                new GlazedListsSortModel(
                        bodyLayerStack.getSortedList(),
                        configRegistry,
                        columnHeaderDataLayer),
                false);
        // connect sortModel to GroupByDataLayer to support sorting by group by
        // summary values
        bodyLayerStack.getBodyDataLayer().initializeTreeComparator(
                sortHeaderLayer.getSortModel(),
                bodyLayerStack.getTreeLayer(),
                true);
        ColumnGroupHeaderLayer columnGroupHeaderLayer = new ColumnGroupHeaderLayer(
                sortHeaderLayer,
                bodyLayerStack.getSelectionLayer(),
                this.columnGroupModel);
        columnGroupHeaderLayer.setCalculateHeight(true);
        // add the filter row functionality
        final FilterRowHeaderComposite filterRowHeaderLayer =
                new FilterRowHeaderComposite(
                        new DefaultGlazedListsFilterStrategy(
                                bodyLayerStack.getFilterList(),
                                configRegistry),
                        columnGroupHeaderLayer,
                        columnHeaderDataLayer.getDataProvider(),
                        configRegistry);
        // Row header
        // Adding the specialized DefaultSummaryRowHeaderDataProvider to
        // indicate the summary row in the row header
        IDataProvider rowHeaderDataProvider =
                new DefaultSummaryRowHeaderDataProvider(bodyLayerStack.getBodyDataLayer().getDataProvider(), "\u2211");
        final DataLayer rowHeaderDataLayer =
                new DefaultRowHeaderDataLayer(rowHeaderDataProvider);
        // add a label to the row header summary row cell aswell, so it can be
        // styled differently too
        // in this case it will simply use the same styling as the summary row
        // in the body
        rowHeaderDataLayer.setConfigLabelAccumulator(new AbstractOverrider() {
            public void accumulateConfigLabels(LabelStack configLabels, int columnPosition, int rowPosition) {
                if ((rowPosition + 1) == rowHeaderDataLayer.getRowCount()) {
                    configLabels.addLabel(ROW_HEADER_SUMMARY_ROW);
                    configLabels.addLabel(SummaryRowLayer.DEFAULT_SUMMARY_ROW_CONFIG_LABEL);
        ILayer rowHeaderLayer =
                new RowHeaderLayer(rowHeaderDataLayer, bodyLayerStack, bodyLayerStack.getSelectionLayer());
        // build the corner layer
        IDataProvider cornerDataProvider =
                new DefaultCornerDataProvider(columnHeaderDataProvider, rowHeaderDataProvider);
        DataLayer cornerDataLayer =
                new DataLayer(cornerDataProvider);
        ILayer cornerLayer =
                new CornerLayer(cornerDataLayer, rowHeaderLayer, filterRowHeaderLayer);
        // build the grid layer
        GridLayer gridLayer = new GridLayer(bodyLayerStack, filterRowHeaderLayer, rowHeaderLayer, cornerLayer);
        // set the group by header on top of the grid
        CompositeLayer compositeGridLayer = new CompositeLayer(1, 2);
        final GroupByHeaderLayer groupByHeaderLayer = new GroupByHeaderLayer(
                bodyLayerStack.getGroupByModel(),
                gridLayer,
        compositeGridLayer.setChildLayer(GroupByHeaderLayer.GROUP_BY_REGION, groupByHeaderLayer, 0, 0);
        compositeGridLayer.setChildLayer("Grid", gridLayer, 0, 1);
        // turn the auto configuration off as we want to add our header menu
        // configuration
        final NatTable natTable = new NatTable(container, compositeGridLayer, false);
        // as the autoconfiguration of the NatTable is turned off, we have to
        // add the DefaultNatTableStyleConfiguration and the ConfigRegistry
        // manually
        natTable.setConfigRegistry(configRegistry);
        natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
        // add some additional styling
        natTable.addConfiguration(new AbstractRegistryConfiguration() {
            public void configureRegistry(IConfigRegistry configRegistry) {
                configRegistry.registerConfigAttribute(
                        CellConfigAttributes.CELL_PAINTER,
                        new CheckBoxPainter(), DisplayMode.NORMAL,
                        ColumnLabelAccumulator.COLUMN_LABEL_PREFIX + 4);
                        CellConfigAttributes.DISPLAY_CONVERTER,
                        new DefaultDoubleDisplayConverter(),
                        DisplayMode.NORMAL,
                        ColumnLabelAccumulator.COLUMN_LABEL_PREFIX + 3);
                        EditConfigAttributes.CELL_EDITABLE_RULE,
                        EditableRule.ALWAYS_EDITABLE);
            	 * This is added to include multiple word search operation for the free text filter.
            	 * @param configRegistry - config registry to update registry values.
            	 * @author Naveen.
                            FilterRowConfigAttributes.TEXT_DELIMITER, "&");
            		//Naveen 30-10-2016
            		// Regular expression applied for all the columns.
            		for (int i = 0; i < propertyNames.length; i++) {
            	                FilterRowConfigAttributes.TEXT_MATCHING_MODE,
            	                TextMatchingMode.REGULAR_EXPRESSION,
            	                DisplayMode.NORMAL,
            	                FilterRowDataLayer.FILTER_ROW_COLUMN_LABEL_PREFIX
            	                        + i);
        // add sorting configuration
        natTable.addConfiguration(new SingleClickSortConfiguration());
        // add group by summary configuration
                        GroupByConfigAttributes.GROUP_BY_CHILD_COUNT_PATTERN,
                        "[{0}] - ({1})");
                        GroupByConfigAttributes.GROUP_BY_HINT,
                        "Drag columns here");
                Style hintStyle = new Style();
                hintStyle.setAttributeValue(
                        CellStyleAttributes.FONT,
                        GUIHelper.getFont(new FontData("Arial", 10, SWT.ITALIC)));
                        GroupByConfigAttributes.GROUP_BY_HINT_STYLE,
                        hintStyle);
                        SummaryRowConfigAttributes.SUMMARY_PROVIDER,
                        new SummationSummaryProvider(bodyLayerStack.bodyDataProvider, false),
                        DisplayMode.NORMAL,
                        SummaryRowLayer.DEFAULT_SUMMARY_COLUMN_CONFIG_LABEL_PREFIX + 3);
                        new SummaryDisplayConverter(new DefaultDoubleDisplayConverter()),
                        DisplayMode.NORMAL,
                // the main styling of the summary row cell in the row header is
                // done via summary row default style, but we need to override
                // the alignment
                IStyle style = new Style();
                style.setAttributeValue(
                        CellStyleAttributes.HORIZONTAL_ALIGNMENT,
                        HorizontalAlignmentEnum.CENTER);
                        CellConfigAttributes.CELL_STYLE,
                        style,
                        DisplayMode.NORMAL, ROW_HEADER_SUMMARY_ROW);
                        style,
                        DisplayMode.SELECT, ROW_HEADER_SUMMARY_ROW);
        // add group by header configuration
        natTable.addConfiguration(new GroupByHeaderMenuConfiguration(natTable,
                groupByHeaderLayer));
        natTable.addConfiguration(new AbstractHeaderMenuConfiguration(natTable) {
            protected PopupMenuBuilder createColumnHeaderMenu(NatTable natTable) {
                return super.createColumnHeaderMenu(natTable)
                        .withHideColumnMenuItem().withShowAllColumnsMenuItem()
                        .withColumnChooserMenuItem()
                        .withCreateColumnGroupsMenuItem()
                        .withUngroupColumnsMenuItem()
                        .withAutoResizeSelectedColumnsMenuItem()
                        .withColumnRenameDialog().withClearAllFilters()
                        .withStateManagerMenuItemProvider();
            protected PopupMenuBuilder createCornerMenu(NatTable natTable) {
                return super.createCornerMenu(natTable)
        natTable.configure();
        natTable.registerCommandHandler(
                new DisplayPersistenceDialogCommandHandler(natTable));
        DisplayColumnChooserCommandHandler columnChooserCommandHandler =
                new DisplayColumnChooserCommandHandler(
                        bodyLayerStack.getColumnHideShowLayer(),
                        columnHeaderLayer,
                        null,
                        null);
        natTable.registerCommandHandler(columnChooserCommandHandler);
        GridDataFactory.fillDefaults().grab(true, true).applyTo(natTable);
        Composite buttonPanel = new Composite(container, SWT.NONE);
        buttonPanel.setLayout(new RowLayout());
        GridDataFactory.fillDefaults().grab(true, false).applyTo(buttonPanel);
        Button toggleHeaderButton = new Button(buttonPanel, SWT.PUSH);
        toggleHeaderButton.setText("Toggle Group By Header");
        toggleHeaderButton.addSelectionListener(new SelectionAdapter() {
            public void widgetSelected(SelectionEvent e) {
                groupByHeaderLayer.setVisible(!groupByHeaderLayer.isVisible());
        Button toggleFilterButton = new Button(buttonPanel, SWT.PUSH);
        toggleFilterButton.setText("Toggle Filter Row");
        toggleFilterButton.addSelectionListener(new SelectionAdapter() {
                filterRowHeaderLayer.setFilterRowVisible(!filterRowHeaderLayer.isFilterRowVisible());
        Button collapseAllButton = new Button(buttonPanel, SWT.PUSH);
        collapseAllButton.setText("Collapse All");
        collapseAllButton.addSelectionListener(new SelectionAdapter() {
                natTable.doCommand(new TreeCollapseAllCommand());
        Button expandAllButton = new Button(buttonPanel, SWT.PUSH);
        expandAllButton.setText("Expand All");
        expandAllButton.addSelectionListener(new SelectionAdapter() {
                natTable.doCommand(new TreeExpandAllCommand());
        // this button adds data to the grid
        // try to group by last name, sort by last name desc and then add
        // dynamic data for verification
        Button addDynamicDataButton = new Button(buttonPanel, SWT.PUSH);
        addDynamicDataButton.setText("Add Data");
        addDynamicDataButton.addSelectionListener(new SelectionAdapter() {
                Address address = new Address();
                address.setStreet("Some Street");
                address.setHousenumber(42);
                address.setPostalCode(12345);
                address.setCity("In the clouds");
                Person person = new Person(42, "Ralph", "Wiggum", Gender.MALE, false, new Date());
                ExtendedPersonWithAddress entry = new ExtendedPersonWithAddress(person, address,
                        "0000", "The little Ralphy", PersonService.createRandomMoneyAmount(),
                        new ArrayList(), new ArrayList());
                bodyLayerStack.getEventList().add(entry);
                person = new Person(42, "Clancy", "Wiggum", Gender.MALE, true, new Date());
                        "XXXL", "It is Chief Wiggum", PersonService.createRandomMoneyAmount(),
                person = new Person(42, "Sarah", "Wiggum", Gender.FEMALE, true, new Date());
                        "mommy", "Little Ralphy's mother", PersonService.createRandomMoneyAmount(),
        // add modern styling
        ThemeConfiguration theme = new ModernNatTableThemeConfiguration();
        theme.addThemeExtension(new ModernGroupByThemeExtension());
        natTable.setTheme(theme);
        // add a border on every side of the table
        natTable.addOverlayPainter(new NatTableBorderOverlayPainter());
        this.natTable = natTable;
        return container;
     * Always encapsulate the body layer stack in an AbstractLayerTransform to
     * ensure that the index transformations are performed in later commands.
     * @param
    class BodyLayerStack extends AbstractLayerTransform {
        private final EventList eventList;
        private final SortedList sortedList;
        private final FilterList filterList;
        private final IDataProvider bodyDataProvider;
        private final GroupByDataLayer bodyDataLayer;
        private final ColumnHideShowLayer columnHideShowLayer;
        private final SelectionLayer selectionLayer;
        private final TreeLayer treeLayer;
        private final GroupByModel groupByModel = new GroupByModel();
        public BodyLayerStack(List values,
                IColumnPropertyAccessor columnPropertyAccessor,
            // wrapping of the list to show into GlazedLists
            // see http://publicobject.com/glazedlists/ for further information
            this.eventList = GlazedLists.eventList(values);
            TransformedList rowObjectsGlazedList = GlazedLists.threadSafeList(this.eventList);
            // use the SortedList constructor with 'null' for the Comparator
            // because the Comparator
            // will be set by configuration
            this.sortedList = new SortedList(rowObjectsGlazedList, null);
            // wrap the SortedList with the FilterList
            this.filterList = new FilterList(this.sortedList);
            // Use the GroupByDataLayer instead of the default DataLayer
            this.bodyDataLayer = new GroupByDataLayer(
                    getGroupByModel(),
                    this.filterList,
                    configRegistry);
            // get the IDataProvider that was created by the GroupByDataLayer
            this.bodyDataProvider = this.bodyDataLayer.getDataProvider();
            // layer for event handling of GlazedLists and PropertyChanges
            GlazedListsEventLayer glazedListsEventLayer =
                    new GlazedListsEventLayer(this.bodyDataLayer, this.filterList);
            SummaryRowLayer summaryRowLayer =
                    new SummaryRowLayer(glazedListsEventLayer, configRegistry, false);
            ColumnReorderLayer columnReorderLayer =
                    new ColumnReorderLayer(summaryRowLayer);
            ColumnGroupReorderLayer columnGroupReorderLayer =
                    new ColumnGroupReorderLayer(
                            columnReorderLayer,
                            _810_SortableGroupByFilterColumnGroupAndFreezeExample.this.columnGroupModel);
            this.columnHideShowLayer =
                    new ColumnHideShowLayer(columnGroupReorderLayer);
            ColumnGroupExpandCollapseLayer columnGroupExpandCollapseLayer =
                    new ColumnGroupExpandCollapseLayer(
                            this.columnHideShowLayer,
            this.selectionLayer = new SelectionLayer(columnGroupExpandCollapseLayer);
            // add a tree layer to visualise the grouping
            this.treeLayer = new TreeLayer(this.selectionLayer, this.bodyDataLayer.getTreeRowModel());
            ViewportLayer viewportLayer = new ViewportLayer(this.treeLayer);
            // this will avoid tree specific rendering regarding alignment and
            // indentation in case no grouping is active
            viewportLayer.setConfigLabelAccumulator(new GroupByConfigLabelModifier(getGroupByModel()));
            FreezeLayer freezeLayer = new FreezeLayer(this.treeLayer);
            CompositeFreezeLayer compositeFreezeLayer =
                    new CompositeFreezeLayer(freezeLayer, viewportLayer, this.selectionLayer);
            setUnderlyingLayer(compositeFreezeLayer);
            // we register a custom UpdateDataCommandHandler that ensures to
            // update the tree structure
            this.bodyDataLayer.unregisterCommandHandler(UpdateDataCommand.class);
            this.bodyDataLayer.registerCommandHandler(new UpdateDataCommandHandler(this.bodyDataLayer) {
                @SuppressWarnings("unchecked")
                protected boolean doCommand(UpdateDataCommand command) {
                    if (super.doCommand(command)) {
                    	ExtendedPersonWithAddress o = (ExtendedPersonWithAddress) ((IRowDataProvider) BodyLayerStack.this.bodyDataProvider).getRowObject(command.getRowPosition());
                        int rowIndex = filterList.indexOf(o);
                        if (rowIndex >= 0) {
                        	filterList.set(rowIndex, o);
                        return true;
                    return false;
        public ColumnHideShowLayer getColumnHideShowLayer() {
            return this.columnHideShowLayer;
        public TreeLayer getTreeLayer() {
            return this.treeLayer;
        public SelectionLayer getSelectionLayer() {
            return this.selectionLayer;
        public EventList getEventList() {
            return this.eventList;
        public SortedList getSortedList() {
            return this.sortedList;
        public FilterList getFilterList() {
            return this.filterList;
        public IDataProvider getBodyDataProvider() {
            return this.bodyDataProvider;
        public GroupByDataLayer getBodyDataLayer() {
            return this.bodyDataLayer;
        public GroupByModel getGroupByModel() {
            return this.groupByModel;
    public static final String PROPERTIES_FILE = "myState.properties";
    public NatTable natTable;
    public void onStart() {
        Properties properties = new Properties();
        try {
            System.out.println("Loading NatTable state from " + PROPERTIES_FILE);
            properties.load(new FileInputStream(new File(PROPERTIES_FILE)));
            this.natTable.loadState("", properties);
        } catch (FileNotFoundException e) {
            // No file found, oh well, move along
            System.out.println(PROPERTIES_FILE + " not found, skipping load");
        } catch (IOException e) {
            throw new RuntimeException(e);
    public void onStop() {
        this.natTable.saveState("", properties);
        try {
            System.out.println("Saving NatTable state to " + PROPERTIES_FILE);
            properties.store(new FileOutputStream(new File(PROPERTIES_FILE)), "NatTable state");
        } catch (Exception e) {
  • Attachment: test1.avi
    (Size: 20.22MB, Downloaded 172 times)
Re: Editor position mismatches in Groupby Nattable. [message #1751764 is a reply to message #1751759] Fri, 13 January 2017 10:43 Go to previous messageGo to next message
You need to create the GridLayer without applying the default configuration
GridLayer gridLayer = new GridLayer(bodyLayerStack, filterRowHeaderLayer, rowHeaderLayer, cornerLayer, false);
And then add an edit configuration that connects the command handler and event handler to the surrounding CompositeLayer
// add editing capability
compositeGridLayer.addConfiguration(new AbstractLayerConfiguration<AbstractLayer>() {
                IEditableRule.ALWAYS_EDITABLE);
                EditConfigAttributes.CELL_EDITOR,
                new TextCellEditor());
                EditConfigAttributes.DATA_VALIDATOR,
                new DefaultDataValidator());
    public void configureTypedLayer(AbstractLayer layer) {
        layer.registerCommandHandler(new EditCellCommandHandler());
        layer.registerEventHandler(new InlineCellEditEventHandler(layer));
compositeGridLayer.addConfiguration(new DefaultEditBindings());
This can also be seen in the _812_EditableGroupBySummarySummaryRowExample
Re: Editor position mismatches in Groupby Nattable. [message #1751770 is a reply to message #1751764] Fri, 13 January 2017 11:19 Go to previous messageGo to next message
Thanks for the solution. Let me try this method in my usecase.
In the same example with large items, Some times after applying Group by, while Adding and removing filter. Its creating a concurrency exception. How can we avoid those exceptions.
Jan 13, 2017 5:17:29 PM org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.DefaultGlazedListsFilterStrategy applyFilter
SEVERE: Error on applying a filter
java.util.ConcurrentModificationException: Cannot begin a new event while another event is in progress by thread, main
Re: Editor position mismatches in Groupby Nattable. [message #1751776 is a reply to message #1751770] Fri, 13 January 2017 12:30 Go to previous messageGo to next message
Which version of NatTable do you use? We recently fixed concurrency issues in that region
Re: Editor position mismatches in Groupby Nattable. [message #1752238 is a reply to message #1751776] Fri, 20 January 2017 03:48 Go to previous message
Thanks dirk.
Its Nattable 1.3. I need to do the update to my Nattable.
Previous Topic:Displaying different objects in Nat Table
Next Topic:Search not working
Current Time: Sun Jul 20 21:38:05 EDT 2025
Powered by FUDForum. Page generated in 0.08051 seconds
