Home » Archived » Eclipse SmartHome » How to get binding configuration properties in an AbstractDiscoveryService?
How to get binding configuration properties in an AbstractDiscoveryService? [message #1751712] Thu, 12 January 2017 13:49 Go to next message
Hey guys,
I created a binding which requires a mandatory configuration parameter which contains the url of a server:
binding.xml
<config-description>
		<parameter name="server" type="text" required="true">
			<label>server url</label>
			<description>Required Property, always set this one</description>
		</parameter>
</config-description>
To get the parameter value, I'am using
MyHandlerFactory.java
    protected void activate(ComponentContext componentContext) {
        super.activate(componentContext);
        Dictionary<String, Object> properties = componentContext.getProperties();
        String server = (String) properties.get("server");
in my BaseThingHandlerFactory, which works quite well. Unfortunately my AbstractDiscoveryService's activate method is not called again, as it is in the BaseThingHandlerFactory, when setting the property in paperUI.
I have to know the property value in my discovery service, as without the server URL discovery is not possible at all.
So how to get this property's value in a AbstractDiscoveryService?
Best Regards,
-mk
Re: How to get binding configuration properties in an AbstractDiscoveryService? [message #1751857 is a reply to message #1751712] Mon, 16 January 2017 05:17 Go to previous message
How did you register your discovery service? You will need to register it through code within your ThingHandlerFactory - i.e. register it in activate() and unregister it in deactivate() of your handler factory (similar to this: https://github.com/eclipse/smarthome/blob/master/extensions/binding/org.eclipse.smarthome.binding.hue/src/main/java/org/eclipse/smarthome/binding/hue/internal/HueThingHandlerFactory.java#L99-L102). Through this, you always have the chance to pass your current configuration to it.
Previous Topic:Yahoo Weather Binding Crash
Next Topic:How To Query Items Things and Bindings
Current Time: Thu Nov 06 19:51:50 EST 2025
Powered by FUDForum. Page generated in 0.03706 seconds
