Home » Modeling » Epsilon » Problems loading XSD in standalone transformation
Problems loading XSD in standalone transformation [message #1751492] Tue, 10 January 2017 13:34 Go to next message
I am working in an standalone transformation that uses as input an XML backed with an XMLSchema. My code is based on "org.eclipse.epsilon.eunit.examples.etl", so my models and metamodels are placed in a source code folder with the packages models and metamodels.
I have tried several things with no success.
Attempt 1:
I copy this section of code of the thread [1]:
             StringProperties sp = new StringProperties();
			sp.put(XmlModel.PROPERTY_NAME, name);
			sp.put(XmlModel.PROPERTY_READONLOAD, readOnLoad);
			sp.put(XmlModel.PROPERTY_STOREONDISPOSAL, storeOnDisposal);
			sp.put(XmlModel.PROPERTY_XSD_FILE,getResourceEmfURI(metamodelPath).toFileString());
			sp.put(XmlModel.PROPERTY_MODEL_FILE,getResourceEmfURI(modelPath).toFileString());
			xmlModel.load(sp, (IRelativePathResolver)null);
The code of the method getResourceEmfURI is:
private URI getResourceEmfURI(String resourcePath) {
		URI res=URI.createURI(getClass().getResource(
				RESOURCE_PATH_PREFIX + resourcePath).toExternalForm());
		System.out.println(res.toFileString());
		return res;
and I got the following exception:
at org.eclipse.epsilon.emc.emf.xml.XmlModel.load(XmlModel.java:40)
at org.eclipse.opencert.epfimport.standalone.EPFTransformation.loadXMLModel(EPFTransformation.java:46)
at org.eclipse.opencert.epfimport.standalone.RunTransformation.main(RunTransformation.java:11)
which is caused by the fact that the IRelativePathResolver is null. However, I do not know about any implementation of this interface.
Attempt 2
My second attempt has been directly inspired by the standalone examples of the mentioned example and it is as follows:
                        xmlModel.setName(name);
			xmlModel.setMetamodelFileUri(getResourceEmfURI(metamodelPath));
			xmlModel.setModelFileUri(getResourceEmfURI(modelPath));
			xmlModel.setReadOnLoad(readOnLoad);
			xmlModel.setStoredOnDisposal(storeOnDisposal);
			xmlModel.load();
Internal error: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Class 'schema' is not found or is abstract. [file:/G:/*****/bin/metamodels/EPFSchema.xsd, 3, 162]
Do you have any idea about how to resolve this?
[1]http://www.eclipse.org/forums/index.php?t=msg&&th=153856&goto=484564
Re: Problems loading XSD in standalone transformation [message #1751530 is a reply to message #1751492] Wed, 11 January 2017 03:47 Go to previous messageGo to next message
Nothing comes to mind off the top of my head I'm afraid. Could you please provide a minimal example [1] we can use to reproduce this?
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/minimal-examples
Re: Problems loading XSD in standalone transformation [message #1751538 is a reply to message #1751530] Wed, 11 January 2017 05:03 Go to previous messageGo to next message
Hi Dimitris,
Please find attached the minimal example.
[Updated on: Wed, 11 January 2017 09:27] by Moderator
Re: Problems loading XSD in standalone transformation [message #1751539 is a reply to message #1751538] Wed, 11 January 2017 05:23 Go to previous messageGo to next message
Replacing "xmlModel.load(sp, (IRelativePathResolver)null);" in attempt1 with the following should do the trick.
xmlModel.load(sp, new IRelativePathResolver() {
    public String resolve(String relativePath) {
        return relativePath;
Dimitris
Re: Problems loading XSD in standalone transformation [message #1751543 is a reply to message #1751539] Wed, 11 January 2017 05:31 Go to previous message
It works!
Many thanks for this.
Aubrey
Previous Topic:return substring
Next Topic:How to implement rules to a connector
Current Time: Sat Jul 26 11:48:46 EDT 2025
Powered by FUDForum. Page generated in 0.03858 seconds
