MYSQL database connection getting closed intermittently [message #1751382] |
Mon, 09 January 2017 10:47  |
Hi experts,
My application on Scout framework throws an processing error, since the mysql database connection thread is getting closed abruptly during writing data into the database.
My application parses around >4GB binary files and writes into the MYSQL database continuously, each record size would be 1500 bytes. But the MYSQL database connection automatically closed after writing around 130000 records. Later throws an error since trying to write data on closed connection.
I could not locate how to handle this issue, can I get your help here, please
The Console message:
Parsing Packet(Size 1456 ): 132840
!ENTRY org.eclipse.scout.rt.server 1 0 2017-01-09 19:58:09.448
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.dump(StatementProcessor.java:849)
SQL with binds:
INSERT IGNORE
INTO DDR.LR_ARRAY_ACOUSTIC_SENSOR(.................................)
VALUES (.................................................)
Parsing Packet(Size 1456 ): 132841
!ENTRY org.eclipse.scout.rt.server 1 0 2017-01-09 19:58:09.536
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.ConnectionCloseThread.run(ConnectionCloseThread.java:33) close connection com.mysql.jdbc.JDBC4Connection@236b397d
!ENTRY org.eclipse.scout.rt.server 1 0 2017-01-09 19:58:09.580
SQL with binds:
INSERT IGNORE
INTO DDR.LR_ARRAY_ACOUSTIC_SENSOR(..................................)
VALUES (................................)
!ENTRY org.eclipse.scout.rt.shared 4 0 2017-01-09 20:01:02.095
!MESSAGE org.eclipse.scout.rt.shared.services.common.exceptionhandler.LogExceptionHandlerService.differentiatedLog(LogExceptionHandlerService.java:77) ProcessingStatus[ERROR code=0 SQL with binds:
INSERT IGNORE
com.mysql.jdbc.exceptions.jdbc4.MySQLNonTransientConnectionException: No operations allowed after connection closed.]
SQL with binds:
INSERT IGNORE
INSERT IGNORE
!STACK 0
ProcessingException[ProcessingStatus[ERROR code=0 SQL with binds:
INSERT IGNORE
com.mysql.jdbc.exceptions.jdbc4.MySQLNonTransientConnectionException: No operations allowed after connection closed.]]
at org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.processModification(StatementProcessor.java:453)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.insert(AbstractSqlService.java:741)
at org.eclipse.scout.rt.server.services.common.jdbc.SQL.insert(SQL.java:133)
at com.vimoon.rdatool.server.ui.forms.GenerateDatabaseService.addPacket(GenerateDatabaseService.java:109)
at com.vimoon.rdatool.shared.DDRParser.parseFile(DDRParser.java:496)
at com.vimoon.rdatool.server.ui.forms.GenerateDatabaseService.store(GenerateDatabaseService.java:66)
at org.eclipse.scout.service.ServiceUtility.invoke(ServiceUtility.java:172)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invokeImpl(DefaultTransactionDelegate.java:208)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invoke(DefaultTransactionDelegate.java:97)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransactionWithDelegate(ServiceTunnelServlet.java:417)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransaction(ServiceTunnelServlet.java:404)
at org.eclipse.scout.rt.server.ServiceTunnelServlet$RemoteServiceJob.runTransaction(ServiceTunnelServlet.java:441)
at org.eclipse.scout.rt.server.ServerJob.runTransactionWrapper(ServerJob.java:223)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:179)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:1)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.eclipse.scout.rt.server.ServerJob.run(ServerJob.java:174)
at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:51)
at org.eclipse.scout.rt.server.ServerJob.runNow(ServerJob.java:166)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.doPost(ServiceTunnelServlet.java:343)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.scout.rt.server.commons.servletfilter.HttpServletEx.access$0(HttpServletEx.java:1)
at org.eclipse.scout.rt.server.commons.servletfilter.HttpServletEx$1.service(HttpServletEx.java:38)
at org.eclipse.scout.rt.server.commons.internal.FilterChainImpl.doFilter(FilterChainImpl.java:44)
at org.eclipse.scout.rt.server.SoapWsseJaasFilter$2.run(SoapWsseJaasFilter.java:198)
at org.eclipse.scout.rt.server.SoapWsseJaasFilter.continueChainWithPrincipal(SoapWsseJaasFilter.java:191)
at org.eclipse.scout.rt.server.SoapWsseJaasFilter.doFilter(SoapWsseJaasFilter.java:135)
at org.eclipse.scout.rt.server.commons.internal.FilterChainImpl.doFilter(FilterChainImpl.java:41)
at org.eclipse.scout.rt.server.commons.servletfilter.ServletFilterDelegate.delegateServiceMethod(ServletFilterDelegate.java:60)
at org.eclipse.scout.rt.server.commons.servletfilter.HttpServletEx.service(HttpServletEx.java:35)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1232)
at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:153)
at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:63)
at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:98)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl.doDispatch(HttpServiceRuntimeImpl.java:372)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:70)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:357)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLNonTransientConnectionException: No operations allowed after connection closed.
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.Util.getInstance(Util.java:386)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1013)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:987)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:982)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:927)
at com.mysql.jdbc.ConnectionImpl.throwConnectionClosedException(ConnectionImpl.java:1206)
at com.mysql.jdbc.ConnectionImpl.checkClosed(ConnectionImpl.java:1198)
at com.mysql.jdbc.ConnectionImpl.prepareStatement(ConnectionImpl.java:4183)
at com.mysql.jdbc.ConnectionImpl.prepareStatement(ConnectionImpl.java:4149)
at org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.PreparedStatementCache.getPreparedStatement(PreparedStatementCache.java:56)
at org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.processModification(StatementProcessor.java:435)
... 62 more
!ENTRY org.eclipse.scout.rt.server 4 0 2017-01-09 20:01:02.114
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService$SqlTransactionMember.rollback(AbstractSqlService.java:901) null
!STACK 0
at com.mysql.jdbc.ConnectionImpl.rollback(ConnectionImpl.java:4690)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService$SqlTransactionMember.rollback(AbstractSqlService.java:897)
at org.eclipse.scout.rt.server.transaction.BasicTransaction.rollback(BasicTransaction.java:175)
at org.eclipse.scout.rt.server.ServerJob.runTransactionWrapper(ServerJob.java:268)
!ENTRY org.eclipse.scout.rt.server 2 0 2017-01-09 20:01:02.125
!MESSAGE org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.releaseConnection(SqlConnectionPool.java:203) closing dirty connection: com.mysql.jdbc.JDBC4Connection@236b397d
[Updated on: Mon, 09 January 2017 10:58] by Moderator
Re: MYSQL database connection getting closed intermittently [message #1751410 is a reply to message #1751393] |
Mon, 09 January 2017 23:33   |
Thanks for your response Ivan.
>>>>are you using auto-commit?
I hope so; am just using the scout framework and its classes(com.bsiag.scout.rt.server.jdbc.AbstractMySqlSqlService)/functions to configure the MYSQL/JDBC connection and passing SQL Queries to MYSQL server. I am neither explicitly starting/closing JDBC connection nor calling 'commit' manually.
>>>>What is the code you are trying to execute. Is it a batch insert or manually written sql statements?
I am passing SQL queries one by one manually through the functions from the class com.bsiag.scout.rt.server.jdbc.AbstractMySqlSqlService/AbstractSqlService: int insert(String s, Object... bindBases) throws ProcessingException; the other functions used are Object[][] select(String s, Object... bindBases) throws ProcessingException, public void selectInto(String s, Object... bindBases) throws ProcessingException, int update(String s, Object... bindBases) throws ProcessingException, int delete(String s, Object... bindBases) throws ProcessingException, etc
what are the possible situations/conditions the JDBC connection thread would be closed automatically?
How to manually invoke/close the JDBC connection, commit/rollback in scout( / disable the auto-commit) to MYSQL server?
How to capture the jdbc connection/thread close event and restart from scout?
How to configure for batch mode of data passing to MYSQL server?
Is it possible to write/read high volume of data(>4GB) at a instant to/from MYSQL from scout?
[Updated on: Mon, 09 January 2017 23:48] by Moderator
Re: MYSQL database connection getting closed intermittently [message #1752802 is a reply to message #1751448] |
Fri, 27 January 2017 08:48  |
The parameter "JdbcPoolConnectionBusyTimeout" is defined with the value 21600000ms in AbstractSQLService; the timer expiry causes the closing of JDBCPool connection thread, and as well the auto-commit is disabled here.
I am searching for the solution to generate the event on "JdbcPoolConnectionBusyTimeout" timer expiry and re-lease/getting-back the connection from the jdbc pool in scout. can anyone help me plz?
FUDForum. Page generated in 0.04420 seconds
