Home » Language IDEs » Java Development Tools (JDT) » External change to manually compiled files
icon5.gif  External change to manually compiled files [message #1751316] Sun, 08 January 2017 06:32 Go to next message
Hi everybody,
i am developing a plugin which mainly handles uml diagrams. To get a better understanding of the preceding steps (if the error might happen somewhere there) here is what i do:
- Generate a UML Model with MagicDraw
- Load the uml 2.3 model into a emf resource in the plugin
- transform it according to a company metamodel using ATL
- generate java code out of this model using Acceleo
- compile the code at runtime
- execute the code <- here comes the problem, the rest works fine so far
The compilation of the generated file works without any problems. If i trigger the process the generated java file is always correct (according to the models content) and the class file corresponds to the java file, so the compilation worked.
I use for compilation and the start of the class the following code:
	    File file = new File(pathToFile);
	    JavaCompiler compiler = ToolProvider.getSystemJavaCompiler();
	    compiler.run(null, null, null, file.getPath());
	    URLClassLoader classLoader = URLClassLoader.newInstance(new URL[] {file.getParentFile().toURI().toURL()});
	    Class<?> cls = classLoader.loadClass("nameOfTheClass"); //name replaced
	    CustomInterface instance = (CustomInterface ) cls.newInstance();
	    classLoader.close();
	    instance.startSimulation();
The main problem now is, that the instantiated class is not the one i compiled before, but the one i compiled at first execution of the code. So no external changes in the files are noticed by java. I guess eclipse keeps the class in memory, although i always create a new classLoader instance.
If i open the generated java file in eclipse and eclipse reloads the file (automatically) then in the next execution the class of the point of time when i open the java file in eclipse is used. Further changes are only loaded if i open the java file again.
I already tried to delete the class file before recompilation and to call classLoader.clearAssertionStatus() but both did not solve the problem.
So does anyone have an idea how to call java, that the newly generated class file has to be loaded? I thought classLoader.loadClass(...) would do exactly this but it seems it doesn't...
Thanks in advance for your help!
Re: External change to manually compiled files [message #1751415 is a reply to message #1751316] Tue, 10 January 2017 02:30 Go to previous messageGo to next message
Benno,
this sounds as if the Generator does not use the IFile/IFolder to write the generated files, but uses java.io.File. If so try the following after generating:
IProject prj = .....   // Determine the current Eclipse project.
prj.refreshLocal(IResource.DEPTH_INFINITE, null);
Just a guess...
Ralf
Re: External change to manually compiled files [message #1751810 is a reply to message #1751415] Sat, 14 January 2017 09:45 Go to previous message
Thanks for your reply! Unfortunately this does not work for me.
Meanwhile i found a workaround myself. I load the generated classfile as byte[] using the 'defineClass' Method, which forces the classloader to explicitly reload the class content from the byte[]. My solution now looks like the following:
public class ByteArrayClassLoader extends ClassLoader {
	public ByteArrayClassLoader() {
		super();
	public Class<?> findClass(String name, byte[] ba) {
	        return defineClass(name,ba,0,ba.length);
//changed part:
Path path = classFile.toPath();
byte[] data = Files.readAllBytes(path);
Class<?> cls = new ByteArrayClassLoader().findClass("cpsModeler.logic.interceptor.codeGenerator.genSrc.generatedFSM", data);
Previous Topic:Use
Next Topic:Help adding license to program
Current Time: Thu Jul 24 22:31:27 EDT 2025
Powered by FUDForum. Page generated in 0.25947 seconds
