Home » Eclipse Projects » EclipseLink » Erro: Column name is being ignored(An exception was thrown while trying to Query. The EclipseLink is changes the field (column name) name by the the attribute name.)
Erro: Column name is being ignored [message #1750931] |
Mon, 02 January 2017 07:03  |
Versions:
NetBeans - 8.1
EclipseLink - 2.5.2
Postgresql - 9.1
GlassFish Server 4
I don't know why, but note that t2.id should be t2.pess_id, but EclipseLink changes the column name by the attribute.
Someone can help me?
Detalhado: SELECT comp_cota_id, alte_em, alte_por_id, comp_cota_situ, cria_em, cria_por_id, dscr, praz_entr_cota, empr_unid_id, usua_id FROM comp_cota
Detalhado: SELECT t0.pess_id, t0.cadastro_tipo, t0.alte_em, t0.alte_por_id, t0.anfi, t0.apel_nome_fant, t0.ativ, t0.cada_tipo, t0.clie, t0.cons_fat_min, t0.cria_em, t0.cria_por_id, t0.forn, t0.nasc_fund, t0.nome_raza_soci, t0.obs, t0.pess_tipo, t0.pess_grup_id, t1.pess_id, t1.alte_em, t1.alte_por_id, t1.cpf_cnpj, t1.cria_em, t1.cria_por_id, t1.rg_ie, t2.pess_id, t2.alte_em, t2.alte_por_id, t2.cria_em, t2.cria_por_id FROM pess t0, empr_unid t2, pess_cada t1 WHERE ((t2.id = ?) AND (((t2.pess_id = t0.pess_id) AND ((t1.pess_id = t0.pess_id) AND (t1.pess_id = t0.pess_id))) AND (t0.cadastro_tipo = ?)))
bind => [3, EmpresaUnidade]
Detalhado: SELECT 1
Advertência: Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.postgresql.util.PSQLException: ERROR: column t2.id does not exist
Posição: 459
Error Code: 0
Call: SELECT t0.pess_id, t0.cadastro_tipo, t0.alte_em, t0.alte_por_id, t0.anfi, t0.apel_nome_fant, t0.ativ, t0.cada_tipo, t0.clie, t0.cons_fat_min, t0.cria_em, t0.cria_por_id, t0.forn, t0.nasc_fund, t0.nome_raza_soci, t0.obs, t0.pess_tipo, t0.pess_grup_id, t1.pess_id, t1.alte_em, t1.alte_por_id, t1.cpf_cnpj, t1.cria_em, t1.cria_por_id, t1.rg_ie, t2.pess_id, t2.alte_em, t2.alte_por_id, t2.cria_em, t2.cria_por_id FROM pess t0, empr_unid t2, pess_cada t1 WHERE ((t2.id = ?) AND (((t2.pess_id = t0.pess_id) AND ((t1.pess_id = t0.pess_id) AND (t1.pess_id = t0.pess_id))) AND (t0.cadastro_tipo = ?)))
Query: ReadObjectQuery(name="empresaUnidadeParaCotacao" referenceClass=EmpresaUnidade sql="SELECT t0.pess_id, t0.cadastro_tipo, t0.alte_em, t0.alte_por_id, t0.anfi, t0.apel_nome_fant, t0.ativ, t0.cada_tipo, t0.clie, t0.cons_fat_min, t0.cria_em, t0.cria_por_id, t0.forn, t0.nasc_fund, t0.nome_raza_soci, t0.obs, t0.pess_tipo, t0.pess_grup_id, t1.pess_id, t1.alte_em, t1.alte_por_id, t1.cpf_cnpj, t1.cria_em, t1.cria_por_id, t1.rg_ie, t2.pess_id, t2.alte_em, t2.alte_por_id, t2.cria_em, t2.cria_por_id FROM pess t0, empr_unid t2, pess_cada t1 WHERE ((t2.id = ?) AND (((t2.pess_id = t0.pess_id) AND ((t1.pess_id = t0.pess_id) AND (t1.pess_id = t0.pess_id))) AND (t0.cadastro_tipo = ?)))")
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:340)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:679)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:558)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1995)
at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:570)
at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:248)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:242)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:228)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectOneRow(DatasourceCallQueryMechanism.java:714)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRowFromTable(ExpressionQueryMechanism.java:2777)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRow(ExpressionQueryMechanism.java:2730)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:526)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1155)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:899)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1114)
at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:429)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1202)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2894)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1797)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1779)
at org.eclipse.persistence.internal.indirection.NoIndirectionPolicy.valueFromQuery(NoIndirectionPolicy.java:326)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRowInternal(ForeignReferenceMapping.java:2234)
at org.eclipse.persistence.mappings.OneToOneMapping.valueFromRowInternal(OneToOneMapping.java:1790)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRow(ForeignReferenceMapping.java:2120)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.buildCloneFromRow(ForeignReferenceMapping.java:336)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildAttributesIntoWorkingCopyClone(ObjectBuilder.java:1811)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneFromRow(ObjectBuilder.java:1958)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:726)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:629)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:587)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:571)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:782)
at org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:848)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:490)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:402)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1744)
at org.eclipse.persistence.internal.jpa.QueryImpl.executeReadQuery(QueryImpl.java:258)
at org.eclipse.persistence.internal.jpa.QueryImpl.getResultList(QueryImpl.java:468)
at net.cartola.logic.CompraCotacaoLogic.list(CompraCotacaoLogic.java:99)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1081)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1153)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:4695)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:630)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:822)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:582)
at org.jboss.weld.ejb.AbstractEJBRequestScopeActivationInterceptor.aroundInvoke(AbstractEJBRequestScopeActivationInterceptor.java:46)
at sun.reflect.GeneratedMethodAccessor302.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:883)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doCall(SystemInterceptorProxy.java:163)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:140)
at sun.reflect.GeneratedMethodAccessor301.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:369)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:4667)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:4655)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:212)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:88)
at com.sun.proxy.$Proxy343.list(Unknown Source)
at net.cartola.wms.cotacao.CotacaoBean.listarTodasCotacoes(CotacaoBean.java:288)
at net.cartola.wms.cotacao.CotacaoBean.pesquisar(CotacaoBean.java:278)
at javax.el.ELUtil.invokeMethod(ELUtil.java:326)
at javax.el.BeanELResolver.invoke(BeanELResolver.java:536)
at javax.el.CompositeELResolver.invoke(CompositeELResolver.java:256)
at com.sun.el.parser.AstValue.invoke(AstValue.java:269)
at com.sun.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:304)
at com.sun.faces.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:105)
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:87)
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
at javax.faces.component.UICommand.broadcast(UICommand.java:315)
at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:790)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1282)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:81)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:198)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:646)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1682)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:344)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:214)
at org.netbeans.modules.web.monitor.server.MonitorFilter.doFilter(MonitorFilter.java:393)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:316)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:160)
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:734)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:673)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:99)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:174)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:357)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:260)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:188)
at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:191)
at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:168)
at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:189)
at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:288)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:206)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:136)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:114)
at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77)
at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:838)
at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:113)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:115)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:55)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:135)
at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:564)
at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:544)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.postgresql.util.PSQLException: ERROR: column t2.id does not exist
Posição: 459
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2284)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2003)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:200)
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:424)
at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:161)
at org.postgresql.jdbc.PgPreparedStatement.executeQuery(PgPreparedStatement.java:114)
at sun.reflect.GeneratedMethodAccessor280.invoke(Unknown Source)
at org.postgresql.ds.PGPooledConnection$StatementHandler.invoke(PGPooledConnection.java:426)
at com.sun.proxy.$Proxy337.executeQuery(Unknown Source)
at com.sun.gjc.spi.jdbc40.PreparedStatementWrapper40.executeQuery(PreparedStatementWrapper40.java:642)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeSelect(DatabaseAccessor.java:1002)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:641)
... 127 more
The files follow attached
| Re: Erro: Column name is being ignored [message #1751313 is a reply to message #1750931] |
Sat, 07 January 2017 15:39  |
This is a rather complex SQL statement with no context of the entity or JPA query that formed it. More information would help (the entities involved, the query etc) as would testing to see if this issue occurs on simpler queries involving the entity mapped to the empr_unid table.
Current Time: Thu Nov 06 09:44:06 EST 2025
Powered by FUDForum. Page generated in 0.07737 seconds
