Home » Language IDEs » C / C++ IDE (CDT) » Eclipse regex_match();
Eclipse regex_match(); [message #1751121] Wed, 04 January 2017 10:18 Go to next message
Hi, I'm trying to implement regex in my parser program when i used codeblocks all worked fine, on eclipse neon i have error Function 'regex_match' could not be resolved . I added flag to gcc c++ compiler settings -std=c++11 and checked CDT GCC Built-in compiler settings MiniGW.
How to make it work on eclipse ?
#include "ParserSip.h"
#include <regex> //its included ok
void checkIfCseq (SipMessage & pointer, string stringLine){
string stringToFind = ".*CSeq:.*";
regex_match(); // Function 'regex_match' could not be resolved
Re: Eclipse regex_match(); [message #1751284 is a reply to message #1751121] Fri, 06 January 2017 19:20 Go to previous messageGo to next message
after changing the c++ flags, can you try rebuilding the index:
1) Right-click on project
2) Select Index
3) Choose rebuild
Jonah
Re: Eclipse regex_match(); [message #1751292 is a reply to message #1751284] Sat, 07 January 2017 03:17 Go to previous message
There is no parameterless function std::regex_match() .
http://www.cplusplus.com/reference/regex/regex_match/
http://en.cppreference.com/w/cpp/regex/regex_match
#include <regex>
void Func () {
  std::string s("subject");
  std::regex e ("(sub)(.*)");
  std::regex_match();	                            // <--- ERROR: no such function
  if (std::regex_match (s,e))                       // <--- OK
      std::cout << "string object matched\n";
  if ( std::regex_match ( s.begin(), s.end(), e ) ) // <--- OK
      std::cout << "range matched\n";
You may still need to rebuild the index after including <regex> though.
[Updated on: Sat, 07 January 2017 03:33] by Moderator
Previous Topic:BUG Eclipse Neon
Next Topic:A default .gdbinit file for Eclipse CDT(neon)/MingW on Windows
Current Time: Sat Jul 19 01:08:33 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
