Home » Eclipse Projects » GEF » ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui
ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui [message #1751020] Tue, 03 January 2017 12:10 Go to next message
I had my profiling gef4/Zest based plugin running correctly, starting eclipse from eclipse, using vmarg -Dosgi.framework.extensions=org.eclipse.fx.osgi , and plugins org.eclipse.fx.javafx and org.eclipse.fx.osgi.
However, I also had a warning in the log file:
"WARNING: You are binding against the deprecated org.eclipse.fx.javafx - please remove all javafx imports"
So I try to be a good boy and follow the advice in:
https://www.eclipse.org/forums/index.php/t/1072815/
i.e., using vmarg -Dorg.osgi.framework.bundle.parent=ext instead, and removing org.eclipse.fx.javafx and org.eclipse.fx.osgi from required plugins, and remove javafx.* from imported packages.
However, I now get the following exception when opening the profiler perspective which opens a (subclass of) ZestFxUiView:
java.lang.ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui_1.0.1.201609060946
The whole horrendous stack trace is included below.
I notice that FXCanvas is in jre/lib/jfxswt.jar, but it is not a bundle. I'm currently using java-1.8.0-oracle-1.8.0.111.x86_64 (linux).
Help please
Thanks is advance
Thomas
!ENTRY org.eclipse.ui 4 4 2017-01-03 16:56:31.720
!MESSAGE Unable to create part
!SUBENTRY 1 org.eclipse.ui 4 1 2017-01-03 16:56:31.721
!MESSAGE Plug-in "com.yepp.cromo.eclipsedev.mylang.profiler" was unable to instantiate class "com.cromosystems.mylang.profiler.perspective.MylangProfilerView".
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.yepp.cromo.eclipsedev.mylang.profiler" was unable to instantiate class "com.cromosystems.mylang.profiler.perspective.MylangProfilerView".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:58)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:101)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1317)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5406)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:108)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:142)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:4091)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:3096)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:3041)
at com.yepp.cromo.sessionserver.SessionServerPlugin$5.run(SessionServerPlugin.java:412)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4528)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4146)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.NoClassDefFoundError: javafx/embed/swt/FXCanvas
at org.eclipse.gef4.mvc.fx.ui.MvcFxUiModule.bindFXCanvasFactory(MvcFxUiModule.java:46)
at org.eclipse.gef4.mvc.fx.ui.MvcFxUiModule.configure(MvcFxUiModule.java:90)
at com.google.inject.AbstractModule.configure(AbstractModule.java:59)
at com.google.inject.spi.Elements$RecordingBinder.install(Elements.java:223)
at com.google.inject.spi.Elements.getElements(Elements.java:101)
at com.google.inject.spi.Elements.getElements(Elements.java:92)
at com.google.inject.util.Modules$RealOverriddenModuleBuilder$1.configure(Modules.java:172)
at com.google.inject.internal.InjectorShell$Builder.build(InjectorShell.java:133)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:103)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at com.cromosystems.mylang.profiler.perspective.MylangProfilerView.<init>(MylangProfilerView.java:102)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 129 more
Caused by: java.lang.ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui_1.0.1.201609060946
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 151 more
!SUBENTRY 2 org.eclipse.equinox.registry 4 1 2017-01-03 16:56:31.723
!STACK 0
... 151 more
[Updated on: Tue, 03 January 2017 12:13] by Moderator
Re: ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui [message #1751070 is a reply to message #1751020] Wed, 04 January 2017 04:51 Go to previous messageGo to next message
It seems that the GEF adopter's guide at https://github.com/eclipse/gef/blob/master/README.md#run-the-examples contradicts https://www.eclipse.org/forums/index.php/t/1072815/ ...
Is it the case that GEF users should use -Dosgi.framework.extensions=org.eclipse.fx.osgi and simply learn to live with the deprecation warning in the log file?What do you GEF developers have to say about the deprecation warning
"WARNING: You are binding against the deprecated org.eclipse.fx.javafx - please remove all javafx imports" ?
[Updated on: Wed, 04 January 2017 04:53] by Moderator
Re: ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui [message #1751088 is a reply to message #1751070] Wed, 04 January 2017 06:56 Go to previous message
Hi Thomas,
the warning you are getting is an e(fx)clipse warning that asks you to remove the JavaFX package imports, which are no longer needed with java 8. Additionally, you should be able to remove org.eclipse.fx.javafx from your target. However, e(fx)clipse is still needed with Java 8 in order to bring the JavaFX/SWT integration onto the classpath. With Java 7, e(fx)clipse was needed to bring all of JavaFX onto the classpath. Using -Dosgi.framework.extensions=org.eclipse.fx.osgi is the way to go.
Matthias
Previous Topic:why is AbstractGeomerty not public?
Next Topic:Why MVC and MVC.FX bundles have been merged?
Current Time: Sun Jul 20 07:45:13 EDT 2025
Powered by FUDForum. Page generated in 0.07135 seconds
