Home » Newcomers » Newcomers » Eclipse Neon.2 - Team Synchronize - Not showing difference in files
Eclipse Neon.2 - Team Synchronize - Not showing difference in files [message #1750942] Mon, 02 January 2017 08:21 Go to next message
I installed Eclipse Neon.2 in OS Ubuntu 16.10 with openjdk version 1.8.0_111.
I added one line (--launcher.GTK_version 2) in eclipse.ini.
So I can good work with Eclipse PDT. My version control is Subversion.
But I have one problem.
If I change the perspective to "Team Synchronize". Then I see my changed files. If I click on a file. Then it open a new tab. But in this tab, I not see the differences between the local file and last version from Subversion. I see nothing.
In my old version Eclipse Mars.2 it works. I see the difference between this files.
But not in Eclipse Neon.2. What is my problem?
Re: Eclipse Neon.2 - Team Synchronize - Not showing difference in files [message #1750969 is a reply to message #1750942] Tue, 03 January 2017 03:42 Go to previous messageGo to next message
current PDT seems to be broken. you may switch to the nightly build version.
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=507821
Re: Eclipse Neon.2 - Team Synchronize - Not showing difference in files [message #1750975 is a reply to message #1750969] Tue, 03 January 2017 05:01 Go to previous message
Thank you for your tip. This was the solution for my problem.
Previous Topic:can I store two configuration based on OS type for a project in eclipse
Next Topic:VPAT for 508 Compliance
Current Time: Sun Jul 20 23:15:26 EDT 2025
Powered by FUDForum. Page generated in 0.34630 seconds
