Home » Archived » Eclipse Process Manager (Stardust) » JBoss AS 7.1 preconfigured deployment configuration(repository not authorised when running maven)
JBoss AS 7.1 preconfigured deployment configuration [message #1750748] Tue, 27 December 2016 20:56 Go to next message
I'm configuring stardust for JBoss deployment and the following command to generate the ipp war file.
mvn archetype:generate -DarchetypeGroupId=com.infinity.bpm.archetypes -DarchetypeArtifactId=ipp-archetype-jb71-ipp-portal-war -DarchetypeVersion=RELEASE -ssettings.xml -DarchetypeCatalog=file://archetype-catalog.xml -X -Dgoals=generate-resources
Attached is the logs, settings.xml, and downloaded catalog.xml files. Can anyone assist? thanks
Chris
  • Attachment: settings.xml
    (Size: 1.12KB, Downloaded 283 times)
  • Attachment: logs
    (Size: 35.18KB, Downloaded 160 times)
  • Attachment: archetype-catalog.xml
    (Size: 8.53KB, Downloaded 281 times)
Re: JBoss AS 7.1 preconfigured deployment configuration [message #1750756 is a reply to message #1750748] Wed, 28 December 2016 02:58 Go to previous messageGo to next message
Your setting.xml referring to infinty.sungard.com repository also this archetype does not look like standard Stardust.
<servers>
<server>
<id>ipp-libs</id>
<username>chris.suen@dss-asia.com</username>
<password>pass</password>
</server>
</servers>
<repositories>
<repository>
<id>ipp-libs</id>
<url>https://infinity.sungard.com/repository/ipp-libs/</url>
</repository>
Tanmoy Roy
Re: JBoss AS 7.1 preconfigured deployment configuration [message #1751150 is a reply to message #1750756] Wed, 04 January 2017 22:53 Go to previous message
hi Roy
That is what i got from the eclipse online help. Can you provide the correct setting.xml that i should be using to get the Jboss 7.1 archetype ?
thanks
Previous Topic:participant manager empty tab
Next Topic:No consumer available exception
Current Time: Sun Jul 20 20:54:12 EDT 2025
Powered by FUDForum. Page generated in 0.25254 seconds
