Home » Modeling » TMF (Xtext) » XTend code generation and comments
XTend code generation and comments [message #1750734] Tue, 27 December 2016 11:29 Go to next message
I noticed that the XTend infrastructure does not copy all comments over to the generated java file. Comments of the form "/*...*/" are copied but not comments of the form "//...".
Can I turn it on?
Is it implemented at all?
Re: XTend code generation and comments [message #1750735 is a reply to message #1750734] Tue, 27 December 2016 11:31 Go to previous messageGo to next message
No you can't
The copying is done manually in the xtend impl
Re: XTend code generation and comments [message #1750736 is a reply to message #1750735] Tue, 27 December 2016 11:41 Go to previous messageGo to next message
Actually comments are not always copied.
For example the xtend code below:
package flax.sandbox
/* comment 1 */
class Test {
    /* comment 2 */
    def void doSomething(String /* comment3 */ myParameter) {
        /* comment 4*/
is transformed into:
package flax.sandbox;
 * comment 1
@SuppressWarnings("all")
public class Test {
   * comment 2
  public void doSomething(final String myParameter) {
This would be handy for IDE that parses stuff from comments (i.e IntelliJ IDEA todo feature).
Is that worth a feature request?
Re: XTend code generation and comments [message #1750737 is a reply to message #1750736] Tue, 27 December 2016 11:59 Go to previous messageGo to next message
yes but xtext handles this (TODO/TASK Markers) stuff on the source base, not on the generated java base.
i dont know what is implemented in the xtext idea code base (there is no maintainer on it right now)
Re: XTend code generation and comments [message #1750739 is a reply to message #1750737] Tue, 27 December 2016 12:17 Go to previous messageGo to next message
Apparenty nothing has been implemented yet with regards to TODO.
I am seriously considering contributing to the idea code base because there are many issues that need to get solved.
Who should I contact for that?
Re: XTend code generation and comments [message #1750740 is a reply to message #1750739] Tue, 27 December 2016 12:21 Go to previous messageGo to next message
id write to the xtext-dev mailing list https://dev.eclipse.org/mailman/listinfo/xtext-dev
Re: XTend code generation and comments [message #1836433 is a reply to message #1750735] Mon, 04 January 2021 05:04 Go to previous messageGo to next message
Hi, Is this implemented yet to convert all the comments from xtend to Java including // comments ? Thanks
Re: XTend code generation and comments [message #1836454 is a reply to message #1836433] Mon, 04 January 2021 12:24 Go to previous messageGo to next message
no, xtend handles no // comments
Re: XTend code generation and comments [message #1836650 is a reply to message #1750735] Mon, 11 January 2021 04:53 Go to previous messageGo to next message
Hi. Additionally another question related to below code.
/* comment 1 */
class Test {
/* comment 2 */
/* comment 4*/
Can we now convert all the block comments above from xtend to java or still comment 1 and comment 2 only converted yet ? Thanks in advance.
Re: XTend code generation and comments [message #1836651 is a reply to message #1836650] Mon, 11 January 2021 06:11 Go to previous message
only method and class and field comments
Previous Topic:Xtend Maven issues after upgrading to Java 9
Next Topic:Why add a pair of brackets will lead to Cannot invoke...EClassifierInfo.getEClassifier()?
Current Time: Thu Jul 24 22:56:38 EDT 2025
Powered by FUDForum. Page generated in 0.32021 seconds
