Home » Eclipse Projects » EGit / JGit » Label decorations
Label decorations [message #1750662] Sat, 24 December 2016 04:55 Go to next message
I don't like the git label decoration in the package explorer.
So i deactivated it in preferences
General -> Apperance -> Label Decorations : uncheck Git
But when i do
1. restart Eclipse
2. switch to Git perspective,
3. do some Git actions, e.g. commit/push,
4. switch back to plugin dev perspective
Now the label decorations are re-enabled again.
Can someone confirm this behavior? Is it a bug?
Frank
Re: Label decorations [message #1750665 is a reply to message #1750662] Sat, 24 December 2016 05:38 Go to previous messageGo to next message
If you disable the preference and then restart and look at the preference again, does it change state? If so, you haven't previously used Oomph's preference recorder to always set it to true have you? If you never want this enabled, you could enable the preference recorder (the toolbar button next to the "?" help button in the preference dialog) and change it and record it so it's always disabled. If the state didn't change just on restart, it would be good to know which specific activity causes the preference itself to change state.
Re: Label decorations [message #1750667 is a reply to message #1750665] Sat, 24 December 2016 05:49 Go to previous message
Hello Ed,
The recorder was grayed.
Now I enabled it.
This seems to help.
Thanks for this hint.
Frank
Previous Topic:new Mercurial client?
Next Topic:Activating modular target fails when installing with automated developer setup
Current Time: Sat Jul 19 00:53:53 EDT 2025
Powered by FUDForum. Page generated in 0.03342 seconds
