Re: Titan eclipse compilation issues [message #1750291 is a reply to message #1750097] |
Mon, 19 December 2016 11:15  |
Hi Siddharth,
thank you for your interest in Titan.
I suggest we go step by step. It would be good if you could send me the package you are trying to compile so I can follow exactly what you are doing.
Please also check in this forum the postings by Murli Sharma, he is also working with 3GPP specs, and so far we managed to solve his problems.
I see two categories of errors : related to omit and related to encoding.
Please edit your Makefile so you have the below compiler flags:
# Flags for the TTCN-3 and ASN.1 compiler:
COMPILER_FLAGS = -L -R -d
-d will tell the compiler to treat default fields as omit. This should get rid of most of your "omit" related errors.
Please also let me know which compiler version you have; "compiler -v" will tell you this.
Best regards
Elemer
FUDForum. Page generated in 0.03511 seconds
