Issue during Eclipse workspace setup [message #1750215] |
Sun, 18 December 2016 14:37  |
I'm trying to setup the Eclipse workspace for XText.
I'm following the instructions at:
https://github.com/eclipse/xtext/blob/master/CONTRIBUTING.md#set-up-your-eclipse-workspace
Everything goes well until the xtext-umbrella repository is cloned:
Performing Git Clone git@github.com:eclipse/xtext-umbrella.git (master)
Cloning Git repo git@github.com:eclipse/xtext-umbrella.git to C:\Users\Eric\xtext-master\git\xtext-umbrella
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/xtext-umbrella.git: Auth fail
I'm pretty sure I entered my credentials correctly (User ID have numbers only) and am wondering what I am doing wrong. Down the error message, it seems that oomph tries to clone over git-ssh, and I get confused as to what I should try next.
How are you guys setting the Eclipse workspace?
Btw I'm on Windows 64-bit.
[Updated on: Sun, 18 December 2016 14:38] by Moderator
Re: Issue during Eclipse workspace setup [message #1753637 is a reply to message #1753633] |
Wed, 08 February 2017 06:20   |
The real issues are (or may be) probably:
!MESSAGE Project org.eclipse.xtext.license.feature exists in different location: /home/ddziuda/eclipse/xtext-master/git/xtext-umbrella/releng/org.eclipse.xtext.license.feature
!MESSAGE Problem parsing archive:file:/!/home/ddziuda/eclipse/xtext-master/git/xtext-xtend/org.eclipse.xtend.maven.android.archetype/src/main/resources/archetype-resources/.project
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtend:org.eclipse.xtend.core:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtext:org.eclipse.xtext.xbase.lib:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtext:org.eclipse.xtext.util:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtext:org.eclipse.xtext.smap:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtend:org.eclipse.xtend.lib:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE Done
!STACK 0
org.xml.sax.SAXException: Done
at org.eclipse.emf.ecore.plugin.EcorePlugin$1Handler.startElement(EcorePlugin.java:383)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl$NSContentDispatcher.scanRootElementHook(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformPluginToPlatformResourceMap(EcorePlugin.java:460)
at org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformURIMap(EcorePlugin.java:571)
at org.eclipse.xtext.ui.resource.JavaProjectResourceSetInitializer.computePlatformURIMap(JavaProjectResourceSetInitializer.java:60)
at org.eclipse.xtext.ui.resource.JavaProjectResourceSetInitializer.initialize(JavaProjectResourceSetInitializer.java:50)
at org.eclipse.xtext.ui.resource.XtextResourceSetProvider.get(XtextResourceSetProvider.java:51)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:284)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:319)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:155)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:360)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:383)
at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:487)
at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:399)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$4.run(SetupTaskPerformer.java:3350)
But github authentication succeeded so I don't know what causes it.
Any hints?
FUDForum. Page generated in 0.05259 seconds
