Home » Modeling » TMF (Xtext) » Reference to files from plugins or projects
Reference to files from plugins or projects [message #1750170] Fri, 16 December 2016 11:39 Go to next message
Hello together,
i wrote a grammar to reference EObjects from other .ecore-Files. This works fine if i copy the file directly besides the .mydsl-file.
eobject=[ecore::EClass|FQN]
What i want is to reference to eobjects from .ecore-files from other projects or plugins. How can i achieve this?
Thank you for your time.
Greetings,
Simon
Re: Reference to files from plugins or projects [message #1750171 is a reply to message #1750170] Fri, 16 December 2016 11:41 Go to previous messageGo to next message
Simply put it on the classpath e.g. By turning your model project to a plugin project and add the library plugins to the dependencies in manifest
Re: Reference to files from plugins or projects [message #1750469 is a reply to message #1750171] Wed, 21 December 2016 06:26 Go to previous messageGo to next message
Hello Christian, thx for the advice.
Sadly it doesent work. I converted the project that contains my dsl-file to a plugin project and added another plugin that conaints an .ecore-file to the plugin dependencys. no difference
Re: Reference to files from plugins or projects [message #1750479 is a reply to message #1750469] Wed, 21 December 2016 09:18 Go to previous messageGo to next message
Does that other project have xtext Nature?
Can you share a complete reproducible example
Re: Reference to files from plugins or projects [message #1750482 is a reply to message #1750479] Wed, 21 December 2016 09:26 Go to previous messageGo to next message
As always your Questions are right on point. With the added XText-Nature it works with a project thats in my workspace.
however i need to use an .ecore-file thats packed in an eclipse-plugin. how can i add xtext nature to a plugin? Or is there another way?
Re: Reference to files from plugins or projects [message #1750483 is a reply to message #1750482] Wed, 21 December 2016 09:31 Go to previous messageGo to next message
Then you don't need. Simply add the dependency (and make sure it is really packaged (build.properties)
Re: Reference to files from plugins or projects [message #1750526 is a reply to message #1750483] Thu, 22 December 2016 03:08 Go to previous messageGo to next message
i can see the plugin that contains my .ecore-model under Plug-in Dependencies Entry and within the .ecore file. So i guess its packaged. (Selected under binary build, in Source build its unchecked). is that correct?
Re: Reference to files from plugins or projects [message #1750528 is a reply to message #1750526] Thu, 22 December 2016 04:30 Go to previous messageGo to next message
that looks legit,
if you have a look at the plugin in the "plugin dependencies" in the package explorer of the test.mydsl containing plugin project,
is the ecore file visible?
Re: Reference to files from plugins or projects [message #1750531 is a reply to message #1750528] Thu, 22 December 2016 04:39 Go to previous messageGo to next message
yes it is, right next to my plugin.xml etc.
http://i.imgur.com/B2gVA2C.png
[Updated on: Thu, 22 December 2016 04:57] by Moderator
Re: Reference to files from plugins or projects [message #1750533 is a reply to message #1750531] Thu, 22 December 2016 05:01 Go to previous messageGo to next message
the mydslfile needs to be inside a source folder afaik
Re: Reference to files from plugins or projects [message #1750534 is a reply to message #1750533] Thu, 22 December 2016 05:05 Go to previous messageGo to next message
That did the trick! So many small things. Thx again Christian!
Re: Reference to files from plugins or projects [message #1750543 is a reply to message #1750534] Thu, 22 December 2016 06:41 Go to previous messageGo to next message
One more Question: Why are the objects i get from the resource like this: platform:/resource/<project>/<path> and not platform:/plugin/<project>/<path> ? I get errors if i try to save it
Re: Reference to files from plugins or projects [message #1750544 is a reply to message #1750543] Thu, 22 December 2016 06:58 Go to previous messageGo to next message
which references?
Re: Reference to files from plugins or projects [message #1750545 is a reply to message #1750544] Thu, 22 December 2016 07:06 Go to previous messageGo to next message
from the Elements i get from the getScope-method.
i try to save the emf-model i get from the mydsl-editor into another emf-instance-model. and i always get the error Resource '/<project-name>' does not exist. Wich is true because the resource is a plugin and not a project that i have in my workspace.
Re: Reference to files from plugins or projects [message #1750547 is a reply to message #1750545] Thu, 22 December 2016 07:21 Go to previous message
sorry i have no idea on that.
Previous Topic:Simple question about the lexer
Next Topic:How to set the Java compliance level of the generated genmodel
Current Time: Mon Jul 21 05:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.06225 seconds
