Home » Modeling » Papyrus » More help on style sheets - sequence diagram fragments
More help on style sheets - sequence diagram fragments [message #1750122] Fri, 16 December 2016 04:45 Go to next message
Hello
I'm looking for a CSS parameter to make all fragments and operands in the sequence diagram white. Currently using below but I'm looking for a simpler command that covers all types of operand instead of having to list them one by one! Thanks!!
Interaction {fillColor:#FFFFFF;}
InteractionOperand {fillColor:#FFFFFF;}
CombinedFragment { fillColor:#FFFFFF;}
InteractionUse {fillColor:#FFFFFF;}
Re: More help on style sheets - sequence diagram fragments [message #1750128 is a reply to message #1750122] Fri, 16 December 2016 04:56 Go to previous messageGo to next message
Hi Richard,
Papyrus CSS doesn't support an inheritance mechanism, so you'll have to list all metaclasses. However, you can use a comma-separated list and write the style property only once:
Elt1, Elt2, Elt3 {
    fillColor: white;
HTH,
Camille
[Updated on: Fri, 16 December 2016 04:57] by Moderator
Re: More help on style sheets - sequence diagram fragments [message #1750136 is a reply to message #1750128] Fri, 16 December 2016 05:47 Go to previous messageGo to next message
Pay attention a lot of elements in the sequence diagram cannot be customized by CSS.
A big work is being done for oxygen in order to update this diagram.
Re: More help on style sheets - sequence diagram fragments [message #1750205 is a reply to message #1750136] Sat, 17 December 2016 22:00 Go to previous message
Thank you all! Elt1, Elt2, Elt3 will work for now!
Previous Topic: I can't sort UML elements by type in model explorer or tables!
Next Topic:Papyrus Designer update website certification error
Current Time: Sun Aug 31 06:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.03540 seconds
