Home » Modeling » Papyrus » open programmatically generated model by papyrus again
open programmatically generated model by papyrus again [message #1749157] Fri, 02 December 2016 07:45 Go to next message
i generate sequence diagram .uml and .notation files programmatically using emf and gmf. and the files is in correct syntax, i compared it with existed files. But when i try to open the generated model by papyrus by adding a default .di file, it doesn't open and i get a message "This diagram is contained in an unresolved resource : platform: files.notation". So is there anything missing i have to do to solve this error and be able to open the generated model by papyrus again ?
Re: open programmatically generated model by papyrus again [message #1749595 is a reply to message #1749157] Thu, 08 December 2016 08:28 Go to previous message
The message is basically saying that it does't find files.notation.
It's hard to say more without an example.
Can you share your generated files?
Benoit
Previous Topic:MARTE ClientServerPort in Papyrus
Next Topic:Create Papyrus diagram programmatically
Current Time: Sun Aug 31 14:04:34 EDT 2025
Powered by FUDForum. Page generated in 0.05097 seconds
