Home » Language IDEs » Java Development Tools (JDT) » Neon fails to install on Ubuntu 16.04
Neon fails to install on Ubuntu 16.04 [message #1749581] Thu, 08 December 2016 05:31 Go to next message
On my fresh install of Ubuntu 16.04 the java-neon installer fails with no specific message:
- in normal install mode the installation process starts, then the GUI comes back to the INSTALL button;
- in advanced mode, it ends with the message "Task execution was canceled. Press Back to choose different settings or Cancel to abort."
I have tried with both the openjdk8 and the Oracle jdk. I have also tried with and without the "Mirrors" option, following a comment on this forum. No success either. Everything else is set to the default values.
Here is the final screen provided by the installer ("Mirrors" unticked):
Executing bootstrap tasks
Renamed existing configuration folder to /home/prost/java-neon/eclipse/configuration.1481192795219
Java(TM) SE Runtime Environment 1.8.0_111-b14
Product org.eclipse.products.epp.package.java.neon
Bundle org.eclipse.oomph.setup 1.6.0.v20161125-0947, build=2765, branch=67300b4badfd07350c1a987bfbc2fafc3a4c0016
Bundle org.eclipse.oomph.setup.core 1.6.0.v20161128-0928, build=2765, branch=67300b4badfd07350c1a987bfbc2fafc3a4c0016
Bundle org.eclipse.oomph.setup.installer 1.6.0.v20161114-1007, build=2765, branch=67300b4badfd07350c1a987bfbc2fafc3a4c0016
Bundle org.eclipse.oomph.setup.p2 1.6.0.v20161019-0656, build=2765, branch=67300b4badfd07350c1a987bfbc2fafc3a4c0016
Performing P2 Director (Eclipse IDE for Java Developers (Neon))
Offline = false
Mirrors = false
Resolving 23 requirements from 3 repositories to /home/prost/java-neon/eclipse
Requirement epp.package.java [4.6.0,4.7.0)
Requirement org.eclipse.platform.feature.group [4.6.0,4.7.0)
Requirement org.eclipse.rcp.feature.group [4.6.0,4.7.0)
Requirement org.eclipse.buildship.feature.group
Requirement org.eclipse.egit.feature.group
Requirement org.eclipse.egit.mylyn.feature.group
Requirement org.eclipse.jdt.feature.group
Requirement org.eclipse.jgit.feature.group
Requirement org.eclipse.m2e.feature.feature.group
Requirement org.eclipse.m2e.logback.feature.feature.group
Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
Requirement org.eclipse.mylyn.context_feature.feature.group
Requirement org.eclipse.mylyn.git.feature.group
Requirement org.eclipse.mylyn.hudson.feature.group
Requirement org.eclipse.mylyn.ide_feature.feature.group
Requirement org.eclipse.mylyn.java_feature.feature.group
Requirement org.eclipse.mylyn.wikitext_feature.feature.group
Requirement org.eclipse.mylyn_feature.feature.group
Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
Requirement org.eclipse.recommenders.rcp.feature.feature.group
Requirement org.eclipse.recommenders.snipmatch.rcp.feature.feature.group
Requirement org.eclipse.wst.xml_ui.feature.feature.group
Requirement org.eclipse.oomph.setup.feature.group
Repository http://download.eclipse.org/technology/epp/packages/neon
Repository http://download.eclipse.org/releases/neon/201610111000
Repository http://download.eclipse.org/oomph/updates/milestone/latest
Adding repository http://download.eclipse.org/releases/neon/201610111000
Adding repository http://download.eclipse.org/oomph/updates/milestone/latest
Fetching p2.index from http://download.eclipse.org/technology/epp/packages/neon/
Adding repository http://download.eclipse.org/technology/epp/packages/neon
Calculating requirements and dependencies.
Computing prerequisite plan
Collecting 1 artifacts from http://download.eclipse.org/technology/epp/packages/neon
Downloading epp.package.java.executable.gtk.linux.x86_64
Collected 1 artifacts for http://download.eclipse.org/technology/epp/packages/neon in 0.471s
Collecting 3 artifacts from http://download.eclipse.org/releases/neon/201610111000
Downloading org.eclipse.rcp_root
Downloading org.eclipse.platform_root
Downloading org.eclipse.platform.ide.executable.gtk.linux.x86_64
Collected 3 artifacts for http://download.eclipse.org/releases/neon/201610111000 in 0.437s
The engine operation was cancelled and the changes are being rolled back.
Took 5 seconds.
Any suggestion?
JPP
Re: Neon fails to install on Ubuntu 16.04 [message #1749624 is a reply to message #1749581] Thu, 08 December 2016 12:25 Go to previous messageGo to next message
You can ask the experts of the installer directly at https://www.eclipse.org/forums/index.php/f/287/
Re: Neon fails to install on Ubuntu 16.04 [message #1749653 is a reply to message #1749624] Fri, 09 December 2016 03:35 Go to previous messageGo to next message
Yes, you'd be better to post this on the Oomph forum.
Someone else complained about something with similar symptoms on the Oomph forum. Perhaps there's a clue (an exception stack trace) in the installer's error log. That should be in a *.log in the configuration folder of the installer. Does this also happen if you install into a new clean/empty folder?
Re: Neon fails to install on Ubuntu 16.04 [message #1749654 is a reply to message #1749653] Fri, 09 December 2016 03:48 Go to previous messageGo to next message
Someone opened this bug. https://bugs.eclipse.org/bugs/show_bug.cgi?id=508945 I can't reproduce it. I needs someone's installer log file.
Re: Neon fails to install on Ubuntu 16.04 [message #1749656 is a reply to message #1749653] Fri, 09 December 2016 03:58 Go to previous message
Ok, I will post it on the installer's forum.
All attempts were made on new folders.
As for the log file, its content is exactly the same as what I posted. It's the only file remaining after the crash, and it's located in eclipse/configuration/org.eclipse.oomph.setup/setup.log
I attach it here, just in case.
  • Attachment: setup.log
    (Size: 4.02KB, Downloaded 121 times)
Previous Topic:How to null annotate Collectors.joining?
Next Topic:jEdit/Eclipse Interface Tools
Current Time: Fri Jun 06 08:55:36 EDT 2025
Powered by FUDForum. Page generated in 0.64306 seconds
