Home » Modeling » Epsilon » Call EGL file from Java application
Call EGL file from Java application [message #1749525] Wed, 07 December 2016 13:18 Go to next message
I am trying to call my .egl file from a Java application. Is there any simple way to invoke the .egl from Java?. I'm trying something like this:
	EglModule module = new EglModule();
	module.parse(new File("modelToCode.egl").getAbsoluteFile());
        EglTemplateFactory factory = new EglTemplateFactory();
        File templateFile = new File("modelToCode.egl");
        EglTemplate template = factory.load(templateFile);
        module.execute(template);
I have tried the standalone example but it is not working.I have also seen other examples with a call like module.execute() without any parameters ...
I really appreciate any help you can provide.
Re: Call EGL file from Java application [message #1749540 is a reply to message #1749525] Wed, 07 December 2016 17:22 Go to previous messageGo to next message
The following should do the trick.
EglTemplateFactoryModuleAdapter module = new EglTemplateFactoryModuleAdapter(new EglTemplateFactory());
module.parse(new File("modelToCode.egl"));
System.out.println(module.execute());
If you wish to orchestrate more than one templates you may want to use EGX [1].
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/code-generation-tutorial-egl/
Re: Call EGL file from Java application [message #1749544 is a reply to message #1749540] Wed, 07 December 2016 19:41 Go to previous messageGo to next message
Hi Dimitris,
Thanks for your response, unfortunately it doesn't works.
The error is the next:
Exception in thread "main" Method 'generate' not found for: org.eclipse.epsilon.egl.EglTemplate@2d6e8792
at (....modelToCode.egl)
The modelToCode.egl code is the next:
var main: Template := TemplateFactory.load('main.egl');
main.generate('../gen/main.c');
Any suggestion?
Re: Call EGL file from Java application [message #1749547 is a reply to message #1749544] Wed, 07 December 2016 20:49 Go to previous messageGo to next message
Does switching
for
new EglTemplateFactoryModuleAdapter(new EglFileGeneratingTemplateFactory());
work?
Dimitris
[Updated on: Wed, 07 December 2016 20:50] by Moderator
Re: Call EGL file from Java application [message #1749574 is a reply to message #1749547] Thu, 08 December 2016 04:48 Go to previous messageGo to next message
No, it doesn't work
Exception in thread "main" Type 'Graph' not found
How can I add my model to the adapter?
Thanks again.
[Updated on: Thu, 08 December 2016 04:49] by Moderator
Re: Call EGL file from Java application [message #1749578 is a reply to message #1749574] Thu, 08 December 2016 05:09 Go to previous messageGo to next message
Hi Juan,
That's much better; now all the parsing stuff works. I'd suggest having a look at [1] to see how you can load models and make them available to Epsilon programs.
Dimitris
[1] https://git.eclipse.org/c/epsilon/org.eclipse.epsilon.git/plain/examples/org.eclipse.epsilon.examples.standalone/src/org/eclipse/epsilon/examples/standalone/
[Updated on: Thu, 08 December 2016 06:10] by Moderator
Re: Call EGL file from Java application [message #1749584 is a reply to message #1749578] Thu, 08 December 2016 06:10 Go to previous messageGo to next message
Thank you so much Dimitris it works perfectly Smile
Re: Call EGL file from Java application [message #1749585 is a reply to message #1749584] Thu, 08 December 2016 06:11 Go to previous message
Hi Juan,
Glad to hear that! Any other problems, give us a shout.
Dimitris
Previous Topic:Type casting in EOL?
Next Topic:help me for Learning
Current Time: Tue Aug 05 04:12:33 EDT 2025
Powered by FUDForum. Page generated in 0.04049 seconds
