Home » Eclipse Projects » NatTable » Mass update of Groupby table with Regular Expession is not working.
Mass update of Groupby table with Regular Expession is not working. [message #1749408] Tue, 06 December 2016 06:16 Go to next message
I'm creating a nattable with Filter, Groupby, Sorting feature, I'm applying the regular expression filter to a particular column. And I'm mass updating the properties for the same filter applied column. I'm getting error about 50% of the columns and remaining column is getting updated with new values.
Refer the code and error below
Error
Dez 06, 2016 11:55:05 AM org.eclipse.nebula.widgets.nattable.edit.command.UpdateDataCommandHandler doCommand
SEVERE: Failed to update value to: Groll
	at ca.odell.glazedlists.impl.adt.barcode2.FourColorTree.get(FourColorTree.java:169)
	at ca.odell.glazedlists.TreeList.getTreeNode(TreeList.java:302)
	at ca.odell.glazedlists.TreeList.get(TreeList.java:287)
	at org.eclipse.nebula.widgets.nattable.data.ListDataProvider.getDataValue(ListDataProvider.java:50)
	at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getDataValue(DataLayer.java:162)
	at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getDataValueByPosition(DataLayer.java:442)
	at org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByDataLayer.getDataValueByPosition(GroupByDataLayer.java:429)
	at org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByDataLayer.getDataValueByPosition(GroupByDataLayer.java:383)
	at org.eclipse.nebula.widgets.nattable.edit.command.UpdateDataCommandHandler.doCommand(UpdateDataCommandHandler.java:54)
	at org.eclipse.nebula.widgets.nattable.examples._400_Configuration._810_SortableGroupByFilterColumnGroupAndFreezeExample$BodyLayerStack$1.doCommand(_810_SortableGroupByFilterColumnGroupAndFreezeExample.java:583)
	at org.eclipse.nebula.widgets.nattable.edit.command.UpdateDataCommandHandler.doCommand(UpdateDataCommandHandler.java:1)
Source Code:
package org.eclipse.nebula.widgets.nattable.examples._400_Configuration;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Date;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import java.util.Properties;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.nebula.widgets.nattable.NatTable;
import org.eclipse.nebula.widgets.nattable.columnChooser.command.DisplayColumnChooserCommandHandler;
import org.eclipse.nebula.widgets.nattable.config.AbstractRegistryConfiguration;
import org.eclipse.nebula.widgets.nattable.config.CellConfigAttributes;
import org.eclipse.nebula.widgets.nattable.config.ConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.DefaultNatTableStyleConfiguration;
import org.eclipse.nebula.widgets.nattable.config.EditableRule;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.data.IColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.IDataProvider;
import org.eclipse.nebula.widgets.nattable.data.IRowDataProvider;
import org.eclipse.nebula.widgets.nattable.data.ReflectiveColumnPropertyAccessor;
import org.eclipse.nebula.widgets.nattable.data.convert.DefaultDoubleDisplayConverter;
import org.eclipse.nebula.widgets.nattable.dataset.person.Address;
import org.eclipse.nebula.widgets.nattable.dataset.person.ExtendedPersonWithAddress;
import org.eclipse.nebula.widgets.nattable.dataset.person.Person;
import org.eclipse.nebula.widgets.nattable.dataset.person.Person.Gender;
import org.eclipse.nebula.widgets.nattable.dataset.person.PersonService;
import org.eclipse.nebula.widgets.nattable.edit.EditConfigAttributes;
import org.eclipse.nebula.widgets.nattable.edit.command.UpdateDataCommand;
import org.eclipse.nebula.widgets.nattable.edit.command.UpdateDataCommandHandler;
import org.eclipse.nebula.widgets.nattable.examples.AbstractNatExample;
import org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsEventLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsSortModel;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.DefaultGlazedListsFilterStrategy;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByConfigAttributes;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByConfigLabelModifier;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByDataLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByHeaderLayer;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByHeaderMenuConfiguration;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.GroupByModel;
import org.eclipse.nebula.widgets.nattable.extension.glazedlists.groupBy.ModernGroupByThemeExtension;
import org.eclipse.nebula.widgets.nattable.filterrow.FilterRowDataLayer;
import org.eclipse.nebula.widgets.nattable.filterrow.FilterRowHeaderComposite;
import org.eclipse.nebula.widgets.nattable.filterrow.TextMatchingMode;
import org.eclipse.nebula.widgets.nattable.filterrow.config.FilterRowConfigAttributes;
import org.eclipse.nebula.widgets.nattable.freeze.CompositeFreezeLayer;
import org.eclipse.nebula.widgets.nattable.freeze.FreezeLayer;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultColumnHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultCornerDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DefaultSummaryRowHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.layer.ColumnHeaderLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.CornerLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultColumnHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.DefaultRowHeaderDataLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer;
import org.eclipse.nebula.widgets.nattable.grid.layer.RowHeaderLayer;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupExpandCollapseLayer;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupHeaderLayer;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupModel;
import org.eclipse.nebula.widgets.nattable.group.ColumnGroupReorderLayer;
import org.eclipse.nebula.widgets.nattable.hideshow.ColumnHideShowLayer;
import org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform;
import org.eclipse.nebula.widgets.nattable.layer.CompositeLayer;
import org.eclipse.nebula.widgets.nattable.layer.DataLayer;
import org.eclipse.nebula.widgets.nattable.layer.ILayer;
import org.eclipse.nebula.widgets.nattable.layer.LabelStack;
import org.eclipse.nebula.widgets.nattable.layer.cell.AbstractOverrider;
import org.eclipse.nebula.widgets.nattable.layer.cell.ColumnLabelAccumulator;
import org.eclipse.nebula.widgets.nattable.painter.NatTableBorderOverlayPainter;
import org.eclipse.nebula.widgets.nattable.painter.cell.CheckBoxPainter;
import org.eclipse.nebula.widgets.nattable.persistence.command.DisplayPersistenceDialogCommandHandler;
import org.eclipse.nebula.widgets.nattable.reorder.ColumnReorderLayer;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayer;
import org.eclipse.nebula.widgets.nattable.sort.SortHeaderLayer;
import org.eclipse.nebula.widgets.nattable.sort.config.SingleClickSortConfiguration;
import org.eclipse.nebula.widgets.nattable.style.CellStyleAttributes;
import org.eclipse.nebula.widgets.nattable.style.DisplayMode;
import org.eclipse.nebula.widgets.nattable.style.HorizontalAlignmentEnum;
import org.eclipse.nebula.widgets.nattable.style.IStyle;
import org.eclipse.nebula.widgets.nattable.style.Style;
import org.eclipse.nebula.widgets.nattable.style.theme.ModernNatTableThemeConfiguration;
import org.eclipse.nebula.widgets.nattable.style.theme.ThemeConfiguration;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummaryDisplayConverter;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummaryRowConfigAttributes;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummaryRowLayer;
import org.eclipse.nebula.widgets.nattable.summaryrow.SummationSummaryProvider;
import org.eclipse.nebula.widgets.nattable.tree.TreeLayer;
import org.eclipse.nebula.widgets.nattable.tree.command.TreeCollapseAllCommand;
import org.eclipse.nebula.widgets.nattable.tree.command.TreeExpandAllCommand;
import org.eclipse.nebula.widgets.nattable.ui.menu.AbstractHeaderMenuConfiguration;
import org.eclipse.nebula.widgets.nattable.ui.menu.PopupMenuBuilder;
import org.eclipse.nebula.widgets.nattable.util.GUIHelper;
import org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import ca.odell.glazedlists.EventList;
import ca.odell.glazedlists.FilterList;
import ca.odell.glazedlists.GlazedLists;
import ca.odell.glazedlists.SortedList;
import ca.odell.glazedlists.TransformedList;
 * Simple example showing how to add the group by feature to the layer
 * composition of a grid in conjunction with showing summary values of
 * groupings.
public class _810_SortableGroupByFilterColumnGroupAndFreezeExample extends AbstractNatExample {
    private static final String ROW_HEADER_SUMMARY_ROW = "rowHeaderSummaryRowLabel";
    private ColumnGroupModel columnGroupModel = new ColumnGroupModel();
    public static void main(String[] args) throws Exception {
        StandaloneNatExampleRunner.run(new _810_SortableGroupByFilterColumnGroupAndFreezeExample());
    public String getDescription() {
        return "This example shows the usage of the group by feature in conjunction with summary values of the groupings.";
    public Control createExampleControl(Composite parent) {
        Composite container = new Composite(parent, SWT.NONE);
        container.setLayout(new GridLayout());
        // create a new ConfigRegistry which will be needed for GlazedLists
        // handling
        final ConfigRegistry configRegistry = new ConfigRegistry();
        // property names of the ExtendedPersonWithAddress class
        final String[] propertyNames = { "firstName", "lastName", "age", "money",
                "married", "gender", "birthday" };
        // mapping from property to label, needed for column header labels
        Map propertyToLabelMap = new HashMap();
        propertyToLabelMap.put("firstName", "Firstname");
        propertyToLabelMap.put("lastName", "Lastname");
        propertyToLabelMap.put("age", "Age");
        propertyToLabelMap.put("money", "Money");
        propertyToLabelMap.put("married", "Married");
        propertyToLabelMap.put("gender", "Gender");
        propertyToLabelMap.put("birthday", "Birthday");
        final IColumnPropertyAccessor columnPropertyAccessor =
                new ReflectiveColumnPropertyAccessor(propertyNames);
        // to enable the group by summary feature, the GroupByDataLayer needs to
        // know the ConfigRegistry
        final BodyLayerStack bodyLayerStack =
                new BodyLayerStack(
                        PersonService.getExtendedPersonsWithAddress(100),
                        columnPropertyAccessor,
                        configRegistry);
        bodyLayerStack.getBodyDataLayer().setConfigLabelAccumulator(new ColumnLabelAccumulator());
        // build the column header layer
        IDataProvider columnHeaderDataProvider =
                new DefaultColumnHeaderDataProvider(propertyNames, propertyToLabelMap);
        DataLayer columnHeaderDataLayer =
                new DefaultColumnHeaderDataLayer(columnHeaderDataProvider);
        ColumnHeaderLayer columnHeaderLayer =
                new ColumnHeaderLayer(columnHeaderDataLayer, bodyLayerStack, bodyLayerStack.getSelectionLayer());
        // add sorting
        SortHeaderLayer sortHeaderLayer = new SortHeaderLayer(
                columnHeaderLayer,
                new GlazedListsSortModel(
                        bodyLayerStack.getSortedList(),
                        configRegistry,
                        columnHeaderDataLayer),
                false);
        // connect sortModel to GroupByDataLayer to support sorting by group by
        // summary values
        bodyLayerStack.getBodyDataLayer().initializeTreeComparator(
                sortHeaderLayer.getSortModel(),
                bodyLayerStack.getTreeLayer(),
                true);
        ColumnGroupHeaderLayer columnGroupHeaderLayer = new ColumnGroupHeaderLayer(
                sortHeaderLayer,
                bodyLayerStack.getSelectionLayer(),
                this.columnGroupModel);
        columnGroupHeaderLayer.setCalculateHeight(true);
        // add the filter row functionality
        final FilterRowHeaderComposite filterRowHeaderLayer =
                new FilterRowHeaderComposite(
                        new DefaultGlazedListsFilterStrategy(
                                bodyLayerStack.getFilterList(),
                                configRegistry),
                        columnGroupHeaderLayer,
                        columnHeaderDataLayer.getDataProvider(),
                        configRegistry);
        // Row header
        // Adding the specialized DefaultSummaryRowHeaderDataProvider to
        // indicate the summary row in the row header
        IDataProvider rowHeaderDataProvider =
                new DefaultSummaryRowHeaderDataProvider(bodyLayerStack.getBodyDataLayer().getDataProvider(), "\u2211");
        final DataLayer rowHeaderDataLayer =
                new DefaultRowHeaderDataLayer(rowHeaderDataProvider);
        // add a label to the row header summary row cell aswell, so it can be
        // styled differently too
        // in this case it will simply use the same styling as the summary row
        // in the body
        rowHeaderDataLayer.setConfigLabelAccumulator(new AbstractOverrider() {
            public void accumulateConfigLabels(LabelStack configLabels, int columnPosition, int rowPosition) {
                if ((rowPosition + 1) == rowHeaderDataLayer.getRowCount()) {
                    configLabels.addLabel(ROW_HEADER_SUMMARY_ROW);
                    configLabels.addLabel(SummaryRowLayer.DEFAULT_SUMMARY_ROW_CONFIG_LABEL);
        ILayer rowHeaderLayer =
                new RowHeaderLayer(rowHeaderDataLayer, bodyLayerStack, bodyLayerStack.getSelectionLayer());
        // build the corner layer
        IDataProvider cornerDataProvider =
                new DefaultCornerDataProvider(columnHeaderDataProvider, rowHeaderDataProvider);
        DataLayer cornerDataLayer =
                new DataLayer(cornerDataProvider);
        ILayer cornerLayer =
                new CornerLayer(cornerDataLayer, rowHeaderLayer, filterRowHeaderLayer);
        // build the grid layer
        GridLayer gridLayer = new GridLayer(bodyLayerStack, filterRowHeaderLayer, rowHeaderLayer, cornerLayer);
        // set the group by header on top of the grid
        CompositeLayer compositeGridLayer = new CompositeLayer(1, 2);
        final GroupByHeaderLayer groupByHeaderLayer = new GroupByHeaderLayer(
                bodyLayerStack.getGroupByModel(),
                gridLayer,
        compositeGridLayer.setChildLayer(GroupByHeaderLayer.GROUP_BY_REGION, groupByHeaderLayer, 0, 0);
        compositeGridLayer.setChildLayer("Grid", gridLayer, 0, 1);
        // turn the auto configuration off as we want to add our header menu
        // configuration
        final NatTable natTable = new NatTable(container, compositeGridLayer, false);
        // as the autoconfiguration of the NatTable is turned off, we have to
        // add the DefaultNatTableStyleConfiguration and the ConfigRegistry
        // manually
        natTable.setConfigRegistry(configRegistry);
        natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
        // add some additional styling
        natTable.addConfiguration(new AbstractRegistryConfiguration() {
            public void configureRegistry(IConfigRegistry configRegistry) {
                configRegistry.registerConfigAttribute(
                        CellConfigAttributes.CELL_PAINTER,
                        new CheckBoxPainter(), DisplayMode.NORMAL,
                        ColumnLabelAccumulator.COLUMN_LABEL_PREFIX + 4);
                        CellConfigAttributes.DISPLAY_CONVERTER,
                        new DefaultDoubleDisplayConverter(),
                        DisplayMode.NORMAL,
                        ColumnLabelAccumulator.COLUMN_LABEL_PREFIX + 3);
                        EditConfigAttributes.CELL_EDITABLE_RULE,
                        EditableRule.ALWAYS_EDITABLE);
            	 * This is added to include multiple word search operation for the free text filter.
            	 * @param configRegistry - config registry to update registry values.
            	 * @author Naveen.
                            FilterRowConfigAttributes.TEXT_DELIMITER, "&");
            		//Naveen 30-10-2016
            		// Regular expression applied for all the columns.
            		for (int i = 0; i < propertyNames.length; i++) {
            	                FilterRowConfigAttributes.TEXT_MATCHING_MODE,
            	                TextMatchingMode.REGULAR_EXPRESSION,
            	                DisplayMode.NORMAL,
            	                FilterRowDataLayer.FILTER_ROW_COLUMN_LABEL_PREFIX
            	                        + i);
        // add sorting configuration
        natTable.addConfiguration(new SingleClickSortConfiguration());
        // add group by summary configuration
                        GroupByConfigAttributes.GROUP_BY_CHILD_COUNT_PATTERN,
                        "[{0}] - ({1})");
                        GroupByConfigAttributes.GROUP_BY_HINT,
                        "Drag columns here");
                Style hintStyle = new Style();
                hintStyle.setAttributeValue(
                        CellStyleAttributes.FONT,
                        GUIHelper.getFont(new FontData("Arial", 10, SWT.ITALIC)));
                        GroupByConfigAttributes.GROUP_BY_HINT_STYLE,
                        hintStyle);
                        SummaryRowConfigAttributes.SUMMARY_PROVIDER,
                        new SummationSummaryProvider(bodyLayerStack.bodyDataProvider, false),
                        DisplayMode.NORMAL,
                        SummaryRowLayer.DEFAULT_SUMMARY_COLUMN_CONFIG_LABEL_PREFIX + 3);
                        new SummaryDisplayConverter(new DefaultDoubleDisplayConverter()),
                        DisplayMode.NORMAL,
                // the main styling of the summary row cell in the row header is
                // done via summary row default style, but we need to override
                // the alignment
                IStyle style = new Style();
                style.setAttributeValue(
                        CellStyleAttributes.HORIZONTAL_ALIGNMENT,
                        HorizontalAlignmentEnum.CENTER);
                        CellConfigAttributes.CELL_STYLE,
                        style,
                        DisplayMode.NORMAL, ROW_HEADER_SUMMARY_ROW);
                        style,
                        DisplayMode.SELECT, ROW_HEADER_SUMMARY_ROW);
        // add group by header configuration
        natTable.addConfiguration(new GroupByHeaderMenuConfiguration(natTable,
                groupByHeaderLayer));
        natTable.addConfiguration(new AbstractHeaderMenuConfiguration(natTable) {
            protected PopupMenuBuilder createColumnHeaderMenu(NatTable natTable) {
                return super.createColumnHeaderMenu(natTable)
                        .withHideColumnMenuItem().withShowAllColumnsMenuItem()
                        .withColumnChooserMenuItem()
                        .withCreateColumnGroupsMenuItem()
                        .withUngroupColumnsMenuItem()
                        .withAutoResizeSelectedColumnsMenuItem()
                        .withColumnRenameDialog().withClearAllFilters()
                        .withStateManagerMenuItemProvider();
            protected PopupMenuBuilder createCornerMenu(NatTable natTable) {
                return super.createCornerMenu(natTable)
        natTable.configure();
        natTable.registerCommandHandler(
                new DisplayPersistenceDialogCommandHandler(natTable));
        DisplayColumnChooserCommandHandler columnChooserCommandHandler =
                new DisplayColumnChooserCommandHandler(
                        bodyLayerStack.getColumnHideShowLayer(),
                        columnHeaderLayer,
                        null,
                        null);
        natTable.registerCommandHandler(columnChooserCommandHandler);
        GridDataFactory.fillDefaults().grab(true, true).applyTo(natTable);
        Composite buttonPanel = new Composite(container, SWT.NONE);
        buttonPanel.setLayout(new RowLayout());
        GridDataFactory.fillDefaults().grab(true, false).applyTo(buttonPanel);
        Button toggleHeaderButton = new Button(buttonPanel, SWT.PUSH);
        toggleHeaderButton.setText("Toggle Group By Header");
        toggleHeaderButton.addSelectionListener(new SelectionAdapter() {
            public void widgetSelected(SelectionEvent e) {
                groupByHeaderLayer.setVisible(!groupByHeaderLayer.isVisible());
        Button toggleFilterButton = new Button(buttonPanel, SWT.PUSH);
        toggleFilterButton.setText("Toggle Filter Row");
        toggleFilterButton.addSelectionListener(new SelectionAdapter() {
                filterRowHeaderLayer.setFilterRowVisible(!filterRowHeaderLayer.isFilterRowVisible());
        Button collapseAllButton = new Button(buttonPanel, SWT.PUSH);
        collapseAllButton.setText("Collapse All");
        collapseAllButton.addSelectionListener(new SelectionAdapter() {
                natTable.doCommand(new TreeCollapseAllCommand());
        Button expandAllButton = new Button(buttonPanel, SWT.PUSH);
        expandAllButton.setText("Expand All");
        expandAllButton.addSelectionListener(new SelectionAdapter() {
                natTable.doCommand(new TreeExpandAllCommand());
        // this button adds data to the grid
        // try to group by last name, sort by last name desc and then add
        // dynamic data for verification
        Button addDynamicDataButton = new Button(buttonPanel, SWT.PUSH);
        addDynamicDataButton.setText("Add Data");
        addDynamicDataButton.addSelectionListener(new SelectionAdapter() {
                Address address = new Address();
                address.setStreet("Some Street");
                address.setHousenumber(42);
                address.setPostalCode(12345);
                address.setCity("In the clouds");
                Person person = new Person(42, "Ralph", "Wiggum", Gender.MALE, false, new Date());
                ExtendedPersonWithAddress entry = new ExtendedPersonWithAddress(person, address,
                        "0000", "The little Ralphy", PersonService.createRandomMoneyAmount(),
                        new ArrayList(), new ArrayList());
                bodyLayerStack.getEventList().add(entry);
                person = new Person(42, "Clancy", "Wiggum", Gender.MALE, true, new Date());
                        "XXXL", "It is Chief Wiggum", PersonService.createRandomMoneyAmount(),
                person = new Person(42, "Sarah", "Wiggum", Gender.FEMALE, true, new Date());
                        "mommy", "Little Ralphy's mother", PersonService.createRandomMoneyAmount(),
        // add modern styling
        ThemeConfiguration theme = new ModernNatTableThemeConfiguration();
        theme.addThemeExtension(new ModernGroupByThemeExtension());
        natTable.setTheme(theme);
        // add a border on every side of the table
        natTable.addOverlayPainter(new NatTableBorderOverlayPainter());
        this.natTable = natTable;
        return container;
     * Always encapsulate the body layer stack in an AbstractLayerTransform to
     * ensure that the index transformations are performed in later commands.
     * @param
    class BodyLayerStack extends AbstractLayerTransform {
        private final EventList eventList;
        private final SortedList sortedList;
        private final FilterList filterList;
        private final IDataProvider bodyDataProvider;
        private final GroupByDataLayer bodyDataLayer;
        private final ColumnHideShowLayer columnHideShowLayer;
        private final SelectionLayer selectionLayer;
        private final TreeLayer treeLayer;
        private final GroupByModel groupByModel = new GroupByModel();
        public BodyLayerStack(List values,
                IColumnPropertyAccessor columnPropertyAccessor,
            // wrapping of the list to show into GlazedLists
            // see http://publicobject.com/glazedlists/ for further information
            this.eventList = GlazedLists.eventList(values);
            TransformedList rowObjectsGlazedList = GlazedLists.threadSafeList(this.eventList);
            // use the SortedList constructor with 'null' for the Comparator
            // because the Comparator
            // will be set by configuration
            this.sortedList = new SortedList(rowObjectsGlazedList, null);
            // wrap the SortedList with the FilterList
            this.filterList = new FilterList(this.sortedList);
            // Use the GroupByDataLayer instead of the default DataLayer
            this.bodyDataLayer = new GroupByDataLayer(
                    getGroupByModel(),
                    this.filterList,
                    configRegistry);
            // get the IDataProvider that was created by the GroupByDataLayer
            this.bodyDataProvider = this.bodyDataLayer.getDataProvider();
            // layer for event handling of GlazedLists and PropertyChanges
            GlazedListsEventLayer glazedListsEventLayer =
                    new GlazedListsEventLayer(this.bodyDataLayer, this.filterList);
            SummaryRowLayer summaryRowLayer =
                    new SummaryRowLayer(glazedListsEventLayer, configRegistry, false);
            ColumnReorderLayer columnReorderLayer =
                    new ColumnReorderLayer(summaryRowLayer);
            ColumnGroupReorderLayer columnGroupReorderLayer =
                    new ColumnGroupReorderLayer(
                            columnReorderLayer,
                            _810_SortableGroupByFilterColumnGroupAndFreezeExample.this.columnGroupModel);
            this.columnHideShowLayer =
                    new ColumnHideShowLayer(columnGroupReorderLayer);
            ColumnGroupExpandCollapseLayer columnGroupExpandCollapseLayer =
                    new ColumnGroupExpandCollapseLayer(
                            this.columnHideShowLayer,
            this.selectionLayer = new SelectionLayer(columnGroupExpandCollapseLayer);
            // add a tree layer to visualise the grouping
            this.treeLayer = new TreeLayer(this.selectionLayer, this.bodyDataLayer.getTreeRowModel());
            ViewportLayer viewportLayer = new ViewportLayer(this.treeLayer);
            // this will avoid tree specific rendering regarding alignment and
            // indentation in case no grouping is active
            viewportLayer.setConfigLabelAccumulator(new GroupByConfigLabelModifier(getGroupByModel()));
            FreezeLayer freezeLayer = new FreezeLayer(this.treeLayer);
            CompositeFreezeLayer compositeFreezeLayer =
                    new CompositeFreezeLayer(freezeLayer, viewportLayer, this.selectionLayer);
            setUnderlyingLayer(compositeFreezeLayer);
            // we register a custom UpdateDataCommandHandler that ensures to
            // update the tree structure
            this.bodyDataLayer.unregisterCommandHandler(UpdateDataCommand.class);
            this.bodyDataLayer.registerCommandHandler(new UpdateDataCommandHandler(this.bodyDataLayer) {
                @SuppressWarnings("unchecked")
                protected boolean doCommand(UpdateDataCommand command) {
                    if (super.doCommand(command)) {
                    	ExtendedPersonWithAddress o = (ExtendedPersonWithAddress) ((IRowDataProvider) BodyLayerStack.this.bodyDataProvider).getRowObject(command.getRowPosition());
                        int rowIndex = filterList.indexOf(o);
                        if (rowIndex >= 0) {
                        	filterList.set(rowIndex, o);
                        return true;
                    return false;
        public ColumnHideShowLayer getColumnHideShowLayer() {
            return this.columnHideShowLayer;
        public TreeLayer getTreeLayer() {
            return this.treeLayer;
        public SelectionLayer getSelectionLayer() {
            return this.selectionLayer;
        public EventList getEventList() {
            return this.eventList;
        public SortedList getSortedList() {
            return this.sortedList;
        public FilterList getFilterList() {
            return this.filterList;
        public IDataProvider getBodyDataProvider() {
            return this.bodyDataProvider;
        public GroupByDataLayer getBodyDataLayer() {
            return this.bodyDataLayer;
        public GroupByModel getGroupByModel() {
            return this.groupByModel;
    public static final String PROPERTIES_FILE = "myState.properties";
    public NatTable natTable;
    public void onStart() {
        Properties properties = new Properties();
        try {
            System.out.println("Loading NatTable state from " + PROPERTIES_FILE);
            properties.load(new FileInputStream(new File(PROPERTIES_FILE)));
            this.natTable.loadState("", properties);
        } catch (FileNotFoundException e) {
            // No file found, oh well, move along
            System.out.println(PROPERTIES_FILE + " not found, skipping load");
        } catch (IOException e) {
            throw new RuntimeException(e);
    public void onStop() {
        this.natTable.saveState("", properties);
        try {
            System.out.println("Saving NatTable state to " + PROPERTIES_FILE);
            properties.store(new FileOutputStream(new File(PROPERTIES_FILE)), "NatTable state");
        } catch (Exception e) {
Re: Mass update of Groupby table with Regular Expession is not working. [message #1749412 is a reply to message #1749408] Tue, 06 December 2016 08:08 Go to previous messageGo to next message
The issue here is the custom UpdateDataCommandHandler. It immediately updates the tree structure after a row object has changed. That way the row object is moved to another position in the FilterList and therefore consecutive UpdateCommands try to operate on a list that has a different state.
You have two options to solve this:
1. Don't use the custom UpdateDataCommandHandler. The result is that the row objects are not immediately moved to another node. So you will have all the "Charlas" entries below "Flanders" until you retrigger the groupBy operation.
2. Change the implementation to perform the tree update delayed. Currently there is no way to distinguish between a multi or a single update. So it needs to be something delayed to ensure you don't get concurrency issues
     class BodyLayerStack<T> extends AbstractLayerTransform {
        public BodyLayerStack(List<T> values,
                IColumnPropertyAccessor<T> columnPropertyAccessor,
                        if (BodyLayerStack.this.future != null) {
                            BodyLayerStack.this.future.cancel(true);
                        BodyLayerStack.this.future = BodyLayerStack.this.executor.schedule(new Runnable() {
                            public void run() {
                                BodyLayerStack.this.eventList.getReadWriteLock().writeLock().lock();
                                try {
                                    EventList<T> temp = GlazedLists.eventList(BodyLayerStack.this.eventList);
                                    BodyLayerStack.this.eventList.clear();
                                    BodyLayerStack.this.eventList.addAll(temp);
                                } finally {
                                    BodyLayerStack.this.eventList.getReadWriteLock().writeLock().unlock();
                                BodyLayerStack.this.future = null;
                        }, 100, TimeUnit.MILLISECONDS);
                        return true;
                    return false;
        public boolean doCommand(ILayerCommand command) {
            if (command instanceof DisposeResourcesCommand) {
                this.executor.shutdownNow();
            return super.doCommand(command);
Re: Mass update of Groupby table with Regular Expession is not working. [message #1749435 is a reply to message #1749412] Tue, 06 December 2016 12:34 Go to previous message
Thank you. Its working fine with option 2Quote:
For beginners,
ScheduledFuture<?> future = null;
private ScheduledExecutorService executor= Executors.newScheduledThreadPool(1);
Previous Topic:DragSupport and reorderDragMode Doesn't works together
Next Topic:programmatically calling keyEvents or other way for opening build in Dialogs
Current Time: Sat Jul 26 21:16:30 EDT 2025
Powered by FUDForum. Page generated in 0.04875 seconds
