Home » Eclipse Projects » Eclipse Scout » Fire property chane events when key is pressed?
Fire property chane events when key is pressed? [message #1749254] Sun, 04 December 2016 10:21 Go to next message
Hi there,
I'm wondering if there is some kind of property change listener, that gets fired when a key was pressed in a StringField?
Right now the registered property change listener on a StringField gets fired, when the StringField lost the focus.
In my use case, I want to start a query on typing and then populate the table page while the user types his query criteria.
Peter
[Updated on: Sun, 04 December 2016 10:22] by Moderator
Re: Fire property chane events when key is pressed? [message #1749258 is a reply to message #1749254] Sun, 04 December 2016 12:39 Go to previous messageGo to next message
Take a look at the methods getConfiguredUpdateDisplayTextOnModify(), setUpdateDisplayTextOnModify(boolean), isUpdateDisplayTextOnModify(). If you set this property to true, the model also gets notified while the user is editing the field.
Re: Fire property chane events when key is pressed? [message #1749274 is a reply to message #1749258] Mon, 05 December 2016 01:11 Go to previous message
perfect thanks!
It works Smile
[Updated on: Wed, 07 December 2016 04:35] by Moderator
Previous Topic:SmartField & ElasticSearch
Next Topic:Changelog for releases
Current Time: Mon Nov 03 08:04:11 EST 2025
Powered by FUDForum. Page generated in 0.04458 seconds
