Home » Eclipse Projects » Oomph » Can we use Oomph to share and enforce company code format?
Can we use Oomph to share and enforce company code format? [message #1749188] Fri, 02 December 2016 15:13 Go to next message
Hi all,
I am attempting to setup code formatting preferences for my company that are identical across all of our projects. Initially I looked at Workspace Mechanic and the Common Preferences plugin, but these seem to have died off after Oomph was introduced - presumably because Oomph does the same things better and offers additional capabilities?
Basically what we are trying to achieve is to define a global code format profile, and use a tool (like Oomph) to keep all of the developers' environments up to date with the central definition. This way a team lead can modify the central code format profile and the change will be pushed to every dev's eclipse the next time it starts up (or better yet at some polling interval).
Is this possible?
I tried to achieve this by creating my own product.setup file with all the plugins/repos we use. I was then trying to populate it with User Preferences by first recording preference changes into my workspace.setup file, and then copying those into the product.setup file. The problem I ran into with the formatter is that the only preference the Oomph recorder saved was the profile name that is selected. Is there a way to include the profile in the setup file as well?
I've seen comments on the forum and in blog articles about using project settings for formatter preferences, but we don't want to do that. We don't work on code external to our company, we always use the same formatter. We don't want to maintain multiple project.setup files every time a format setting changes.
My hope is that after defining a product.setup file with formatter and other preferences, I can host it at an HTTP url, and our developers can point the Eclipse installer at it to install the company flavor of Eclipse. If the installer is pointed at a URL for the product.setup file, does that mean that Eclipse will check this remote product.setup file each time it starts to see if it has changed and then update Eclipse accordingly?
I'm afraid I may be fundamentally misunderstanding Oomph's capabilities. Most of the blogs/docs are more interested in explaining how to roll up all your plugins in a distro, which is neat, but not our main requirement. I'm really hoping Oomph is able to facilitate team code formatting standards because it looks like a lot of thought and effort has gone into this tool, and it seems to be the future of Eclipse preference management.
Re: Can we use Oomph to share and enforce company code format? [message #1749215 is a reply to message #1749188] Sat, 03 December 2016 06:50 Go to previous messageGo to next message
Mike Muske wrote on Fri, 02 December 2016 15:13
Hi all,
I'd like to think that Oomph does this very well.
Is this possible?
Yes.
Yes. The recorder only detects things you change so if you didn't change the profile itself during the process, but only changes to active profile that was chosen, then only the latter is recorded.
Maintaining it in your own Product definition is definitely a way to achieve your goal.
Yes, exactly.
So it sounds like the only thing you've missed the recording of the profile itself. If I open a Setup Editor, and use the "Record Preferences" button, and go to the JDT formatter preferences to create a new profile and activate it, I get these recorded tasks:
<setup:CompoundTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    name="org.eclipse.jdt.ui">
  <setupTask
      xsi:type="setup:PreferenceTask"
      key="/instance/org.eclipse.jdt.ui/formatter_profile"
      value="_MyFormatter"/>
  <setupTask
      key="/instance/org.eclipse.jdt.ui/formatter_settings_version"
      value="12"/>
  <setupTask
      key="/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles"
      value="*** removed because it's very big ***"/>
</setup:CompoundTask>
Note that the setup editor also has a "Capture Preferences" toolbar button that lets you record the current state of any preference as a preference task, so you could find your org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles preference and capture it in your Product setup.
I've used this support in customer projects so this definitely all works. In this case I was captured in a Project setup, but the tasks are the same. Note that for this customer I also defined the profiles for source cleanup and editor save actions. The latter are cool because the files will be formatted when you save them, so they're always in the perfect state.
Re: Can we use Oomph to share and enforce company code format? [message #1749453 is a reply to message #1749215] Tue, 06 December 2016 18:15 Go to previous messageGo to next message
I cannot tell you how happy I am to hear that this is possible, thank you so much for your fast reply! Also, thank you for all your work in bringing this tool to the Eclipse community, I look forward to getting to know it better.
Re: Can we use Oomph to share and enforce company code format? [message #1749886 is a reply to message #1749453] Tue, 13 December 2016 09:21 Go to previous messageGo to next message
I basically want to provide the same thing. I wonder if there's a possibility to
a) Replace the entire eclipse products so that only the company products are available
b) Provide an installer which is preconfigured so that no manual step is needed to add the custom product (and project) setup
Thanks in advance
Re: Can we use Oomph to share and enforce company code format? [message #1749937 is a reply to message #1749886] Wed, 14 December 2016 02:22 Go to previous message
Yes, you can host your own Index as described in the authoring guide. Note that the latest version of Oomph has wizards to create all the needed resource types, i.e., the Index, Product and Project catalogs, and of course Product and Projects. Modifying the eclipse-inst.ini lets you specialize your installer. There are documented steps for how to recompose the Windows self-extracting executable.
Previous Topic:Uninstalling all JPA plugins from eclipse
Next Topic:Extending 'Eclipse IDE for Java EE Developers' brings in fewer features than expected
Current Time: Thu Nov 06 01:47:16 EST 2025
Powered by FUDForum. Page generated in 0.03944 seconds
