Home » Eclipse Projects » EclipseLink » right way to maintain bi-directional relationships
right way to maintain bi-directional relationships [message #1748941] Wed, 30 November 2016 04:56 Go to next message
Hi Team,
I need to know how to maintain bidirectional manyToOne and OneToOne in the right way , beacause i have some problem while delete or update entities
in my application .
Environment
Payara Version: 4.1.1.163
- Edition: Full
- JDK Version: 8 - Oracle
- Operating System: Linux
Framework
- jsf + primefaces
- eclipselink
Re: right way to maintain bi-directional relationships [message #1749092 is a reply to message #1748941] Thu, 01 December 2016 13:07 Go to previous messageGo to next message
Not sure I understand. When you make a change to one side, you must make the corresponding change to the other side and ensure both changes are picked up by the context -either by modifying managed entities or merging both changed detached instances back into the context. What exactly are you doing?
Re: right way to maintain bi-directional relationships [message #1749401 is a reply to message #1748941] Tue, 06 December 2016 04:49 Go to previous message
My question is : what is the best solution to maintain the relation ?
In my applications the users can change the associations through the interaction with the view (JSF framework) . I ensure the relation's maintenance
in the stateless EJB responsible for the management of transactions in the persistence context .
The hardest part is the update method because i change the state of three entities for each change of association :
1 - The relation owner entity
2 - The old inverse entity ( remove operation on the oneToMany list )
3 - The new inverse entity ( add operation on the oneToMany list )
Previous Topic:How to get Eclipselink to fire JSR303 constraints in mapped super class?
Next Topic:EclipseLink - @OneToOne mapping does not update MongoDB(NoSQL)
Current Time: Thu Nov 06 09:41:09 EST 2025
Powered by FUDForum. Page generated in 0.03758 seconds
