Home » Eclipse Projects » Eclipse Scout » DataSourceCredentialVerifier
DataSourceCredentialVerifier [message #1739349] Sat, 30 July 2016 07:08 Go to next message
I'm using the NEON R release (on linux mint, using OpenJDK and postgresql fyi), and as far as I can tell, there's no database authentication mechanism provided out-of-the-box as was in previous version (a la DataSourceSecurityFilter). So I rolled up my sleeves and wrote one.
As can be expected, I duplicated the ConfigFileCredentialVerifier. What surprised me though was that the verification is done on the 'client' side, not in the server. Because of that, I had to add postgresql driver maven dependencies to the client, which somehow sits with me a bit wrong. I got it working, but is necessary to do that? I remember seeing this behaviour in earlier versions in the RAP client.
Also, it strikes me as a kind of core piece of functionality. I presume you (at BSI) already have already written something to this effect. If so, is it scheduled for a future release?
In the mean time, here's what I did. It seems to work (for me), but please scrutinize if I can improve anything.
@Bean
public class DataSourceCredentialVerifier implements ICredentialVerifier {
	private static final String SELECT_USER_SQL = ""
			+ "SELECT pw_hash, pw_salt"
			+ "  FROM users "
			+ " WHERE username = ? "
			+ "   AND (blocked IS NULL OR blocked = false) "
			+ "   AND (failed_login_attempts < ? OR id = 1) ";
	private static final String UPDATE_RETRY_COUNT_SQL = ""
			+ "UPDATE users "
			+ "   SET failed_login_attempts = COALESCE(failed_login_attempts, 0) + 1 "
			+ "   AND id != 1 ";
	private static final int DEFAULT_MAX_RETRIES = 5;
	private static Logger logger = LoggerFactory.getLogger(DataSourceCredentialVerifier.class);
	private String m_dbUrl;
	private String m_dbUsername;
	private String m_dbPassword;
	private Integer m_maxRetries;
	private Connection m_connection;
	@PostConstruct
	private void init() {
		m_dbUrl = BEANS.get(JdbcUrlProperty.class).getValue();
		m_dbUsername = BEANS.get(JdbcUsernameProperty.class).getValue();
		m_dbPassword = BEANS.get(JdbcPasswordProperty.class).getValue();
		m_maxRetries = BEANS.get(MaxRetriesProperty.class).getValue();
		try {
			m_connection = DriverManager.getConnection(m_dbUrl, m_dbUsername, m_dbPassword);
		} catch (SQLException e) {
			logger.error("Unable to connect to database", e);
	@PreDestroy
	private void destroy() {
		if (m_connection != null) {
			try {
				m_connection.close();
				// NOP
	public int verify(String username, char[] password) throws IOException {
		int result = AUTH_FORBIDDEN;
		try (PreparedStatement stmt = m_connection.prepareStatement(SELECT_USER_SQL)) {
			stmt.setString(1, username);
			stmt.setInt(2, m_maxRetries != null ? m_maxRetries.intValue() : DEFAULT_MAX_RETRIES);
			logger.debug("{}", stmt);
			stmt.execute();
			ResultSet rs = stmt.getResultSet();
			if (rs != null && rs.next()) {
				String pwHash = rs.getString(1);
				String pwSalt = rs.getString(2);
				if (!StringUtility.isNullOrEmpty(pwHash) && !StringUtility.isNullOrEmpty(pwSalt)) {
					byte[] hash = SecurityUtility.hash(Base64Utility.decode(
							String.valueOf(password)), Base64Utility.decode(pwSalt));
					if (Arrays.equals(hash, Base64Utility.decode(pwHash))) {
						result = AUTH_OK;
			logger.error("Unable to fetch authentication info from db", e);
			result = AUTH_FAILED;
		if (result == AUTH_FAILED && !StringUtility.isNullOrEmpty(username)) {
			// attempt to increment the failed retry count
			try (PreparedStatement stmt = m_connection.prepareStatement(UPDATE_RETRY_COUNT_SQL)) {
				int updates = stmt.executeUpdate();
				if (updates > 0) {
					logger.info("retry count for {} incremented. {} row updated.", username, updates);
				logger.warn("Unable to update retry count for user " + username, e);
		return result;
	public static class JdbcUrlProperty extends AbstractStringConfigProperty {
		public String getKey() {
			return "auth.jdbc.url";
	public static class JdbcUsernameProperty extends AbstractStringConfigProperty {
			return "auth.jdbc.user";
	public static class JdbcPasswordProperty extends AbstractStringConfigProperty {
			return "auth.jdbc.password";
	public static class MaxRetriesProperty extends AbstractPositiveIntegerConfigProperty {
			return "auth.maxretries";
		String username = "admin";
		String password = "manager";
		byte[] salt = SecurityUtility.createRandomBytes();
		byte[] hash = SecurityUtility.hash(Base64Utility.decode(password), salt);
		System.out.printf("The salt is: [%s]\n", Base64Utility.encode(salt));
		System.out.printf("The hash for %s/%s is: [%s]\n", username, password, Base64Utility.encode(hash));
Re: DataSourceCredentialVerifier [message #1742837 is a reply to message #1739349] Thu, 08 September 2016 02:19 Go to previous messageGo to next message
Thanks for sharing Marco.
Had the same issue, so I also wrote a CredentialVerifier.
I used server side services to verify the login against database - unfortunately this only worked in debug mode (HTTP 403 when client tries to call service in production mode).
Maybe there is a way to make a single service / method available also in production mode before auth? Would feel better Razz
Kevin
Re: DataSourceCredentialVerifier [message #1744191 is a reply to message #1742837] Fri, 23 September 2016 05:50 Go to previous messageGo to next message
hi Kevin,
for me is running somthing like this.
to Annotate the class with
@Order(value = 1000)
@RunWithRunContext()
in verify
Subject subject = new Subject();
    	subject.getPrincipals().add(new SimplePrincipal("system"));
    	subject.setReadOnly();
    	RunContext runContext = RunContexts.copyCurrent()
    	    .withSubject(subject)
    	    .withLocale(Locale.GERMAN);
    	ok = runContext.call(new ValidUserResult(username, password)
  public class ValidUserResult implements Callable<Boolean> {
    	String username;
    	char[] password;
    	public ValidUserResult(String username, char[] password) {
    		this.username = username;
    		this.password= password;
    	  public Boolean call() throws Exception {
    	    	boolean ok;
      		  ok = BEANS.get(IAdminUserService.class).isValidUser(username, password);
    	    return ok;
hope this can help.
Rüdiger
Re: DataSourceCredentialVerifier [message #1749076 is a reply to message #1739349] Thu, 01 December 2016 10:44 Go to previous messageGo to next message
I've posted a question regarding this topic here:
http://stackoverflow.com/questions/40914718/eclipse-scout-clean-database-authentication
I would appreciate answers here or at stackoverflow. As you wish.
Re: DataSourceCredentialVerifier [message #1749371 is a reply to message #1749076] Mon, 05 December 2016 17:23 Go to previous messageGo to next message
please let us know if the answer on stackoverflow did help you.
Re: DataSourceCredentialVerifier [message #1823427 is a reply to message #1749371] Thu, 26 March 2020 08:36 Go to previous message
Managed to solve it. Removed developmentAccessFilter and login form is working ...Thanks
Previous Topic:Two client apps +server app on single Tomcat
Next Topic:Error with Chart Fields
Current Time: Mon Jul 28 17:46:31 EDT 2025
Powered by FUDForum. Page generated in 0.03426 seconds
