| Re: Looking for example of "Post-build steps" [message #1749031 is a reply to message #1748997] |
Thu, 01 December 2016 05:16   |
Jonah Graham wrote on Wed, 30 November 2016 22:23If you want the assembly of each file, the easiest option may be to add "-save-temps" as an additional compiler flag. That will cause GCC to leave the .s file rather than delete it when done. It will also IIRC save the .i (pre-processed) source file too.
Also, if you edit your compile command to run too commands, make sure you join them together with && instead of ;. Otherwise if the first command fails and the second succeeds you won't get a build error, but you will have a broken build.
Thanks Jonah,
Yes, I want assembly for each file, but for the moment I search for a solution for single file. Concerning compiler flags. First I don's use GCC, but ARMCC. Second, I'm not sure if similar flag does exist for this compiler. And finally "Post-build" sounds as something that can be executed after build process ... to process in some way the files produced by build process. Isn't it ?
In other words "automate" the actions that could otherwise be done manually form the command line, i.e.:
- run compiler on .c file that produces object (.o) file
- run "fromelf" command on this .o file to produce assembly file
I believed that "Post-build" option serves for such kind of scenarios. Or I've been mistaken ? If my supposition is correct (i.e. "Post-build" can be used for scenarios as I presented above), probably it would be reasonably to search a solution how to properly integrate "fromelf" execution into "Post-build" Eclipse interface option rather than search for some compiler flag.
After all, could you, please, show me some example where "Post build" is used.
Thanks in advance.
FUDForum. Page generated in 0.10413 seconds
