Home » Eclipse Projects » OM2M » OM2M Subscription, H2 and MongoDB
OM2M Subscription, H2 and MongoDB [message #1748895] Tue, 29 November 2016 15:22 Go to next message
I developed OSGi bundle for MongoDB support. For passing data to new plugin i used embedded OM2M subscription.
I tested new plugin with 20.000 data (JMeter). After JMeter finished with sending data i checked how many data each database contains (H2 and MongoDB).
I found out that MongoDB contains all of the data but some of them are missing in H2. If i waited few more seconds (minutes), H2 got all of the missing data.
Does anyone knows why is that? It's possible that subscription thread starts(finish) faster or before thread, which is responsible for H2 data insert?
Thanks for your help.
Matej
Re: OM2M Subscription, H2 and MongoDB [message #1749216 is a reply to message #1748895] Sat, 03 December 2016 06:54 Go to previous messageGo to next message
Bump Smile
Re: OM2M Subscription, H2 and MongoDB [message #1749787 is a reply to message #1748895] Mon, 12 December 2016 04:57 Go to previous messageGo to next message
Hi Matej,
Actually the notification part is separated from the DB insertion in OM2M. The notifier is threaded and can send notifications in parallel. So I think it is due to H2 time to insert in the database while the notification is sent. Perhaps some improvement could be implemented to avoid the notification to be sent before the persistency is completely terminated.
Hope this helps,
Guillaume
Re: OM2M Subscription, H2 and MongoDB [message #1756166 is a reply to message #1749787] Mon, 13 March 2017 06:34 Go to previous messageGo to next message
I rewritted my plugin for new OM2M version and i noticed difference in DB commit and notify logic. In new OM2M version is DB commit executed before notification which is executed in new thread (ContentInstanceController.java). Is this right or am i missing something? Smile
Re: OM2M Subscription, H2 and MongoDB [message #1756233 is a reply to message #1756166] Tue, 14 March 2017 07:57 Go to previous message
Hello Matej,
You have it right, the transaction is committed right before sending the notification. Actually the notifier uses a different thread to send the notification while the response is sent to the originator of the request.
Previous Topic:Dynamically discovering and connecting remote CSEs and AEs.
Next Topic:Cannot access mn-cse resource from in-cse web interface
Current Time: Sun Jul 20 22:19:49 EDT 2025
Powered by FUDForum. Page generated in 0.06785 seconds
