Home » Eclipse Projects » Kura » Any recommened unit tests tools for Kura?
Any recommened unit tests tools for Kura? [message #1748387] Tue, 22 November 2016 11:44 Go to next message
How can I test my Kura bundle? modular tests and integration tests
In Java application I used to use Junit to test each class of my application. Can I use the same in kura bundle?
Or is there any recommeneded tools and approache?
Thanks!
Best,
Sabrina
Re: Any recommened unit tests tools for Kura? [message #1748412 is a reply to message #1748387] Tue, 22 November 2016 16:01 Go to previous messageGo to next message
Hi Sabrina,
JUnit works fine for testing OSGi bundles. Have a look at this setup [1] for how we test our new Apache Camel integration.
[1] https://github.com/eclipse/kura/tree/develop/kura/org.eclipse.kura.camel.test
--Dave
Re: Any recommened unit tests tools for Kura? [message #1748882 is a reply to message #1748412] Tue, 29 November 2016 12:25 Go to previous messageGo to next message
Thanks, this is for integration tests but what about unit tests?
Does it work if I do the same as a regular java application means that in the same bundle I will be having the two directories:
* src: for source
* test: for unit tests
Best,
Sabrina
Re: Any recommened unit tests tools for Kura? [message #1748896 is a reply to message #1748882] Tue, 29 November 2016 15:33 Go to previous message
Hi Sabrina,
Yes, that should all work exactly the same. If you have problems with it let me know.
--Dave
Previous Topic:Setting Up Kura and Wifi on RPi 3 Model B
Next Topic:kura log files
Current Time: Sat Nov 08 07:39:34 EST 2025
Powered by FUDForum. Page generated in 0.04593 seconds
