| Addictional Optional Argument Recognition [message #1748558] |
Thu, 24 November 2016 06:48  |
Hi guys, I have a problem:
This is my grammar
grammar it.unibo.FPML with org.eclipse.xtext.common.Terminals
generate fPML "..."
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
// Entry element
Model:
elements+=PureBlock
elements+=EffectFullBlock;
// Outer Blocks
PureBlock:
'Pure' '{'
elements+=DataBlock
elements+=PureFunctionBlock
PureFunctionBlock:
'Functions' '{'
(features+=PureFunctionDefinition)*
DataBlock:
'Data' '{'
(elements+=Data)*
value=ValueBlock
ValueBlock:
'Value' '{'
(elements+=Value)*
EffectFullBlock:
'Effects' '{'
(features+=EffectFullFunctionDefinition)*
main=MainFunc
// Outer Block Elements
Data:
name=ID ':' content=AdtType;
Value returns PureFunctionDefinition: {Value} name=ID ':' value=Expression;
AdtType:
ValueType
| '[' adtElement1=AdtType adtElement2=(SumType | ProdType) ']';
SumType:
'+' adtElement=AdtType;
ProdType:
'*' adtElement=AdtType;
'def' returnType=ValueType name=ID '(' args+=Argument ( ',' args+=Argument)? ')' ':' '{' functionBody=FunctionBodyPure '}';
EffectFullFunctionDefinition:
'def' returnType=IOType name=ID '(' args+=EffectFullArgument (',' args+=EffectFullArgument)? ')' ':' '{' functionBody=FunctionBodyEffectFull '}';
MainFunc:
'IO' returnType=UnitType 'main' ':' '{' functionBody=FunctionBodyEffectFull '}';
Function: EffectFullFunction | PureFunction;
PureFunction: PureFunctionDefinition | PrimitivePureFunction;
EffectFullFunction: EffectFullFunctionDefinition | PrimitiveEffectFullFunction;
// Function Body Elements
EffectFullReference: Function | EffectFullArgument;
PureReference: PureFunctionDefinition | Argument;
EffectFullArgument:
type=Type name=ID;
Argument: type=ValueType name=ID;
FunctionBodyPure:
EmptyFunctionBody | CompositionFunctionBodyPure;
FunctionBodyEffectFull:
EmptyFunctionBody | CompositionFunctionBodyEffect;
EmptyFunctionBody:
{EmptyFunctionBody} 'Undefined';
CompositionFunctionBodyPure:
referenceElement=[PureFunctionDefinition] (functionChain+=CompositionFunctionBodyPureFactor)+
| primitiveElement=PrimitivePureFunction (functionChain+=CompositionFunctionBodyPureFactor)+;
CompositionFunctionBodyPureFactor:
( '|>' (referenceElement=[PureFunctionDefinition]))
| ( '|>' (PrimitiveElement=PrimitivePureFunction));
CompositionFunctionBodyEffect:
referenceElement=[EffectFullReference] (functionChain+=CompositionFunctionBodyEffectFullFactor)+
| primitiveElement=(PrimitiveEffectFullFunction | PrimitivePureFunction) (functionChain+=CompositionFunctionBodyEffectFullFactor)+;
CompositionFunctionBodyEffectFullFactor:
( '>>=' (referenceElement=[EffectFullReference]))
| ( '>>=' (PrimitiveElement=(PrimitiveEffectFullFunction | PrimitivePureFunction)));
// Types
IOType:
'IO' type=Type ;
ValueType:
IntegerType | StringType | DataType | PureFunctionType;
Type:
ValueType | UnitType | EffectFullFunctionType;
IntegerType:
{IntegerType} type="int";
StringType:
{StringType} type="String";
UnitType:
{UnitType} type="Unit";
DataType:
{DataType} 'ref' type=[Data];
PureFunctionType:
{PureFunctionType} 'F' '<' argType=ValueType ',' returnType=ValueType '>';
EffectFullFunctionType:
{EffectFullFunctionType} 'FIO' '<' argType=IOType ',' returnType=IOType '>';
// Values
Expression:
IntValue | StringValue | DataValue | FunctionValue;
IntValue returns IntegerType: {IntegerType} value=INT;
StringValue returns StringType: {StringType} value=STRING;
FunctionValue returns PureFunctionType: value=PureLambda;
DataValue returns DataType: {DataValue} type=[Data]'(' value=AdtValue ')';
ValueRef: {ValueRef} value=[Value];
PureLambda returns PureFunctionDefinition:
{PureLambda} '(' arg=Argument ')' ':' functionBody=FunctionBodyPure
AdtValue:
IntValue
| StringValue
| ValueRef
| DataValue
| SumValue
| FunctionValue
| ProdValue;
ProdValue:
'(' prodAdtElement1=AdtValue ',' prodAdtElement2=AdtValue ')';
SumValue:
'Left' '(' sumAdtElement1=AdtValue ')'
| 'Right' '(' sumAdtElement2=AdtValue ')';
// Primitives
PrimitivePureFunction:
IntToString | IntPow | Plus | Minus | Times | Mod | ApplyF;
IntToString: {IntToString} 'IntToString';
IntPow: {IntPow} 'IntPow';
Plus: {Plus} '+';
Minus: {Minus} '-';
Times: {Times} '*';
Mod: {Mod} 'mod';
ApplyF:{ApplyF} 'applyF' functionType=PureFunctionType value=[PureReference];
PrimitiveEffectFullFunction:
PrimitivePrint | PrimitiveRandom | ApplyFIO;
PrimitivePrint:
{PrimitivePrint} "print";
PrimitiveRandom:
{PrimitiveRandom} "randomInt";
ApplyFIO: {ApplyFIO} 'applyFIO' functionType=EffectFullFunctionType value=[EffectFullReference];
All works fine, but this strange behaviour showed in the attach image.
As you can see, it seems that the second arguments aren't recognized by xtext and so I've problems in typechecking them and using them.
Sometimes when I run the eclipse runtime only the second argument ID is recognized, but the type still not be seen.
I simply can't figure out the cause of this behaviour.
Any suggestions??
Thanks in advance
| Re: Addictional Optional Argument Recognition [message #1748782 is a reply to message #1748779] |
Mon, 28 November 2016 10:21   |
AAA ok right...
here's my last example, a little bit complex but i will attach also an image that show where there're the missing parameters.
Where I use a single parameter all works fine.
Pure {
Data {
MyData: int
MyDataString: String
MyDataRef: ref MyData
MyDataProd: [int * int]
MyDataFunc: F<int, F<int,int> >
Value {
num2: 3
num: 2
randomMessage1: "This is the random generated: "
randomMessage2: "Result of the computation: "
DataProdValue: MyDataProd((2, 6))
Functions{
def F<int, int> a(int b, int c): { + |> applyF F<int, int> num |> * |> applyF F<int, int> c }
def ref MyData a1(F<int, int> b1): { Undefined }
def String a2(int b2): { IntPow |> IntToString}
def F<int,int> a3(int b3, int b4): { a |> applyF F<int,int> num2 |> IntPow |> - |> applyF F<int,int> b4 }
Effects {
Data {
MyDataIO: IO int
MyDataIOString: IO String
MyDataIOProd: [IO int + IO int]
MyDataIORef: IO refIO MyDataIO
MyDataIOFunc: IO FIO<int, IO String>
Value {
MyDataIOValue: MyDataIO(IO (4))
MyDataValue: randomInt >>= return int
MyDataFuncValue: MyDataIOFunc([int a] : a2 >>= return String)
Functions {
def IO FIO <String,IO int> printValueAndMassageAndPassValue(int g, String m): { IntToString >>= print >>= m >>= print >>= g }
def IO int d2(int e2): { e2 >>= + >>= applyF F<int,int> num }
def IO FIO<String, IO String> d(String e, String c): { print >>= c }
def IO String d1(String e1): { Undefined }
IO Unit main: { Undefined }
Anyway, for the updated grammar see here:
https://github.com/benkio/FPML/blob/master/fpml/src/it/unibo/FPML.xtext
Because the one of the starting message can be outdated.
Thanks again
FUDForum. Page generated in 0.04797 seconds
