Home » Language IDEs » ServerTools (WTP) » JSF - unknown tag
JSF - unknown tag [message #174739] Tue, 18 July 2006 03:38 Go to next message
Originally posted by: cap_nemesis.hotmail.com
When I display a jsp page with JSF in a "Java Project" the editor does not
recognize JSF tags, whereas opening the page in a "Dynamic Web Project"
renders the page without warnings.
So how can I enable JSF support in a normal java project?
Thx!
Re: JSF - unknown tag [message #174859 is a reply to message #174739] Wed, 19 July 2006 04:12 Go to previous messageGo to next message
you need JSF plugin, JSF libraries (1.1 only), and Dynamic Web Project
with JSF Facets
Marx
Re: JSF - unknown tag [message #175059 is a reply to message #174859] Wed, 19 July 2006 19:29 Go to previous messageGo to next message
"Marx" <marx@nospam_wasko.pl> schrieb im Newsbeitrag
news:e9kpgp$fm3$1@utils.eclipse.org...
> Markus K
Re: JSF - unknown tag [message #175074 is a reply to message #175059] Thu, 20 July 2006 02:01 Go to previous messageGo to next message
> So you mean it cannot be done, making a "NOT Dynamic Web Project" JSF-tag
> aware?
I think so
I had problems even in Dynamic project when something was misconfigured
Marx
Re: JSF - unknown tag [message #175105 is a reply to message #175074] Thu, 20 July 2006 05:49 Go to previous messageGo to next message
>> aware?
> I think so
> Marx
I guess I'll have to convert the project.
Thx for you time.
Markus
Re: JSF - unknown tag [message #175159 is a reply to message #175059] Thu, 20 July 2006 13:54 Go to previous messageGo to next message
"Markus K�������������������
Re: JSF - unknown tag [message #175217 is a reply to message #175159] Fri, 21 July 2006 05:40 Go to previous messageGo to next message
"Nitin Dahyabhai" <nitind@us.ibm.com> schrieb im Newsbeitrag
news:e9og0v$vse$1@utils.eclipse.org...
>>>> not recognize JSF tags, whereas opening the page in a "Dynamic Web
>>>> Project" renders the page without warnings.
> What exactly did you mean by "display", and which parts of JSF support
> were you looking for? A certain amount of it should always work, even in
> a Java project.
By "display" I mean opening a page in the editor.
I expected the editor to know about the JSF tags, so that it wouldn't
display the "unknow tag"-warnings and I would be able to use the
autocompletion feature for the tags.
All that is working at least in a dynamic web project.
Markus
Re: JSF - unknown tag [message #175275 is a reply to message #175217] Sun, 23 July 2006 05:28 Go to previous messageGo to next message
Re: JSF - unknown tag [message #175592 is a reply to message #175275] Thu, 27 July 2006 12:08 Go to previous messageGo to next message
news:e9vfgu$elm$1@utils.eclipse.org...
> Have you also placed the JSR tag library .jars into the project, set up
> the Java Build Path so that the Servlet APIs are available, and put the
> correct tag library directives into your .jsp file?
> - Nitin
I added all the libs of a standard dynamic web project via the build path,
but the tags are still not recognized.
The tag directives are ok.
What exactly do you mean by "placing" tag libs into the project?
Sry for the late reply (accident).
Markus
Re: JSF - unknown tag [message #175678 is a reply to message #175592] Fri, 28 July 2006 03:19 Go to previous messageGo to next message
Re: JSF - unknown tag [message #175687 is a reply to message #175678] Fri, 28 July 2006 06:07 Go to previous message
Markus K
Previous Topic:Creating Enterprise Application Project
Next Topic:Preset Dynamic web project with custom facet selected
Current Time: Mon Nov 03 08:54:45 EST 2025
Powered by FUDForum. Page generated in 0.49040 seconds
