Home » Modeling » Papyrus » MARTE ClientServerPort in Papyrus(Change the specification kind )
MARTE ClientServerPort in Papyrus [message #1748549] Thu, 24 November 2016 05:10 Go to next message
How to change ClientServerPort specification kind from Interface-Based (default setting) to feature-Based when the drop-down list is stamped.
  • Attachment: Capt.PNG
    (Size: 14.52KB, Downloaded 138 times)
Re: MARTE ClientServerPort in Papyrus [message #1749139 is a reply to message #1748549] Fri, 02 December 2016 04:11 Go to previous message
The leading "/" indicates that the interface-kind is a derived attribute, i.e. it is calculated from other values.
In case of the client-server port in MARTE, the calculation will set the specification kind automatically to feature-based, if the port does not have a UML type, but the MARTE featureSpec attribute is assigned.
Previous Topic:[EGit] Comparison problem with profiled model
Next Topic:open programmatically generated model by papyrus again
Current Time: Sun Nov 09 09:55:31 EST 2025
Powered by FUDForum. Page generated in 0.24012 seconds
