Home » Eclipse Projects » Eclipse 4 » Slow reaction of Eclipse Editors on a Windows VM(Eclipse Luna vs Eclipse Kepler performance of application)
Slow reaction of Eclipse Editors on a Windows VM [message #1748509] Wed, 23 November 2016 13:20 Go to next message
have an Eclipse application that uses all standard IEditor and Jface tables.
All development and testing is done on Windows 64 bit VM.
During the period that we used Kepler and Java 1.6 we did performance testing for the GUI and we had acceptable results.
Now that we switched to Luna and Java 1.8, the Eclipse application is extremely slower during some period of the day and just slower otherwise. "Slow" means I can see the editor clears the client area and draws the border and then draws the table. When closing the editor I can see the steps Jface is clearing the client area of the window (that may take several seconds) - Yes, that slow. Doing a right Click for a popup menu may take 3-10 seconds to come up and etc.
I did test other application like Notepad, Notepad++, VS2013 at the same time that Eclipse shows slowness, but those applications run fine.
My machine, which is a Windows 2008 R2 Terminal Server, has 24GB memory, 500GB hard drive and 8 CPUs.
I use Java 8, 64 bit, version 101, I'm attaching the eclipse.ini file.
As a side note, when I run the application on a laptop (or any stand alone Desktop), I do not see any performance issues.
Any ideas why Eclipse Luna will perform differently:
1. Using a VM
2. During different periods of the day
3. Why it will be slower then Kepler with Java 1.6
I'll appreciate any approach or direction to help my customers that have the same environment with the same issues. I'm been battling this for a year now.
Thanks Yigal
Re: Slow reaction of Eclipse Editors on a Windows VM [message #1748516 is a reply to message #1748509] Wed, 23 November 2016 16:40 Go to previous message
I would try to update to Neon or at least Mars to see if more current versions still show such an error.
Previous Topic:Enable File-->Save when view part is dirty
Next Topic:Problems running an RCP product which appears to have dependencies on batik.css 1.6 and 1.7
Current Time: Fri Jul 25 23:46:19 EDT 2025
Powered by FUDForum. Page generated in 0.04226 seconds
