Home » Eclipse Projects » EGit / JGit » Syntax coloring problem(Git 'Working directory' files have no syntax coloring)
Syntax coloring problem [message #666076] |
Mon, 18 April 2011 20:21  |
Files that I edit from the Git Repository view ('Working Directory') are not syntax-colored at all.
The only available option in the Git view is "Open in Text Editor", is this bypassing the content type eclipse preferences?
How might I regain syntax coloring without resorting to opening the file locally?
Thanks!!
Details:
Windows 7 x64
Version: Helios Service Release 2
Build id: 20110218-0911
PyDev for Eclipse 2.0.0.2011040403
Eclipse EGit (Incubation) 0.11.3
Full details:
*** Date: Monday, April 18, 2011 8:20:42 PM Eastern Daylight Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20110210-1200
eclipse.commands=-os
win32
-ws
win32
-arch
x86_64
-showsplash
C:\eclipse\\plugins\org.eclipse.platform_3.6.2.v201102101200 \splash.bmp
-launcher
C:\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32 .x86_64_1.1.2.R36x_v20101222\eclipse_1312.dll
-startup
C:\eclipse\\plugins/org.eclipse.equinox.launcher_1.1.1.R36x_ v20101122_1400.jar
-product
org.eclipse.epp.package.php.product
-showlocation
-vm
C:/Program Files/Java/jdk1.6.0_24/jre/bin/server/jvm.dll
eclipse.home.location=file:/C:/eclipse/
eclipse.launcher=C:\eclipse\eclipse.exe
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.php
eclipse.product=org.eclipse.epp.package.php.product
eclipse.startTime=1303143723309
eclipse.vm=C:/Program Files/Java/jdk1.6.0_24/jre/bin/server/jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms1024m
-Xmx1024m
-XX:PermSize=512m
-XX:MaxPermSize=512m
-Djava.class.path=C:\eclipse\\plugins/org.eclipse.equinox.la uncher_1.1.1.R36x_v20101122_1400.jar
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\\plugins/org.eclipse.equinox.laun cher_1.1.1.R36x_v20101122_1400.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jdk1.6.0_24\jre\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jdk1.6.0_24\jre\lib\ext;C:\Windows\Sun\Java\lib\e xt
java.home=C:\Program Files\Java\jdk1.6.0_24\jre
java.io.tmpdir=C:\Users\mike\AppData\Local\Temp\
java.library.path=C:\eclipse;.;C:\Windows\Sun\Java\bin;C:\Wi ndows\system32;C:\Windows;C:\PHP\;C:\Program Files (x86)\ATI Stream\bin\x86_64;C:\Program Files (x86)\ATI Stream\bin\x86;C:\Windows\system32;C:\Windows;C:\Windows\Sys tem32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Pr ogram Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Bitvise Tunnelier;C:\Program Files (x86)\Git\cmd
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_24-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_24
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=19.1-b02
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.equinox.launcher.splash.location=C:\eclipse\\plu gins\org.eclipse.platform_3.6.2.v201102101200\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86-64
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Windows 7
os.version=6.1
osgi.arch=x86_64
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.configuration.area=file:/C:/eclipse/configuration/
osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.6 .2.R36x_v20110210.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.6.2.R36x_v20110210
osgi.install.area=file:/C:/eclipse/
osgi.instance.area=file:/C:/Users/mike/workspaces/mailerd/
osgi.instance.area.default=file:/C:/Users/mike/workspace/
osgi.logfile=C:\Users\mike\workspaces\mailerd\.metadata\.log
osgi.manifest.cache=C:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=C:\eclipse\\plugins\org.eclipse.platform _3.6.2.v201102101200\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\plugins
osgi.tracefile=C:\Users\mike\workspaces\mailerd\.metadata\tr ace.log
osgi.ws=win32
path.separator=;
python.home=C:\eclipse\plugins\org.python.pydev.jython_2.0.0 .2011040403
python.path=C:\eclipse\plugins\org.python.pydev.jython_2.0.0 .2011040403\jysrc
python.security.respectJavaAccessibility=false
sun.arch.data.model=64
sun.boot.class.path=C:\Program Files\Java\jdk1.6.0_24\jre\lib\resources.jar;C:\Program Files\Java\jdk1.6.0_24\jre\lib\rt.jar;C:\Program Files\Java\jdk1.6.0_24\jre\lib\sunrsasign.jar;C:\Program Files\Java\jdk1.6.0_24\jre\lib\jsse.jar;C:\Program Files\Java\jdk1.6.0_24\jre\lib\jce.jar;C:\Program Files\Java\jdk1.6.0_24\jre\lib\charsets.jar;C:\Program Files\Java\jdk1.6.0_24\jre\lib\modules\jdk.boot.jar;C:\Progr am Files\Java\jdk1.6.0_24\jre\classes
sun.boot.library.path=C:\Program Files\Java\jdk1.6.0_24\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=amd64
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.net.client.defaultConnectTimeout=15000
sun.net.client.defaultReadTimeout=1000
sun.os.patch.level=Service Pack 1
user.country=US
user.dir=C:\eclipse
user.home=C:\Users\mike
user.language=en
user.name=mike
user.timezone=America/New_York
user.variant=
*** Features:
AnyEditTools (2.4.0.201101292156) "AnyEdit Tools"
ch.sahits.codegen.sql (2.1.0) "SQL Insert Script maker"
com.foosbar.mailsnag (0.4.7) "MailSnag"
com.quest.toad.cloud (1.2.0.201103080913) "Toad Eclipse for Cloud Databases"
de.anbos.eclipse.logviewer.feature (0.9.8.7) "Log Viewer"
Drupal_for_Eclipse_PDT (0.2.1.201001011121) "Drupal for Eclipse PDT"
FileSync (1.3.7.201103201622) "FileSync Plug-in"
net.sf.eclipsecs (5.3.0.201012121300) "Eclipse Checkstyle Plug-in"
org.eclipse.cdt (7.0.2.201102110609) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.build.crossgcc (1.0.0.201102110609) "CDT GCC Cross Compiler Support"
org.eclipse.cdt.bupc (1.0.3.201102110609) "Berkeley UPC Tool Chain"
org.eclipse.cdt.core.lrparser.feature (5.1.1.201102110609) "LR Parser Plug-in"
org.eclipse.cdt.core.parser.upc.feature (5.1.0.201102110609) "UPC Parser Plug-in"
org.eclipse.cdt.debug.edc (1.0.0.201102110609) "EDC Debug Plug-in"
org.eclipse.cdt.debug.gdbjtag (7.0.0.201102110609) "Eclipse GDB Hardware Debugging Plug-in"
org.eclipse.cdt.examples.dsf (2.1.0.201102110609) "Debugger Services Framework Examples"
org.eclipse.cdt.gdb (7.0.0.201102110609) "GDB Common"
org.eclipse.cdt.launch.remote (6.0.0.201102110609) "C/C++ Remote Debug Launcher"
org.eclipse.cdt.p2 (1.0.0.201102110609) "CDT P2 customizations for SDKs"
org.eclipse.cdt.sdk (7.0.2.201102110609) "Eclipse C/C++ Development Tools SDK"
org.eclipse.cdt.testing (7.0.0.201102110609) "Eclipse C/C++ Development Tools Testing Framework"
org.eclipse.cdt.util (5.1.0.201102110609) "Eclipse C/C++ Development Tools Utilities"
org.eclipse.cdt.xlc.feature (6.1.0.201102110609) "XL C/C++ Managed Build Core"
org.eclipse.cvs (1.2.1.r362_v20101111-7B77FKv99HL0GvIAF99I8H14B7E) "Eclipse CVS Client"
org.eclipse.datatools.common.doc.user (1.8.2.v201010181125-26-311A16321A3557) "Data Tools Platform User Documentation"
org.eclipse.datatools.connectivity.doc.user (1.8.2.v201010181125-37D-7733L3D753L7BBF) "Data Tools Platform Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature (1.8.2.v201010181125-7C7b8mEt1Zwkn9kfkUHHsoP_3to) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.core.feature (1.8.2.v201010181125-7B7C7ACcNBGLEOIeD_SO) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.8.2.v201010181125-4107w3121151A1A53) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.8.2.v201010181125-7H7C7CCcNBHEDPHcETPO) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.8.2.v201010181125-47C08w95ENAK6AFDFK7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.8.2.v201010181125-77778fBmKDNOMgJvJ8Of7QBR) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.8.2.v201010181125-7J8x7UBWwUN6z02z-fiI_w4x4uLf) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.8.2.v201010181125-67C2AqGBJVKbHlH1GU7QBR) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.8.2.v201010181125-7F47SFC7sRbrSZope9vW) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.8.2.v201010181125-540AkF78Y7VCOCQDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.8.2.v201010181125-4-29oB56N5N7L6PAQ) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.8.2.v201010181125-2-07w31211518181A) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.8.2.v201010181125-542AkF79P7QCP9SDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.8.2.v201010181125-546AkF78Y7R9PAX77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.8.2.v201010181125-3328s735357795A78) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.8.2.v201010181125-7A7T78DZRDKDFbGwFjNK) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.8.2.v201010181125-548dAkF79Q7RAN9UEE) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.8.2.v201010181125-542AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.8.2.v201010181125-540AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sdk.feature (1.8.2.v201010181125-7I977XFE9JfheEiJQF88iIv2_vUh) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.8.2.v201010181125-541AkF79P7N8NAQ77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.8.2.v201010181125-7E45F9NiNZVR6a1PMVn) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.intro (1.8.2.v201010181125-26-7w312116392911) "Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.8.2.v201010181125-77078CcNBGKBZI_FcRd) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sdk.feature (1.8.2.v201010181125-7P9j7eFEPPYjqNWgPz-1SsWN7dZo) "DTP SDK Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.8.2.v201010181125-7A-3F7RZHLz-Hz-OlPz0Qf) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.8.2.v201010181125-7N7y7JFDrhqbGIFUNhcFodMMD2J0) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.8.2.v201010181125-622BgJ9CR9XFcEWLP) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.datatools.sqltools.doc.user (1.8.2.v201010181125-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools User Documentation"
org.eclipse.dltk.core (2.0.0.v20100518-1923-7L-0EAAoOVMSUaEAZ8w_) "Eclipse Dynamic Languages Toolkit"
org.eclipse.dltk.core.index (2.0.0.v20100616-2015-6-19oA5855S5U27J_B) "Eclipse Dynamic Languages Toolkit Index"
org.eclipse.draw2d (3.6.2.v20110128-0100-4517w3122123901211) "Graphical Editing Framework Draw2d"
org.eclipse.egit (0.11.3) "Git Team Provider (Incubation)"
org.eclipse.egit.source (0.11.3) "Git Team Provider (Incubation)"
org.eclipse.emf (2.6.1.v20100914-1218) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.codegen (2.6.0.v20100914-1218) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.6.1.v20100914-1218) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100914-1218) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.6.0.v20100914-1218) "EMF Code Generation UI"
org.eclipse.emf.common (2.6.0.v20100914-1218) "EMF Common"
org.eclipse.emf.common.ui (2.6.0.v20100914-1218) "EMF Common UI"
org.eclipse.emf.converter (2.6.0.v20100914-1218) "EMF Model Converter"
org.eclipse.emf.databinding (1.2.0.v20100914-1218) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.2.0.v20100914-1218) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.6.1.v20100914-1218) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.6.0.v20100914-1218) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.6.0.v20100914-1218) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.6.0.v20100914-1218) "EMF Edit"
org.eclipse.emf.edit.ui (2.6.0.v20100914-1218) "EMF Edit UI"
org.eclipse.emf.mapping (2.6.0.v20100914-1218) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.6.0.v20100914-1218) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100914-1218) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.6.0.v20100914-1218) "EMF Mapping UI"
org.eclipse.epp.mpc (1.0.1.v20100826-2143) "EPP Marketplace Client"
org.eclipse.epp.package.php.feature (1.3.2.20110218-0812) "EPP PHP Bundle"
org.eclipse.gef (3.6.2.v20110128-0100-777B381A4Bz06565376E32322) "Graphical Editing Framework GEF"
org.eclipse.help (1.2.1.r362_v20101111-7e7jEVFDr6xg-LSlC_z0w1D) "Help System Base"
org.eclipse.jdt (3.6.2.r362_v20101117-0800-7z8XFW6FLFlmjJcvz03jyeFBLS_F) "Eclipse Java Development Tools"
org.eclipse.jgit (0.11.3) "JGit Core (Incubation)"
org.eclipse.linuxtools.man (0.0.1.201102241810) "Man viewer and service (Incubation)"
org.eclipse.mylyn_feature (3.4.3.v20110131-0100-e3x-7Z7f7AFBBoPbVQ7iNFebXJDypa) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.4.3.v20110131-0100-e3x-7D774BgJ9DI9YFV4CICE2KAv) "Mylyn"
org.eclipse.mylyn.context_feature (3.4.3.v20110131-0100-e3x-777728s73543D6D135332KAv) "Mylyn"
org.eclipse.mylyn.ide_feature (3.4.3.v20110131-0100-e3x-7G7J5BgJ9EC9QKN49E997JSm) "Mylyn"
org.eclipse.mylyn.team_feature (3.4.3.v20110131-0200-e3x-4327w31221242012110f4y) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.3.2.v20100916-0100-e3x-7F7e1FC7sReRSnX-DReRRMHHM) "Mylyn"
org.eclipse.pde (3.6.2.r362_v20110203-7b7mFL2FET3dhHalh1iNZtL) "PDE"
org.eclipse.php (2.2.1.v20101001-2300-7L7J1F8NcJTJTJJT9cmJJ) "PDT Plug-in"
org.eclipse.platform (3.6.2.r362_v20110210-9gF78Gs1FrIGnHDHWkEcopoN8AmxeZflGDGKQi ) "Eclipse Platform"
org.eclipse.rcp (3.6.2.r362_v20101104-9SAxFMKFkSAqi8axkv1ZjegmiBLY) "Eclipse RCP"
org.eclipse.rse (3.2.2.R32x_v201102130925-7L78FA58SreKCHr_JG7UA8bra19p) "Remote System Explorer End-User Runtime"
org.eclipse.rse.core (3.2.2.R32x_v201102011435-7a7FFMcF9hxfDPvGY6d8rTEETOY) "RSE Core"
org.eclipse.rse.dstore (3.2.2.R32x_v201102011435-7L77FDBD2YO5DwmNgNdOG98LBL) "RSE DStore Services"
org.eclipse.rse.examples (3.1.100.v201005032000-7B5-AkF77g7RFZFJ77) "Remote System Explorer Examples"
org.eclipse.rse.ftp (3.0.200.v201005221100-780Bg9oB56N5J9QBADD) "RSE FTP Service"
org.eclipse.rse.local (2.1.202.R32x_v201102011435-7B4F8QBCKC5H2XIVHMB922546) "RSE Local Services"
org.eclipse.rse.sdk (3.2.2.R32x_v201102130925-7U7EFA9Dc3j6z-rvb-L1tXd_cz-N) "Remote System Explorer Extender SDK"
org.eclipse.rse.ssh (3.0.100.v201005221100-7A2BhAkF77g7VEYDG7C) "RSE SSH Services"
org.eclipse.rse.telnet (2.2.100.v201005221100-7730AkF77g7UDXELEF) "RSE Telnet Service"
org.eclipse.rse.terminals (1.0.102.R32x_v201102011435-77-DI9uCFjNZVBGlDNC332423365) "RSE Terminals UI"
org.eclipse.rse.useractions (1.1.200.v201005221100-31A78s733L3D7H7933) "Remote System Explorer User Actions"
org.eclipse.tm.discovery (3.0.200.v201005032000-7d-FhJFEx2XZtYr4N3JXX) "Target Management Service Discovery Engine"
org.eclipse.tm.terminal (3.0.202.R32x_v201102011435-4-8a7S43yaw312213122546) "Target Management Terminal Widget"
org.eclipse.tm.terminal.local (0.1.0.v201006041240-10-7w312117152433) "Local Terminal (Incubation)"
org.eclipse.tm.terminal.serial (2.0.200.v201005032000-3-8Z7w311A16383411) "Target Management Terminal Serial Connector"
org.eclipse.tm.terminal.ssh (2.0.200.v201005271030-3-A77w312116382141) "Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.0.200.v201005032000-3-8_7w311A1A271116) "Target Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.1.2.R32x_v201102011435-3017S43yaw312213122546) "Target Management Terminal View"
org.eclipse.wst.common.fproj (3.2.3.v201101121727-377AC8s73543C6H4A5H) "Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.2.3.v201102160540-7C78FGUF9JgLWNO2UCNqfa) "Eclipse JavaScript Development Tools"
org.eclipse.wst.web_ui.feature (3.2.3.v201102160541-7O7CFbWEMf84qYjGDyP3DNEwcgFU) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.2.3.v201102160550-7H7AFUWDxumQJOi9ghcTb5YgkwEZ) "Eclipse XML Editors and Tools"
org.eclipse.wst.xml.xpath2.processor.feature (1.1.6.v201101212357-67K3BgJ9DJAPEUCSKQ) "Eclipse XPath 2 Developers Tools"
org.eclipse.wst.xsl.feature (1.1.3.v201102102045-7S7WFASFIpS-21NUD58xfPVDTLR) "Eclipse XSL Developer Tools"
org.epic.feature.main (0.6.39) "Perl Editor Plug-in"
org.fhsolution.eclipse.feature.csvedit (1.1.0) "Eclipse CSV Editor"
org.python.pydev.feature (2.0.0.2011040403) "Pydev - Python Development Environment"
zigen.plugin.future (1.2.2.v20101009) "DBViewerPlugin"
*** Plug-in Registry:
ch.sahits.codegen (2.1.0) "General Code generation plugin" [Starting]
ch.sahits.codegen.core (2.1.0) "Code GenerationCore Plug-in" [Resolved]
ch.sahits.codegen.help (2.1.0) "Help for Sahits code generation" [Starting]
ch.sahits.codegen.java (2.1.0) "Java Code Generation Plug-in" [Starting]
ch.sahits.codegen.sql (2.1.0) "SQL Insert Script maker" [Resolved]
ch.sahits.codegen.ui (2.1.0) "Encapsule the UI components of the code generation" [Starting]
ch.sahits.model (2.1.0) "Model Plug-in" [Resolved]
ch.sahits.util (1.2.3) "Sahits utilities" [Resolved]
cn.pande.eclipsex.fullscreen (1.0.7) "Fullscreen Plug-in" [Starting]
com.foosbar.mailsnag (0.4.7) "MailSnag" [Active]
com.github.eclipsecolortheme (0.9.1.201102150736) "Eclipse Color Theme" [Starting]
com.ibm.icu (4.2.1.v20100412) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
com.python.pydev (2.0.0.2011040403) "Pydev Extensions" [Active]
com.python.pydev.analysis (2.0.0.2011040403) "Analysis Plug-in" [Active]
com.python.pydev.codecompletion (2.0.0.2011040403) "Codecompletion Plug-in" [Active]
com.python.pydev.debug (2.0.0.2011040403) "Extensions Debug Plug-in" [Starting]
com.python.pydev.fastparser (2.0.0.2011040403) "Fastparser Plug-in" [Starting]
com.python.pydev.refactoring (2.0.0.2011040403) "Refactoring Plug-in" [Active]
com.quest.toad.cloud (1.2.0.201103080913) "Toad Eclipse for Cloud Databases" [Starting]
com.quest.toad.cloud.explorer (1.2.0.201103080913) "Toad Explorer View" [Starting]
com.quest.toad.cloud.help (1.2.0.201103080913) "Toad for Cloud Databases Help Content" [Resolved]
com.quest.toad.cloud.model (1.2.0.201103080913) "Data Model for Toad for Cloud Databases" [Resolved]
com.quest.toad.cloud.sqleditor (1.2.0.201103080913) "Editor for Toad for Cloud Databases" [Starting]
com.quest.toad.cloud.tools (1.2.0.201103080913) "Tools and Utilities for Toad for Cloud Databases" [Starting]
com.quest.toad.cloud.ui (1.2.0.201103080913) "Shared UI Components and Tools" [Starting]
com.tetrade.eclipse.plugins.easyshell (1.3.4) "Easy Shell Plugin" [Active]
com.wwindows.common (1.0.0.201101121101) "Common" [Active]
com.wwindows.joffice.xulrunner (1.9.2.10) "Xulrunner" [Starting]
com.wwindows.office.browser.view (1.0.0.201101121101) "View" [Starting]
com.wwindows.office.config (1.0.0.201101121101) "Config" [Resolved]
com.wwindows.office.nl (1.0.0.201101121101) "Nl" [Resolved]
com.wwindows.office.ooxml.bin (1.0.0.201101121101) "OOXML Bin" [Starting]
com.wwindows.office.ooxml.editor (1.0.0.201101121101) "OOXML Editor" [Starting]
com.wwindows.office.ooxml.libs (3.7.0.201101121101) "Opensource" [Resolved]
com.wwindows.office.ooxml.viewer (1.0.0.201101121101) "Viewer" [Starting]
com.wwindows.office.resources (1.0.0.201101121101) "Images" [Resolved]
de.anbos.eclipse.logviewer.plugin (0.9.8.7) "Log Viewer" [Active]
de.bughome.edt.arch.diagram (1.1.0) "Eclipse Diagram Tools Architecture Diagram Plugin" [Starting]
de.bughome.edt.arch.model (1.1.0) "Arch Model" [Starting]
de.bughome.edt.arch.model.edit (1.1.0) "Arch Edit Support" [Starting]
de.bughome.edt.arch.model.editor (1.1.0) "Arch Editor" [Starting]
de.loskutov.anyedit.AnyEditTools (2.4.0.201101292156) "AnyEdit Tools" [Active]
de.loskutov.FileSync (1.3.7.201103201622) "FileSync Plug-in" [Starting]
hr.ja.openextern (1.0.3) "OpenExtern Plug-in" [Starting]
java_cup.runtime (0.10.0.v201005080400) "Java Cup" [Resolved]
javax.servlet (2.5.0.v200910301333) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.wsdl (1.5.1.v201005080630) "WSDL4J" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
net.sf.eclipsecs.branding (5.3.0.201012121300) "Eclipse Checkstyle Plug-in" [Resolved]
net.sf.eclipsecs.checkstyle (5.3.0.201012121300) "Checkstyle Core Library" [Active]
net.sf.eclipsecs.core (5.3.0.201012121300) "Checkstyle Plug-in" [Active]
net.sf.eclipsecs.doc (5.3.0.201012121300) "eclipse-cs Plugin and Checkstyle Documentation" [Resolved]
net.sf.eclipsecs.ui (5.3.0.201012121300) "Eclipse Checkstyle Ui Plug-in" [Active]
net.sf.wickedshell (2.0.6) "Wicked Shell Plug-in" [Starting]
net.sf.wickedshell.domain (2.0.6) "Wicked Shell Domain Plug-in" [Starting]
net.sf.wickedshell.jdt (2.0.6) "Wicked Shell JDT support Plug-in" [Resolved]
net.sf.wickedshell.resources (2.0.6) "Wicked Shell Resources support Plug-in" [Resolved]
net.sf.wickedshell.shell (2.0.6) "Wicked Shell custom shells Plug-in" [Resolved]
net.sf.wickedshell.ui (2.0.6) "Wicked Shell UI Plug-in" [Resolved]
net.sourceforge.javahexeditor (0.4.1) "Java Hex Editor Plug-in" [Active]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v201004271650) "SourceForge LPG" [Resolved]
net.sourceforge.shelled.core (0.0.0.201007201532) "ShellEd Core" [Active]
net.sourceforge.shelled.ui (0.0.0.201007201532) "ShellEd UI" [Starting]
org.apache.ant (1.7.1.v20100518-1145) "Apache Ant" [Resolved]
org.apache.batik.bridge (1.6.0.v200912221622) "Apache Batik Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200912221622) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200912221622) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM" [Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT Utilities" [Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser" [Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG Generation" [Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI Utilities" [Resolved]
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.bcel (5.2.0.v201005080400) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v20100518-1140) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0) "Apache Commons Collections Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v201004212143) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v201005080502) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v201005080501) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v201005080501) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.net (2.0.0.v200905272248) "Apache Commons Net" [Resolved]
org.apache.jasper (5.5.17.v201004212143) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.15.v201005080500) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20100518-1140) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20100518-1140) "Apache Lucene Analysis" [Resolved]
org.apache.ws.commons.util (1.0.0.v20100518-1135) "WS Commons Util Plug-in" [Resolved]
org.apache.xalan (2.7.1.v201005080400) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v201005080400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.apache.xmlbeans (2.3.1) "Apache XML Beans Plug-in" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.201.v20110203_r362) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.1.v20101020_r362) "Ant Launching Support" [Starting]
org.eclipse.ant.optional.junit (3.2.200) "Apache Ant" [Resolved]
org.eclipse.ant.ui (3.5.0.v20100427) "Ant UI" [Active]
org.eclipse.cdt (7.0.2.201102110609) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.build.crossgcc (1.0.0.201102110609) "CDT GCC Cross Compiler Support" [Starting]
org.eclipse.cdt.codan.checkers (1.0.0.201102110609) "Codan Checkers" [Starting]
org.eclipse.cdt.codan.checkers.ui (1.0.0.201102110609) "Codan Checkers Ui" [Starting]
org.eclipse.cdt.codan.core (1.0.0.201102110609) "Code Analysis Core" [Active]
org.eclipse.cdt.codan.core.cxx (1.0.0.201102110609) "Code Analysis Core for C/C++" [Active]
org.eclipse.cdt.codan.core.test (1.0.0.201102110609) "Codan Core Tests" [Starting]
org.eclipse.cdt.codan.ui (1.0.0.201102110609) "Code Analysis UI" [Starting]
org.eclipse.cdt.codan.ui.cxx (1.0.0.201102110609) "Codan Analysis UI for C/C++" [Active]
org.eclipse.cdt.core (5.2.1.201102110609) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.lrparser (5.1.1.201102110609) "LR Parser Plug-in" [Starting]
org.eclipse.cdt.core.lrparser.tests (5.1.0.201102110609) "C99 Parser Tests Plug-in" [Resolved]
org.eclipse.cdt.core.lrparser.xlc (5.0.4.201102110609) "XLC Parser Plug-in" [Starting]
org.eclipse.cdt.core.lrparser.xlc.tests (1.0.0.201102110609) "Tests" [Resolved]
org.eclipse.cdt.core.parser.upc (5.1.0.201102110609) "UPC Parser Plug-in" [Resolved]
org.eclipse.cdt.core.parser.upc.tests (5.1.0.201102110609) "C99 Parser Tests Plug-in" [Resolved]
org.eclipse.cdt.core.tests (5.2.1.201102110609) "org.eclipse.cdt.core.tests" [Active]
org.eclipse.cdt.core.win32 (5.2.0.201102110609) "C/C++ Development Tools Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (7.0.0.201102110609) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.edc (1.0.0.201102110609) "EDC Debug Plug-in" [Starting]
org.eclipse.cdt.debug.edc.doc.user (1.0.0.201102110609) "Eclipse Debugger for C/C++ User Guide" [Resolved]
org.eclipse.cdt.debug.edc.linux.x86 (1.0.0.201102110609) "EDC Linux Debugger" [Starting]
org.eclipse.cdt.debug.edc.tcf.extension (1.0.0.201102110609) "EDC Extension to TCF Core" [Resolved]
org.eclipse.cdt.debug.edc.ui (1.0.0.201102110609) "TCF Debug Ui Plug-in" [Starting]
org.eclipse.cdt.debug.edc.windows (1.0.0.201102110609) "Windows Plug-in" [Starting]
org.eclipse.cdt.debug.edc.windows.ui (1.0.0.201102110609) "Windows Debug Plug-in" [Starting]
org.eclipse.cdt.debug.edc.x86 (1.0.0.201102110609) "X86" [Starting]
org.eclipse.cdt.debug.gdbjtag (7.0.0.201102110609) "Eclipse GDB Hardware Debugging Plug-in" [Resolved]
org.eclipse.cdt.debug.gdbjtag.core (7.0.0.201102110609) "Eclipse GDB Hardware Debug Core Plug-in" [Starting]
org.eclipse.cdt.debug.gdbjtag.ui (7.0.0.201102110609) "Eclipse GDB Hardware Debug UI Plug-in" [Starting]
org.eclipse.cdt.debug.mi.core (7.0.1.201102110609) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Starting]
org.eclipse.cdt.debug.mi.ui (6.1.0.201102110609) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Starting]
org.eclipse.cdt.debug.ui (7.0.0.201102110609) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.debug.ui.memory.memorybrowser (1.2.1.201102110609) "Memory Browser" [Starting]
org.eclipse.cdt.debug.ui.memory.search (1.2.0.201102110609) "Memory Search" [Starting]
org.eclipse.cdt.debug.ui.memory.traditional (1.2.0.201102110609) "Traditional Memory Rendering" [Starting]
org.eclipse.cdt.debug.ui.memory.transport (2.1.0.201102110609) "Memory Transport Plug-in" [Starting]
org.eclipse.cdt.debug.ui.tests (6.0.0.201102110609) "org.eclipse.cdt.debug.ui.tests" [Starting]
org.eclipse.cdt.doc.isv (5.1.0.201102110609) "C/C++ Plugin Developer Guide" [Starting]
org.eclipse.cdt.doc.user (5.1.0.201102110609) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.1.1.201102110609) "Debug Services Framework Core" [Starting]
org.eclipse.cdt.dsf.gdb (3.0.0.201102110609) "GDB DSF Debugger Integration Core" [Starting]
org.eclipse.cdt.dsf.gdb.ui (2.1.0.201102110609) "GDB DSF Debugger Integration UI" [Active]
org.eclipse.cdt.dsf.ui (2.1.2.201102110609) "Debugger Services Framework UI" [Starting]
org.eclipse.cdt.errorparsers.xlc (5.0.100.201102110609) "xlC Error Parser Test Plugin" [Starting]
org.eclipse.cdt.examples.dsf (2.1.0.201102110609) "Debugger Services Framework Examples" [Starting]
org.eclipse.cdt.examples.dsf.pda (2.1.0.201102110609) "PDA Example Device Debugging Core Plug-in" [Starting]
org.eclipse.cdt.examples.dsf.pda.ui (2.1.0.201102110609) "PDA Example Device Debugging UI Plug-in" [Starting]
org.eclipse.cdt.gdb (7.0.0.201102110609) "GDB Common" [Starting]
org.eclipse.cdt.gdb.ui (7.0.0.201102110609) "GDB UI Common" [Starting]
org.eclipse.cdt.launch (6.1.0.201102110609) "C/C++ Development Tools Launching Support" [Starting]
org.eclipse.cdt.launch.remote (2.2.0.201102110609) "C/C++ Remote Debug Launcher" [Starting]
org.eclipse.cdt.make.core (7.0.1.201102110609) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (7.0.0.201102110609) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.make.xlc.core (5.0.2.201102110609) "XL C/C++ Make Core" [Starting]
org.eclipse.cdt.managedbuilder.bupc.ui (1.0.3.201102110609) "Berkeley UPC Tool Chain" [Starting]
org.eclipse.cdt.managedbuilder.core (7.0.2.201102110609) "CDT Build System Core" [Active]
org.eclipse.cdt.managedbuilder.core.tests (7.0.0.201102110609) "Tests" [Starting]
org.eclipse.cdt.managedbuilder.gnu.ui (7.0.0.201102110609) "GNU Managed Build Definitions" [Starting]
org.eclipse.cdt.managedbuilder.ui (7.0.0.201102110609) "C/C++ Managed Builder UI" [Starting]
org.eclipse.cdt.managedbuilder.ui.tests (7.0.0.201102110609) "Managed Build UI Tests Plug-in" [Starting]
org.eclipse.cdt.managedbuilder.xlc.core (5.0.0.201102110609) "XL C/C++ Managed Build Core" [Starting]
org.eclipse.cdt.managedbuilder.xlc.ui (6.1.0.201102110609) "XL C/C++ Managed Build UI Plugin" [Starting]
org.eclipse.cdt.managedbuilder.xlupc.ui (1.1.0.201102110609) "XL UPC Managed Build UI Plugin" [Starting]
org.eclipse.cdt.p2 (1.0.0.201102110609) "CDT P2 customizations for SDKs" [Starting]
org.eclipse.cdt.scripting (1.0.0.201102110609) "Scripting" [Active]
org.eclipse.cdt.sdk (7.0.2.201102110609) "Eclipse C/C++ Development Tools SDK" [Resolved]
org.eclipse.cdt.testing (7.0.0.201102110609) "Eclipse C/C++ Development Tools Testing Framework" [Resolved]
org.eclipse.cdt.ui (5.2.2.201102110609) "C/C++ Development Tools UI" [Active]
org.eclipse.cdt.ui.tests (5.1.1.201102110609) "org.eclipse.cdt.ui.tests" [Active]
org.eclipse.cdt.util (5.0.100.201102110609) "Eclipse C/C++ Development Tools Utilities" [Resolved]
org.eclipse.compare (3.5.101.R36x_v20100929-0800) "Compare Support" [Active]
org.eclipse.compare.core (3.5.101.R36x_v20100929-0800) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.101.R36x_v20101103-0618) "Compare Support for Word" [Starting]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20100512-1500) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20100505-1235) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.3.100.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100601-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.3.0.I20100601-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.3.0.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.200.v20100505) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.1.v20100831_r361) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.100.v20100520-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.1.R36x_v20100727-0745) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86_64 (1.1.201.R36x_v20100727-0745) "Core File System for Windows 64 bit" [Resolved]
org.eclipse.core.jobs (3.5.1.R36x_v20100824) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20100511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86_64 (1.0.100.I20100505-1245) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.6.1.R36x_v20110131-1630) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.6.0.v20100505) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20100517) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.3.0.v20100520) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.400.v20100505) "Core Variables" [Active]
org.eclipse.cvs (1.0.500.v201102101200) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.7.0.20090521092446) "Data Tools Platform User Documentation" [Starting]
org.eclipse.datatools.connectivity (1.2.2.v201010220354) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.100.v200906020900) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v200906161815) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.3.v201007080903) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200906020553) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200908130547) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v201004070709) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v200906161815) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation" [Starting]
org.eclipse.datatools.connectivity.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.connectivity.oda (3.3.1.v201102051100) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.3.v201102051100) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.3.2.v201012150951) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.4.v201012150951) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.1.v201101261130) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.1.v201101261130) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.4.v201007150318) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.1.v201004090942) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.2.1.v201010090204) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.2.0.v201002281800) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v201009280455) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.2.1.v201010211415) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.4.v201004270430) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.templates (1.0.0.v200906020553) "DTP Connectivity Templates Plug-in" [Starting]
org.eclipse.datatools.doc.isv (1.8.2.V201101310500) "Data Tools Documentation Plug-in" [Resolved]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (1.0.3.v200906161800) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.4.v201005211215) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (1.0.4.v201005211230) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.1.v201005211230) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.4.v201005211230) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v201006242214) "Ingres DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v201004070709) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201001180222) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.v201004211630) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200908130512) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v201002041100) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200906161800) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.2.v201010151422) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.2.v201012301630) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.1.v201010211755) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.1.v201012161115) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200908130544) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.102.v201101120730) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.2.v201005051303) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200906020900) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.1.v200906161800) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200906020900) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041100) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201002041100) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200906020900) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200906020900) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v201010140307) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjectedit or.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111150) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200906020900) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v201010140307) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v201010140307) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090458) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.intro (1.7.0.v201005281800) "Eclipse Data Tools Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.2.v201002130228) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v201002161452) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.4.v201002250945) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.1.v201002161452) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.1.1.v201008100700) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200906022249) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.1.v201004291415) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.1.v200907031118) "DTP ODA Context-sensitive Help" [Starting]
org.eclipse.datatools.sdk (1.7.0.v200906161850) "DTP SDK Plug-in" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.2.0.v201005241300) "Data Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.2.0.v201005250945) "Data UI Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.1.v201002270530) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.1.v201005250945) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation" [Starting]
org.eclipse.datatools.sqltools.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.2.v201004291415) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200906030654) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.2.0.v201004291415) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.1.0.v201005260930) "Eclipse Data Tools Platform SQL Results View Plug-ins" [Starting]
org.eclipse.datatools.sqltools.result.ui (1.1.1.v201101140400) "Eclipse Data Tools Platform SQL Results View UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor.ui (1.0.1.v201004060545) "Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302) "Schema Object Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.1.200810071) "Schema Object Editor Framework" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages (1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.3.v201009131745) "SQL Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.2.v201009230800) "Eclipse Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.1.v201005250945) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.1.v201005250945) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.debug.core (3.6.0.v20100519) "Debug Core" [Active]
org.eclipse.debug.ui (3.6.3.v20101201_r362) "Debug UI" [Active]
org.eclipse.dltk (2.0.0.v20090827) "Eclipse Dynamic Languages Toolkit" [Resolved]
org.eclipse.dltk.console (1.0.0.v20090730-1127) "Dynamic Languages Toolkit Console Core" [Starting]
org.eclipse.dltk.console.ui (2.0.0.v20091203-1154) "Dynamic Languages Toolkit Console UI" [Starting]
org.eclipse.dltk.core (2.0.1.v20100806-1245) "Dynamic Languages Toolkit Core" [Active]
org.eclipse.dltk.core.index (2.0.0.v20100608-0117) "Eclipse Dynamic Languages Toolkit Index" [Resolved]
org.eclipse.dltk.core.index.sql (2.0.1.v20100909-1720) "DLTK Abstract SQL-based Indexer" [Active]
org.eclipse.dltk.core.index.sql.h2 (2.0.1.v20100909-1720) "DLTK H2-based Indexer" [Active]
org.eclipse.dltk.debug (2.0.0.v20091110-1532) "Dynamic Languages Toolkit Debug Core" [Starting]
org.eclipse.dltk.debug.ui (2.0.0.v20100115-2213) "Dynamic Languages Toolkit Debug UI" [Starting]
org.eclipse.dltk.formatter (2.0.0.v20100304-1959) "Dynamic Languages Toolkit Formatter" [Starting]
org.eclipse.dltk.launching (2.0.0.v20100806-1245) "Dynamic Languages Toolkit Launching Core" [Active]
org.eclipse.dltk.rse.core (2.0.1.v20100804-1944) "Dynamic Languages Toolkit RSE Integration Core" [Active]
org.eclipse.dltk.rse.ui (2.0.0.v20100115-2213) "Dynamic Languages Toolkit RSE Integration UI" [Active]
org.eclipse.dltk.ssh.core (1.0.0.v20100616-2015) "Dynamic Languages Toolkit Ssh support" [Starting]
org.eclipse.dltk.testing (1.0.0.v20090914-1703) "Dynamic Languages Toolkit Testing Frameworks Support" [Starting]
org.eclipse.dltk.ui (2.0.0.v20100909-1720) "Dynamic Languages Toolkit Core UI" [Active]
org.eclipse.dltk.validators.core (1.0.0.v201005
Current Time: Sat Jul 26 17:29:02 EDT 2025
Powered by FUDForum. Page generated in 0.04660 seconds
