Home » Archived » BIRT » How to save report to excel or pdf silently in server or client PC
How to save report to excel or pdf silently in server or client PC [message #722571] Tue, 06 September 2011 04:24 Go to next message
Hi all,
Is there a way to save or export report to pdf or excel silently in server or client PC?
Re: How to save report to excel or pdf silently in server or client PC [message #722710 is a reply to message #722571] Tue, 06 September 2011 10:38 Go to previous messageGo to next message
Can you give some more detail? Do you want as a user views the report
in html the server to generate a pdf copy somewhere?
Jason
On 9/6/2011 4:24 AM, cbr125x wrote:
> Hi all,
> Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #722861 is a reply to message #722710] Tue, 06 September 2011 21:28 Go to previous messageGo to next message
Thanks Jason for reply,
yes, i want to generate the report that i made by BIRT into PDF file, and save the file in the server local drive or client local drive (which i already granted permission to write).
Let's say i want to generate the report in pdf file at C:\PDF\ or at \\server1\PDF\
is there a way to do that?
Jason Weathersby wrote on Tue, 06 September 2011 10:38
Jason
> Hi all,
> Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #723540 is a reply to message #722861] Thu, 08 September 2011 14:39 Go to previous messageGo to next message
Are you using the RE API or the BIRT Viewer?
Jason
> \\server1\PDF\
>> Jason
>> > Hi all,
>> > Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #723620 is a reply to message #723540] Thu, 08 September 2011 21:23 Go to previous messageGo to next message
actually i'm not really sure what method i use, i think it is BIRT Viewer, i put the "webviewerExample" in the tomcat server, is it Viewer?
can i you explain me too about the RE API?
Jason Weathersby wrote on Thu, 08 September 2011 14:39
Jason
> \\server1\PDF\
>> Jason
>> > Hi all,
>> > Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #724557 is a reply to message #723620] Mon, 12 September 2011 10:16 Go to previous messageGo to next message
That is the viewer. You could write some script in the report that
would save the report to the server in a different format while the user
is viewing it in HTML. Is that what you want?
Jason
> Thanks
>> Jason
>> (which
>> > \\server1\PDF\
>> >> Jason
>> >> > Hi all,
>> >> > Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #724731 is a reply to message #724557] Mon, 12 September 2011 21:27 Go to previous messageGo to next message
Yes, that is what i want, what script i should write?
Jason Weathersby wrote on Mon, 12 September 2011 10:16 :
Jason
> Thanks
>> Jason
>> (which
>> > \\server1\PDF\
>> >> Jason
>> >> > Hi all,
>> >> > Thanks
Re: How to save report to excel or pdf silently in server or client PC [message #725008 is a reply to message #724731] Tue, 13 September 2011 13:52 Go to previous messageGo to next message
I am attaching an example of a report that creates a pdf for every row
in a detail table. Look at the table row oncreate to get an idea on how
to call the api from script. In your case you can put the script in the
afterFactory of the report.
Jason
> That is the viewer. You could write some script in the report that would
> save the report to the server in a different format while the user is
> Jason
>> Thanks
>>> Jason
>>> (which
>>> > \\server1\PDF\
>>> >> Jason
>>> >> > Hi all,
>>> >> > Thanks
  • Attachment: burst.zip
    (Size: 5.53KB, Downloaded 1179 times)
Re: How to save report to excel or pdf silently in server or client PC [message #725173 is a reply to message #725008] Wed, 14 September 2011 03:02 Go to previous messageGo to next message
Thx Jason for keep replying my question.
i already test the example u gave me. it generate pdf successfuly.
but i did not succeed implement the script in my report.
i try to describe the example u gave, sorry if i was wrong.
in the report it seeems we have to report "burstpdf" and "burstDetail".
when we called the "burstpdf" report then we generate the "burstDetail" report to pdf into "c:temp".
how about if i want to generate the burstpdf only?
i try to put this script in the afterFactory Events in report design
importPackage(Packages.org.eclipse.birt.report.engine.api);
var re = reportContext.getReportRunnable().getReportEngine();
var des = re.openReportDesign("C:/Testing/ABC.rptdesign"); //--> Let's say i have ABC.rptdesign
var ntask = re.createRunAndRenderTask(des);
var options = new PDFRenderOption();
var outputfile = "c:/temp/test1.pdf";
options.setOutputFileName(outputfile);
options.setOutputFormat("pdf");
ntask.setRenderOption(options);
ntask.run();
ntask.close();
the viewer become not responding. but when i comment the
//ntask.run();
//ntask.close();
The report run successfuly but the pdf is still not created.
can u help me in which script i must change?
Thx Again
Jason Weathersby wrote on Tue, 13 September 2011 13:52
Jason
[Updated on: Wed, 14 September 2011 03:03] by Moderator
Re: How to save report to excel or pdf silently in server or client PC [message #725382 is a reply to message #725173] Wed, 14 September 2011 11:25 Go to previous messageGo to next message
My guess is that you have a nested chase condition. You are calling a
report that generates a pdf which in itself is generating another pdf
and on and on and on..
Look at the attached example where I use a hidden parameter to make sure
this does not happen. BTW I just did the pdf generation in the
beforeFactory.
Jason
> var des = re.openReportDesign("C:/Testing/ABC.rptdesign"); var ntask =
> ntask.run();
> ntask.close();
Re: How to save report to excel or pdf silently in server or client PC [message #725508 is a reply to message #725382] Wed, 14 September 2011 22:07 Go to previous messageGo to next message
thx Jason it works now. but i have some questions.
1. I tried not to use the parameter, PDF file is generated but it takes long time than we use parameter. why should we use parameter?
2. what is the different with after factory and before factory?
Jason Weathersby wrote on Wed, 14 September 2011 11:25
beforeFactory.
Jason
> ntask.run();
> ntask.close();
Re: How to save report to excel or pdf silently in server or client PC [message #725677 is a reply to message #725508] Thu, 15 September 2011 09:46 Go to previous messageGo to next message
It does not matter if you do it in the beforeFactory or afterFactory.
The reason it is taking longer without the parameter is it is trying to
run the report a bunch of times. Every time you call the report it will
create the pdf which is circular logic.
Jason
On 9/14/2011 10:07 PM, cbr125x wrote:
> thx Jason it works now. but i have some questions. 1. I tried not to use
>> sure this does not happen. BTW I just did the pdf generation in the
>> beforeFactory.
>> Jason
>> > ntask.run();
>> > ntask.close();
Re: How to save report to excel or pdf silently in server or client PC [message #1064752 is a reply to message #725677] Thu, 20 June 2013 16:02 Go to previous messageGo to next message
Hi Jason,
I used the following code to save the birt report as a PDF in Java.
I'm able to save the pdf file. But, I cannot delete the file because it is still in use. Do you know any workaround for this?
IReportDocument rptDoc = engine.openReportDocument(docname);
IRenderTask renderTask = engine.createRenderTask(rptDoc);
RenderOption options = new PDFRenderOption();
File tempReportFile = new File(filename);
String tempReportCanonicalPath = tempReportFile.getCanonicalPath();
options.setOutputFileName(tempReportCanonicalPath);
renderTask.setRenderOption(options);
renderTask.render();
renderTask.close();
rptDoc.close();
reportDesignHandle.close();
//Some processing is done here (but no file handles opened)
//Never able to delete the file because it is in use by some BIRT Class (I think)
if(tempReportFile.delete()) {
logger.debug("delete success");
else {
logger.debug("delete fail");
Re: How to save report to excel or pdf silently in server or client PC [message #1727778 is a reply to message #1064752] Sun, 27 March 2016 07:32 Go to previous messageGo to next message
Hi jason,
In the way you showed i am able to create pdf files for static reports. but what about dynamic reports? I mean i am using pojo data source provided in birt and generating a report from rptdesign file. in the rptdesign file i tried copying the same code written by you but i does not work.
I want to generate the pdf file for the viewing report which is generated by pojo datasource using the data from the database. can you help me in this?
Re: How to save report to excel or pdf silently in server or client PC [message #1747974 is a reply to message #722571] Thu, 17 November 2016 06:24 Go to previous messageGo to next message
hi iam unable to convert my rptdesign file to pdf anybody please help ..
below is the code i am working on :
try {
EngineConfig config = new EngineConfig();
Platform.startup(config);
ReportEngine engine = new ReportEngine(config);
IReportRunnable reportRunnable = engine.openReportDesign(reportDesign);
IRunAndRenderTask runAndRender = engine.createRunAndRenderTask(reportRunnable);
PDFRenderOption option = new PDFRenderOption();
option.setOutputFileName("C:/Users/chabbbpa/Desktop/WebViewerExample/check.pdf");
option.setOutputFormat("PDF");
runAndRender.setRenderOption(option);
runAndRender.run();
System.out.println("report generated");
runAndRender.close();
engine.destroy();
Platform.shutdown();
} catch (EngineException e) {
e.printStackTrace();
} catch (BirtException e) {
Re: How to save report to excel or pdf silently in server or client PC [message #1771810 is a reply to message #725508] Wed, 30 August 2017 14:56 Go to previous messageGo to next message
your Example report CreatePDFversion is working for no parameters But i have to pass parameters.
But in my Report i have many parameters which are passed to the Report.
It shows 27 pages data, but the file in C;/temp/testa.pdf shows no data.
Why ? Is additional code required for paramterized Report to pass those paramters to the PDF too.
Can you please modify your code in Before Factory to include the parameters value passed to the Report design in your code. i.e.
if( params["createPDF"] == true ){
var des = re.openReportDesign("C:\\work\\workspaces\\2.6.1workspaces\\BIRT - Reports\\BirtEventHandlersReports\\book\\script\\burst\\createpdfversion.rptdesign");
ntask.setParameterValue("createPDF", false);
var outputfile = "C:/Temp/testa.pdf";
ntask.run();
ntask.close();
[Updated on: Wed, 30 August 2017 16:54] by Moderator
Re: How to save report to excel or pdf silently in server or client PC [message #1771871 is a reply to message #725382] Thu, 31 August 2017 10:09 Go to previous messageGo to next message
Hi Jason
Can you please create similar report createpdfversion which has parameters too. as for me the Report with parameters is showing Blank data though Report in BIRT viewer has data.
I suppose the parameters are not passed onto this PDF.
Please help i am novice in this.
Re: How to save report to excel or pdf silently in server or client PC [message #1771891 is a reply to message #725508] Thu, 31 August 2017 13:16 Go to previous messageGo to next message
hi Jason
Your work is appreciated.
Please help us with an example for createpdfversion with paramters.
As this is without any paramters.
Raj
Re: How to save report to excel or pdf silently in server or client PC [message #1785894 is a reply to message #1771871] Sun, 22 April 2018 12:43 Go to previous messageGo to next message
Did u got result for this? I am also expecting result for the same question
Re: How to save report to excel or pdf silently in server or client PC [message #1818701 is a reply to message #1771891] Mon, 23 December 2019 21:58 Go to previous message
You can set parameters as
ntask.setParameterValue(paramaterName, parameterValue);
Example -
var des = re.openReportDesign("D:\\Projects\\BirtReport\\BirtReport\\test\\Agent_Details_Report.rptdesign");
//set paameters
ntask.setParameterValue("dob", params["dob"].value);
ntask.setParameterValue("agentCode", params["agentCode"].value);
var outputfile = "d:/birt_pdf/testAgent.pdf";
ntask.run();
ntask.close();
Tejaswini
Previous Topic:Need help to disable multi-sheet export in XLSX format
Next Topic:Adding Column to Table
Current Time: Sun Jul 27 08:17:25 EDT 2025
Powered by FUDForum. Page generated in 0.05997 seconds
