Nullpointerexception when deploying model [message #1747959] |
Thu, 17 November 2016 05:19  |
16:34:07 INFO - [main ] ModelDeploymentTool - Starting ...
16:34:07 INFO - [main ] ModelDeploymentTool - Deploying model from file [C:\eclipse-mars\Workspace\support case\ACMEWorkflowModel.xpdl]
16:34:08 INFO - [main ] Parameters - CARNOT version: 3.1.1.20160216-0737
16:34:08 INFO - [main ] GlobalParameters - Loading properties via provider factory org.eclipse.stardust.common.config.DefaultPropertiesProvider$Factory (priority 1).
16:34:08 INFO - [main ] DefaultPropertiesProvider - Property bundle carnot.properties bootstrapped from classloader sun.misc.Launcher$AppClassLoader@47858e:
16:34:08 INFO - [main ] DefaultPropertiesProvider - Carnot.Spring.ApplicationContextFile = carnot-spring-client.xml
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.UseLockTables = true
16:34:08 INFO - [main ] DefaultPropertiesProvider - Security.DefaultPartition = default
16:34:08 INFO - [main ] DefaultPropertiesProvider - Logging.MaxFileSize = 4194304
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.Type = DERBY
16:34:08 INFO - [main ] DefaultPropertiesProvider - Credential.Provider =
16:34:08 INFO - [main ] DefaultPropertiesProvider - Logging.Format = %d{yyyy-MM-dd HH:mm:ss,SSS} %-5p [%t] (%x) %c{2} - %m%n
16:34:08 INFO - [main ] DefaultPropertiesProvider - Security.PromptDomain = false
16:34:08 INFO - [main ] DefaultPropertiesProvider - Logging.Directory =
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.User = carnot
16:34:08 INFO - [main ] DefaultPropertiesProvider - Mail.Host = your-mail-host
16:34:08 INFO - [main ] DefaultPropertiesProvider - Carnot.Configuration.UseDocumentRepository = true
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.FixAutoCommit = true
16:34:08 INFO - [main ] DefaultPropertiesProvider - Client.ServiceFactory = org.eclipse.stardust.engine.api.spring.SpringServiceFactory
16:34:08 INFO - [main ] DefaultPropertiesProvider - Mail.Sender = your-mail-address
16:34:08 INFO - [main ] DefaultPropertiesProvider - Logging.Filters =
16:34:08 INFO - [main ] DefaultPropertiesProvider - Logging.LogLevel = INFO
16:34:08 INFO - [main ] DefaultPropertiesProvider - Web.ServiceFactory = org.eclipse.stardust.engine.api.spring.SpringServiceFactory
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.UsePreparedStatements = true
16:34:08 INFO - [main ] DefaultPropertiesProvider - Secure.Session.Factory =
16:34:08 INFO - [main ] DefaultPropertiesProvider - QueryService.Guarded = true
16:34:08 INFO - [main ] DefaultPropertiesProvider - Security.Authentication.ConfigurationName =
16:34:08 INFO - [main ] DefaultPropertiesProvider - Security.PromptPartition = false
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.Schema =
16:34:08 INFO - [main ] DefaultPropertiesProvider - Security.PromptRealm = false
16:34:08 INFO - [main ] DefaultPropertiesProvider - Security.DefaultRealm = carnot
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.URL = jdbc:derby://localhost/carnot
16:34:08 INFO - [main ] DefaultPropertiesProvider - Carnot.ProcessPortal.AssemblyLineActivityProvider = org.eclipse.stardust.ui.web.viewscommon.common.provider.DefaultAssemblyLineActivityProvider
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.DriverClass = org.apache.derby.jdbc.ClientDriver
16:34:08 INFO - [main ] DefaultPropertiesProvider - AuditTrail.DataSource = java:/AuditTrail.DataSource
16:34:08 INFO - [main ] GlobalParameters - Loading properties via provider factory org.eclipse.stardust.engine.spring.web.SpringAppContextPropertiesProviderFactory (priority 4).
16:34:08 INFO - [main ] DefaultXMLReader - Reading model with id 'ACMEWorkflowModel'.
16:34:08 WARN - [main ] LogUtils -
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:199)
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:185)
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:28)
at org.eclipse.stardust.common.CompareHelper.compare(CompareHelper.java:100)
at org.eclipse.stardust.engine.core.model.beans.ElementFactoryImpl.createModel(ElementFactoryImpl.java:1177)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader$InvocationManager.invoke(DefaultXMLReader.java:1792)
at com.sun.proxy.$Proxy8.createModel(Unknown Source)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.loadModel(DefaultXMLReader.java:613)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.loadModel(DefaultXMLReader.java:607)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.importFromXML(DefaultXMLReader.java:1630)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.importFromXML(DefaultXMLReader.java:1554)
at org.eclipse.stardust.modeling.deploy.ModelDeploymentTool.<init>(ModelDeploymentTool.java:209)
at org.eclipse.stardust.modeling.deploy.ModelDeploymentTool.main(ModelDeploymentTool.java:142)
16:34:08 WARN - [main ] DefaultXMLReader -
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.loadModel(DefaultXMLReader.java:615)
FUDForum. Page generated in 0.07477 seconds
