Build Forte error [message #1730941] |
Sat, 30 April 2016 05:21  |
Hi all, i'm new in this forum, i have a problem with 4DIAC.
Speciically, when i make deployment with Forte with Pre-Existent Functional Blocks everything work, but when i create new functional blocks....forte recognize only the OLD pre-existent FB!
This is hoy i did:
- i create a new functional block
- exported its .cpp and .f files in the Forte\src\modules\utils
- added the line in the cmakelist.txt in the utils folder
- opened cmake, configured using the root forte directory as source code, Forte\bin\win32 as destination folder, using visual studio 8 2009 as generator and using the native compiler,checked FORTE_ARCHITECTURE_WIN32, FORTE_MODULE_CONVERT, FORTE_MODULE_IEC61131, FORTE_MODULE_TEST, FORTE_MOODULE_UTILS, FORTE_SUPPORT_MONITORING, pressed again configure since red flags don't appaer, pressed generate button
- opened visual studio generated solution with visual studio 2008
- setted release mode
- build forte......AND HERE THE PROBLEM!
"Errore 45 fatal error C1083: Impossibile aprire il file inclusione 'E_CYCLE_gen.cpp': No such file or directory"
PLEASE....HELP ME :\
Re: Build Forte error [message #1755882 is a reply to message #1751302] |
Wed, 08 March 2017 17:00   |
I've tried to build Forte 1.8.4 code base with Modbus RTU (for getting access to RS485 devices) on a x86 platform with Debian 8 installed using Cmake but I get the following errors during the compilation:
home/jreveane/4Diac/Bundle/FORTE_1.8.4/src/modules/modbus/modbusconnection.cpp: In member function 'virtual int CModbusConnection::connect()':
/home/jreveane/4Diac/Bundle/FORTE_1.8.4/src/modules/modbus/modbusconnection.cpp:35:64: error: invalid conversion from 'timeval*' to 'uint32_t {aka unsigned int}' [-fpermissive]
modbus_set_response_timeout(m_pModbusConn, &responseTimeout);
/home/jreveane/4Diac/Bundle/FORTE_1.8.4/src/modules/modbus/modbusconnection.cpp:35:64: error: too few arguments to function 'int modbus_set_response_timeout(modbus_t*, uint32_t, uint32_t)'
In file included from /home/jreveane/4Diac/Bundle/FORTE_1.8.4/src/modules/modbus/modbusconnection.h:22:0,
from /home/jreveane/4Diac/Bundle/FORTE_1.8.4/src/modules/modbus/modbusconnection.cpp:11:
/home/jreveane/4Diac/Bundle/build/modbus.h:186:16: note: declared here
MODBUS_API int modbus_set_response_timeout(modbus_t *ctx, uint32_t to_sec, uint32_t to_usec);
/home/jreveane/4Diac/Bundle/FORTE_1.8.4/src/modules/modbus/modbusconnection.cpp:41:56: error: invalid conversion from 'timeval*' to 'uint32_t {aka unsigned int}' [-fpermissive]
modbus_set_byte_timeout(m_pModbusConn, &byteTimeout);
/home/jreveane/4Diac/Bundle/FORTE_1.8.4/src/modules/modbus/modbusconnection.cpp:41:56: error: too few arguments to function 'int modbus_set_byte_timeout(modbus_t*, uint32_t, uint32_t)'
/home/jreveane/4Diac/Bundle/build/modbus.h:189:16: note: declared here
MODBUS_API int modbus_set_byte_timeout(modbus_t *ctx, uint32_t to_sec, uint32_t to_usec);
src/CMakeFiles/forte.dir/build.make:1710: recipe for target 'src/CMakeFiles/forte.dir/modules/modbus/modbusconnection.cpp.o' failed
make[2]: *** [src/CMakeFiles/forte.dir/modules/modbus/modbusconnection.cpp.o] Error 1
CMakeFiles/Makefile2:125: recipe for target 'src/CMakeFiles/forte.dir/all' failed
make[1]: *** [src/CMakeFiles/forte.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
I had a look at the Forte build documentation for Unix platform and the Modbus page as well but this didn't really help.
So, is there any HowTo which would explain the Forte Build on Linux with Modbus RTU support ?
Thanks in advance for your help.
Regards.
Re: Build Forte error [message #1794272 is a reply to message #1794239] |
Tue, 28 August 2018 07:24  |
Typically libmodbus.so will just be a symbolic link. In your case I assume it points to libmodbus.so.5. So you the question would be if you installed libmodbus in your system. Then something with the install process seems to be broken. If you just build your own libmodbus. Then you need also the files where all the symbolic so links are pointing to in the directory of forte executable.
FUDForum. Page generated in 0.28243 seconds
