Home » Archived » Eclipse Process Manager (Stardust) » Stardust portal-Participant Manager Tab empty(First time running stardust portal)
Stardust portal-Participant Manager Tab empty [message #1747346] |
Sat, 12 November 2016 18:42  |
I completed the Support Case Management tutorial using Eclipse Neon.1
After deploying the model to tomcat and succesfully logged to the portal the link to "Participant Manager" , the tab shows empty.
Also the Workflow Execution tab is displayed with the labels {{TITLE}} in every row.
I tried firefox and chrome.
In the log i get this warning:
18:12:25 INFO [Thread8 ] ForkingDebugInterceptor - <-- forked.
nov 12, 2016 6:12:25 PM org.apache.catalina.core.ApplicationContext log
INFORMACIÓN: WARNING: Component _id186 just got an automatic id, because there was no id assigned yet. If this component was created dynamically (i.e. not by a JSP tag) you should assign it an explicit static id or assign it the id you get from the createUniqueId from the current UIViewRoot component right after creation!
18:12:25 INFO [080-exec-8] DateUtils - Client TimeZone ID: GMT-05:00
The Stardust version is 4.0.1
Eclipse Process Manager - Core Modeling 4.0.1.v20160914-0234-RC4 org.eclipse.stardust.modeling.core-feature.feature.group Eclipse Stardust
What could I have done wrong?
Re: Stardust portal-Participant Manager Tab empty [message #1747909 is a reply to message #1747346] |
Wed, 16 November 2016 12:14   |
These are the last lines from the log taken just after the login page.
The suspicious lines are in red but there is no Stack traces.
12:03:53 INFO [080-exec-1] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:53 INFO [080-exec-1] FiFoJobManager - Enqueued job Job {runnable = ForkedActionRunner {action = org.eclipse.stardust.engine.core.runtime.internal.SynchUserSessionToDiskAction@516ac40e}, done = false, error = null}. Scheduled queue length is now 1
12:03:53 INFO [Thread1 ] FiFoJobManager - Adding job Job {runnable = ForkedActionRunner {action = org.eclipse.stardust.engine.core.runtime.internal.SynchUserSessionToDiskAction@516ac40e}, done = false, error = null}. Active jobs queue length is now 1
12:03:53 INFO [Thread2 ] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:53 INFO [080-exec-1] AuditTrailLogger - Logged in. (User: motu (Realm: carnot) (Of the Universe, Master))
12:03:53 INFO [Thread2 ] ForkingDebugInterceptor - --> forked: org.eclipse.stardust.engine.core.runtime.internal.SynchUserSessionToDiskAction@516ac40e
12:03:53 INFO [Thread2 ] ForkingDebugInterceptor - <-- forked.
12:03:53 WARN [080-exec-1] inJavaAccessPointProvider - Couldn't create access points for java type, class 'null' not found.
12:03:53 INFO [080-exec-1] ContextParameters - Properties added from scope 'web':
12:03:53 INFO [080-exec-1] LogUtils - jdbc:
12:03:53 INFO [080-exec-1] LogUtils - AuditTrail.DataSource = org.apache.derby.jdbc.EmbeddedXADataSource@3e3047e6
12:03:53 INFO [080-exec-1] LoginUtils - Initializing for Login
12:03:53 INFO [080-exec-1] ServiceLoaderUtils - searchProviders: Searching providers using IPP = org.eclipse.stardust.ui.web.common.spi.user.IAuthorizationProvider$Factory
12:03:53 INFO [080-exec-1] ServiceLoaderUtils - searchProviders: Found provider using IPP -> [org.eclipse.stardust.ui.web.viewscommon.common.spi.user.impl.IppAuthorizationProvider$IppFactory@76ec62b8]
12:03:53 INFO [080-exec-1] FilterProviderUtil - Filter Providers are loaded from JCR
12:03:53 INFO [080-exec-1] FilterProviderUtil - Filter Providers loaded are: []
12:03:54 INFO [080-exec-1] AuditTrailLogger - Logged in. (User: motu (Realm: carnot) (Of the Universe, Master))
12:03:54 INFO [080-exec-1] IppThemeProvider - Inside Loading plugin skin folders
12:03:54 INFO [080-exec-1] LoginUtils - Initialization successful for Login
12:03:54 INFO [080-exec-4] ortalPluginResourceLoader - Resolved plugin ID html5-common to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-html5-common.jar!/META-INF/webapp
12:03:54 INFO [080-exec-3] ortalPluginResourceLoader - Resolved plugin ID html5-views-common to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-html5-views-common.jar!/META-INF/webapp
12:03:54 INFO [80-exec-10] ortalPluginResourceLoader - Resolved plugin ID benchmark to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-benchmarks.jar!/META-INF/webapp
12:03:54 INFO [080-exec-2] ortalPluginResourceLoader - Resolved plugin ID bpm-modeler to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-web-modeler.jar!/META-INF/xhtml
12:03:54 INFO [80-exec-12] ortalPluginResourceLoader - Resolved plugin ID html5-process-portal to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-html5-process-portal.jar!/META-INF/webapp
12:03:54 INFO [80-exec-11] ortalPluginResourceLoader - Resolved plugin ID html5-business-control-center to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-html5-business-control-center.jar!/META-INF/webapp
12:03:54 INFO [80-exec-13] ortalPluginResourceLoader - Resolved plugin ID html5-admin-portal to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-html5-admin-portal.jar!/META-INF/webapp
12:03:54 INFO [080-exec-9] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:54 INFO [080-exec-4] ortalPluginResourceLoader - Resolved plugin ID bpm-reporting to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-web-reporting.jar!/META-INF/webapp
12:03:54 INFO [80-exec-11] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:54 INFO [80-exec-13] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:54 INFO [080-exec-8] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:54 INFO [080-exec-4] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:54 INFO [080-exec-7] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:54 INFO [080-exec-3] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:54 INFO [080-exec-8] ortalPluginResourceLoader - Resolved plugin ID stardust-web-camel to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-web-camel.jar!/META-INF/xhtml
12:03:54 INFO [80-exec-12] Parameters - CARNOT version: 4.0.1.20160914-0634-RC4
12:03:55 INFO [80-exec-10] HTML5FrameworkServices - Loading Plugin Bundles: [benchmark-messages, html5-common, views-common-messages, bpm-reporting-messages, rules-manager-messages, html5-admin-portal, html5-process-portal, html5-business-control-center, business-control-center-messages, portal-common-messages, processportal, bpm-modeler-messages, html5-views-common, admin-portal-messages, stardust-web-camel]
12:03:55 INFO [80-exec-10] nFaceletsResourceResolver - Resolved plugin ID common to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/ipp-portal-common.jar!/META-INF/xhtml
nov 16, 2016 12:03:55 PM org.apache.catalina.core.ApplicationContext log
INFORMACIÓN: WARNING: Component _id42 just got an automatic id, because there was no id assigned yet. If this component was created dynamically (i.e. not by a JSP tag) you should assign it an explicit static id or assign it the id you get from the createUniqueId from the current UIViewRoot component right after creation!
12:03:56 INFO [80-exec-12] ortalPluginResourceLoader - Resolved plugin ID stardust-ui-form-jsf to URL prefix jar:file:/Users/karimrg/Documents/SwDevelopment/EclipseStardust-tutorials/.metadata/.plugins/org.eclipse.wst.server.core/tmp1/wtpwebapps/kr-support-case/WEB-INF/lib/stardust-ui-form-jsf.jar!/META-INF/webapp
12:03:56 INFO [080-exec-4] DateUtils - Client TimeZone ID: GMT-05:00
Re: Stardust portal-Participant Manager Tab empty [message #1747917 is a reply to message #1747909] |
Wed, 16 November 2016 13:06   |
hi,
whith the logs activated and click on "participation manager" link the log is:
13:03:06 DEBUG [080-exec-9] EnhancedJarResourceFilter - Looking for Resource Path: /block/send-receive-updates
13:03:06 DEBUG [080-exec-9] EnhancedJarResourceFilter - Skipped Resource Path: block/send-receive-updates
13:03:06 DEBUG [080-exec-9] MainServlet - Servicing Request-URI: [/Support-Case/block/send-receive-updates]
13:03:06 DEBUG [080-exec-9] efaultListableBeanFactory - Creating instance of bean 'ippRequestScopedBpmEventBridge'
13:03:06 DEBUG [080-exec-9] efaultListableBeanFactory - Invoking init method 'init' on bean with name 'ippRequestScopedBpmEventBridge'
13:03:06 DEBUG [080-exec-9] efaultListableBeanFactory - Creating instance of bean 'infinityBpmEventsController'
13:03:06 DEBUG [080-exec-9] VariableResolverImpl - Variable 'infinityRequestScopedCustomBpmEventsController' could not be resolved.
13:03:06 DEBUG [080-exec-9] efaultListableBeanFactory - Finished creating instance of bean 'infinityBpmEventsController'
13:03:06 DEBUG [080-exec-9] efaultListableBeanFactory - Finished creating instance of bean 'ippRequestScopedBpmEventBridge'
13:03:06 DEBUG [080-exec-9] FileUploadPhaseListener - FileUploadPhaseListener.beforePhase() APPLY_REQUEST_VALUES(2)
13:03:06 DEBUG [080-exec-9] FileUploadPhaseListener - FileUploadPhaseListener.beforePhase() stateHolder: null
13:03:06 DEBUG [080-exec-9] PortalUiController - openView: viewUrl=/plugins/html5-admin-portal/partials/views/participantManagementView.html/participantMgmt, viewDef=org.eclipse.stardust.ui.web.common.ViewDefinition@509acd25, msgBean=null
13:03:06 DEBUG [080-exec-9] FileUploadPhaseListener - FileUploadPhaseListener.afterPhase() APPLY_REQUEST_VALUES(2)
13:03:06 DEBUG [080-exec-9] efaultListableBeanFactory - Returning cached instance of singleton bean 'ippPortalParameters'
13:03:06 DEBUG [080-exec-9] VariableResolverImpl - Variable 'requiredValue' could not be resolved.
13:03:06 DEBUG [080-exec-9] talApplicationEventScript - Event Scripts: try{parent.BridgeUtils.log("parent.BridgeUtils.View.openView('/bpm/portal/Int/participantMgmt/_all_', '/bpm/portal/Int/participantMgmt/:id', {type: 'participantMgmt', id: '_all_', label: 'Participant Manager', icon: 'participant-manager', url: '/Support-Case/plugins/common/portalSingleViewMain.iface?singleViewId=ippAdminPerspective::participantMgmt&standaloneMode=true&singleViewKey=null', custom: {}});", 'i');parent.BridgeUtils.View.openView('/bpm/portal/Int/participantMgmt/_all_', '/bpm/portal/Int/participantMgmt/:id', {type: 'participantMgmt', id: '_all_', label: 'Participant Manager', icon: 'participant-manager', url: '/Support-Case/plugins/common/portalSingleViewMain.iface?singleViewId=ippAdminPerspective::participantMgmt&standaloneMode=true&singleViewKey=null', custom: {}});}catch(e){}
13:03:06 DEBUG [080-exec-9] SingleViewLaunchPanels - SingleApp_LaunchPanels:getEventScripts():parent.BridgeUtils.runScript(function() {try{parent.BridgeUtils.log("parent.BridgeUtils.View.openView(true, '/bpm/portal/Int/participantMgmt/_all_', '/bpm/portal/Int/participantMgmt/:id', {type: 'participantMgmt', id: '_all_', label: 'Participant Manager', icon: 'participant-manager', url: '/Support-Case/plugins/common/portalSingleViewMain.iface?singleViewId=ippAdminPerspective::participantMgmt&standaloneMode=true&singleViewKey=null', custom: {}});", 'i');parent.BridgeUtils.View.openView(true, '/bpm/portal/Int/participantMgmt/_all_', '/bpm/portal/Int/participantMgmt/:id', {type: 'participantMgmt', id: '_all_', label: 'Participant Manager', icon: 'participant-manager', url: '/Support-Case/plugins/common/portalSingleViewMain.iface?singleViewId=ippAdminPerspective::participantMgmt&standaloneMode=true&singleViewKey=null', custom: {}});}catch(e){}parent.BridgeUtils.initiateResize();}, 0.7407873210766408)
13:03:06 DEBUG [080-exec-9] BridgeFacesContext - javax.servlet.include.request_uri = null
13:03:06 DEBUG [080-exec-9] BridgeFacesContext - javax.servlet.include.servlet_path = null
13:03:06 DEBUG [080-exec-9] ReceiveSendUpdates - String intern pools sizes:
ClientIdPool: 50
CSSNamePool: 15
ELPool: 0
XhtmlPool: 40
13:03:06 DEBUG [080-exec-9] DisposableBeanAdapter - Invoking destroy method 'destroy' on bean with name 'ippRequestScopedBpmEventBridge'
regards
[Updated on: Wed, 16 November 2016 20:16] by Moderator
Current Time: Sun Jul 20 20:15:34 EDT 2025
Powered by FUDForum. Page generated in 0.11576 seconds
