Re: Exported Product does not run ObjectTeams [message #1800884 is a reply to message #1747265] |
Wed, 09 January 2019 06:50   |
Till Kolditz wrote on Fri, 11 November 2016 12:46Hi,
after having solved my previous problem (project-specific settings for O/T were missing), I'm now stuck at getting O/T enabled in my exported product (eclipse neon, not yet SR1).
All required plug-ins are exported and the code for activating teams does not throw exceptions (except for one weird case).
However, it turns out that my roles are not executed. Starting the product from inside eclipse, I have to set the "enable O/T equinox" setting explicitly in the "Run Configurations" dialog. Notepad++ Malwarebytes FileZilla
Is there anything I have to enable for product export in eclipse neon?
IIRC in eclipse 3.* this worked out of the box.
"Normally" this setting is added when you install a recent version of OT/Equinox, but obviously, that trick doesn't help for a product.
[Updated on: Wed, 09 January 2019 15:09] by Moderator
FUDForum. Page generated in 0.05306 seconds
