Home » Eclipse Projects » Eclipse Scout » [NEON] Refresh Ui Component instantly
[NEON] Refresh Ui Component instantly [message #1746653] Wed, 02 November 2016 09:45 Go to next message
I implemented a menu to load data asynchronously as following:
public abstract class AbstractLoadingMenu extends AbstractMenu {
	protected String getConfiguredText() {
		return TEXTS.get("AbstractLoadingMenu");
	protected Set<? extends IMenuType> getConfiguredMenuTypes() {
		return CollectionUtility.hashSet(TableMenuType.EmptySpace);
	protected void execAction() {
		setEnabled(false);
		Jobs.schedule(new IRunnable() {
			public void run() throws Exception {
				try {
					setText(getConfiguredLoadingMessage());
					load();
				} catch (Throwable t) {
					t.printStackTrace();
					setText(getConfiguredErrorMessage());
				} finally {
					setText(getConfiguredText());
					setEnabled(true);
		}, Jobs.newInput().withName(getConfiguredText()).withRunContext(ClientRunContexts.copyCurrent()));
	protected abstract void load();
Sometimes it takes rather long until the menu becomes enabled again despite setEnabled(true); being called almost instantly. I suspect it maybe has something todo with it being called out of a job. Is there a method to force the ui to refresh instantly after setEnabled(true); has been called?
Other than that I am generally interested in any feedback about this implementation.
Re: [NEON] Refresh Ui Component instantly [message #1747376 is a reply to message #1746653] Mon, 14 November 2016 02:32 Go to previous messageGo to next message
Your guess is almost right. The UI change doesn't happen immediately because you call setText/setEnabled outside of a model job. All changes on the Scout (UI) model must happen inside of a model job. So when you do something in the background by starting an arbitrary Thread you must make sure, that this Thread starts a model thread again, when you call a method on the Scout model (like you do). Instead of the Jobs class, simply use the ModelJobs class. A small example:
   // this is executed by a thread != Scout model thread
   loadALotOfDataInTheBackground();
   // when you're done...
    ModelJobs.schedule(new IRunnable() {
         m_stringField.setText("I'm done");
    }, ModelJobs.newInput(ClientRunContexts.copyCurrent()));
You should also check the technical guide for more details about the Scout jobs framework:
https://eclipsescout.github.io/6.0/technical-guide.html#modeljobs
Re: [NEON] Refresh Ui Component instantly [message #1747378 is a reply to message #1747376] Mon, 14 November 2016 02:54 Go to previous message
Andre Wegmueller wrote on Mon, 14 November 2016 07:32
Thats what I should have done in the first place. Thank you!
Previous Topic:Issues with Hello World example for beginners
Next Topic:[neon] Login with http works, but not https
Current Time: Wed Jul 23 11:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.28166 seconds
