Home » Modeling » ATL » access to String ATL
icon5.gif  access to String ATL [message #1746992] Tue, 08 November 2016 07:01 Go to next message
when i generate getRule1() :
lazy rule Rule2Rule{
      from f:GrammAcme!Rule
      to t:MMAcme!Rule(
      	 ruletext<-thisModule.getRule1()
  helper  def: getRule1(f:GrammAcme!Rule):String=
  	 if not f.designRuleExpression.qt.formalParam.oclIsUndefined() then
		   if not f.designRuleExpression.qt.designRuleExpression.qb.oclIsUndefined() then
		  if not  f.designRuleExpression.qt.designRuleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpression.additiveExpression
         .multiplicativeExpression.unaryExpression.primitiveExpression.ruleExpression.oclIsUndefined() then
         .multiplicativeExpression.unaryExpression.primitiveExpression.ruleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpression
         .additiveExpression.multiplicativeExpression.unaryExpression.primitiveExpression.id.oclIsUndefined() then
  	  f.nameRule +' '+ '='+' ' + f.typeRule +' '+ f.designRuleExpression.qt.typeExp + ' '+ f.designRuleExpression.qt.nameComponent
		 + ' '+':'+' ' +f.designRuleExpression.qt.formalParam.type
		+ ' '+'in'+ ' '+  f.designRuleExpression.qt.setExpression.nameSetReference
		 +'.' + f.designRuleExpression.qt.setExpression.set.toString().regexReplaceAll('Sequence',' ').replaceAll('{',' ').replaceAll('}',' ').replaceAll('\'',' ').trim()
         .additiveExpression.multiplicativeExpression.unaryExpression.primitiveExpression.id.idName+'.'+f.designRuleExpression.qt.designRuleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpression.additiveExpression
         .additiveExpression.multiplicativeExpression.unaryExpression.primitiveExpression.id.iddNames.toString().regexReplaceAll('Sequence',' ').replaceAll('{',' ').replaceAll('}',' ').replaceAll('\'',' ').trim()
			  	else  OclUndefined endif
here i don't have a problem and i have this result :
<rules ruletext="rule10 = invariant forall ps : PortTWSService in self.PORTS | (ps.Prec) =="/>
when i generate getRule3() i don't have a problem
      to t:MMAcme!Rule(
      	 ruletext<-thisModule.getRule3()
 helper def: getRule3(f:GrammAcme!Rule):String=
  if not f.oclIsUndefined() then
   	if not f.designRuleExpression.qt.designRuleExpression.oclIsUndefined() then
         .multiplicativeExpression.unaryExpression.primitiveExpression.ruleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpressions->first().
						  						  else  OclUndefined endif ;								  ;
<rules ruletext="activer"/>
but when i concat getRule3() + getRule1() like this :
      to t:MMAcme!Rule(
      	 ruletext<-thisModule.getRule1()+thisModule.getRule3()
i have this problem :
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: OclUndefined.+(org.eclipse.m2m.atl.engine.emfvm.lib.OclUndefined)
at Rule2Rule#296(Acme2Acme.atl[116:2-116:47])
local variables: self=Acme2Acme : ASMModule, f=IN!<unnamed>, t=OUT!<unnamed>
at Family2Family#113(Acme2Acme.atl[28:32-28:55])
local variables: self=Acme2Acme : ASMModule, f=IN!<unnamed>, q=IN!<unnamed>, j=OUT!WSM, e=IN!<unnamed>
at __applyFamily2AcmeFile#24(Acme2Acme.atl[12:17-12:46])
local variables: self=Acme2Acme : ASMModule, link=TransientLink {rule = Family2AcmeFile, sourceElements = {q = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@9a6d8c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1a36881 (name: FamilyBody) (instanceClassName: null) (abstract: false, interface: false)), f = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@11642c7 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@8201b4 (name: Family) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {j = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@d60adf (eClass: org.eclipse.emf.ecore.impl.EClassImpl@14f5028 (name: AcmeFile) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, f=IN!<unnamed>, q=IN!<unnamed>, j=OUT!WSM
at __exec__#8(Acme2Acme.atl)
local variables: self=Acme2Acme : ASMModule, e=TransientLink {rule = Family2AcmeFile, sourceElements = {q = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@9a6d8c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1a36881 (name: FamilyBody) (instanceClassName: null) (abstract: false, interface: false)), f = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@11642c7 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@8201b4 (name: Family) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {j = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@d60adf (eClass: org.eclipse.emf.ecore.impl.EClassImpl@14f5028 (name: AcmeFile) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}
at main#27(Acme2Acme.atl)
i don'tt unrestand wahat is the problem ??????
[Updated on: Wed, 09 November 2016 20:08] by Moderator
Re: problem string concat operation OclUndefined ? [message #1746997 is a reply to message #1746992] Tue, 08 November 2016 07:45 Go to previous messageGo to next message
please any help ??
Re: problem string concat operation OclUndefined ? [message #1747041 is a reply to message #1746997] Tue, 08 November 2016 14:03 Go to previous messageGo to next message
any one can help me!!!!
Re: problem string concat operation OclUndefined ? [message #1747144 is a reply to message #1747041] Thu, 10 November 2016 03:21 Go to previous messageGo to next message
ATL dynamically looks up the '+' method, based on its arguments (unlike Java, which looks up methods statically). If your first String argument is OclUndefined at runtime, ATL tries to find '+' on OclUndefined, which does not exist.
The easiest solution is to return empty strings instead of OclUndefined in thisModule.getRule1() and thisModule.getRule3(). Alternatively, you have to perform oclIsUndefined() checks on both values before calling '+'.
Re: problem string concat operation OclUndefined ? [message #1747152 is a reply to message #1747144] Thu, 10 November 2016 04:37 Go to previous messageGo to next message
hi , i do that but thisModule.getRule3()+thisModule.getRule1() is
thisModule.getRule1() is Quote:
empty !!!! the result is ''
[Updated on: Thu, 10 November 2016 06:03] by Moderator
Re: problem string concat operation OclUndefined ? [message #1747155 is a reply to message #1747152] Thu, 10 November 2016 05:14 Go to previous messageGo to next message
please help me I am blocked
Re: problem string concat operation OclUndefined ? [message #1748285 is a reply to message #1747155] Mon, 21 November 2016 14:54 Go to previous message
You can't call a third function to merge them?
"ruletext<-thisModule.getRule1and3()" or maybe "ruletext<-thisModule.getRule1and3(thisModule.getRule1(), thisModule.getRule3())"
Previous Topic:ResolveTemp and Multiple Helpers in HOT
Next Topic:OclExpression decomposition in ATL HOT
Current Time: Fri Jul 25 08:35:16 EDT 2025
Powered by FUDForum. Page generated in 0.05505 seconds
