Eclipse Titan hangs due to waiting user operation [message #1746863] |
Sun, 06 November 2016 15:14  |
I get the attached error message after changing some TTCN-files. I have reinstalled eclipse, cleaned the workspace, recreated the project. Started eclipse with -clean option in eclipse.ini file, removed the .lock file in the workspaces metadata and tried all other recommendations I have found. Nothing helped.
I am using eclipse under ubuntu 16.04. I noticed that after ecplise titan reinstalled the "Titanium feature" package did not install due to dependency problems.
Michael
Re: Eclipse Titan hangs due to waiting user operation [message #1747200 is a reply to message #1747102] |
Thu, 10 November 2016 11:44   |
Ok. Here is the debug output:
On-the-fly analyzation of project titan.TestPorts.SocketCANasp started
**It took 3.426012414 seconds till the files (23 pieces) of project titan.TestPorts.SocketCANasp got syntactically analyzed
**Selection with Broken parts via references is started at: 2016.11.10 05:41:35.848
** Module SocketCAN__Templates can not be skipped as it was not yet analyzed.
** Module Isobus can not be skipped as it was not yet analyzed.
** Module Isotptest can not be skipped as it was not yet analyzed.
** Module IsobusMessageTypes can not be skipped as it was not yet analyzed.
** Module IsobusCMMessageTypes can not be skipped as it was not yet analyzed.
** Module Raw can not be skipped as it was not yet analyzed.
** Module Isobustest can not be skipped as it was not yet analyzed.
** Module SocketCAN__BCM__test can not be skipped as it was not yet analyzed.
** Module Bcm can not be skipped as it was not yet analyzed.
** Module SocketCAN__PortType can not be skipped as it was not yet analyzed.
** Module J1939 can not be skipped as it was not yet analyzed.
** Module Can can not be skipped as it was not yet analyzed.
** Module SocketCAN__RAW__test can not be skipped as it was not yet analyzed.
** Module test2 can not be skipped as it was not yet analyzed.
** Module test3 can not be skipped as it was not yet analyzed.
** Module SocketCANtest can not be skipped as it was not yet analyzed.
** Module IsobusNMMessageTypes can not be skipped as it was not yet analyzed.
** Module IsobusVTMessageTypes can not be skipped as it was not yet analyzed.
** Module CanError can not be skipped as it was not yet analyzed.
** Module Isotp can not be skipped as it was not yet analyzed.
** Module General__Types can not be skipped as it was not yet analyzed.
** Module SocketCAN__Types can not be skipped as it was not yet analyzed.
** Module Isobus__Templates can not be skipped as it was not yet analyzed.
**Selection with Broken parts via references is ended at: 2016.11.10 05:41:35.862
**Selection time is: 0.013229685000000001 seconds (13229685 nanoseconds).
**Nr. of broken modules: 23
**Broken modules name: [module: SocketCAN__Templates, module: Isobus, module: Isotptest, module: IsobusMessageTypes, module: IsobusCMMessageTypes, module: Raw, module: Isobustest, module: SocketCAN__BCM__test, module: Bcm, module: SocketCAN__PortType, module: J1939, module: Can, module: SocketCAN__RAW__test, module: test2, module: test3, module: SocketCANtest, module: IsobusNMMessageTypes, module: IsobusVTMessageTypes, module: CanError, module: Isotp, module: General__Types, module: SocketCAN__Types, module: Isobus__Templates]
** Had to start checking at 23 modules.
**On-the-fly semantic checking of projects (23 modules) took 0.730165546 seconds
The whole analysis block took 4.261023067 seconds to complete
** Had to start checking at 0 modules.
**On-the-fly semantic checking of projects (23 modules) took 2.81321E-4 seconds
The whole analysis block took 0.0026314100000000003 seconds to complete
**It took 0.045728091000000005 seconds till the files (22 pieces) of project titan.TestPorts.SocketCANasp got syntactically analyzed
The whole analysis block took 0.049333578 seconds to complete
**It took 0.111342092 seconds till the files (22 pieces) of project titan.TestPorts.SocketCANasp got syntactically analyzed
The whole analysis block took 0.11174542500000001 seconds to complete
**It took 0.102277881 seconds till the files (22 pieces) of project titan.TestPorts.SocketCANasp got syntactically analyzed
The whole analysis block took 0.102750357 seconds to complete
**It took 0.054393090000000005 seconds till the files (22 pieces) of project titan.TestPorts.SocketCANasp got syntactically analyzed
The whole analysis block took 0.054744182 seconds to complete
**It took 0.064461828 seconds till the files (22 pieces) of project titan.TestPorts.SocketCANasp got syntactically analyzed
The whole analysis block took 0.065253689 seconds to complete
**It took 0.09879035600000001 seconds till the files (22 pieces) of project titan.TestPorts.SocketCANasp got syntactically analyzed
The whole analysis block took 0.099098984 seconds to complete
> Window/Preferences/ TITAN Preferences/On-the-fly checker and disable the option "Warn and disable parsing before the system runs out of memory".
There is no such preferences option in my Titan preferences tab. The option "Treat on-the -fly error as fatal for the build was not activated. See attachment.
When activation above option nothing changes. See attachment.
[Updated on: Thu, 10 November 2016 12:13] by Moderator
Re: Eclipse Titan hangs due to waiting user operation [message #1747911 is a reply to message #1747578] |
Wed, 16 November 2016 12:23  |
Hi Kristof,
>One way to proceed forward could be to check if you can update your plugins to the newest (5.5.1) version, to see if the issue still persists.
I regularly have problems to find the installation instructions for the latest release. Probably I took an old version of the install instructions in the documentation set.
I'll wait for the next release.
Michael
[Updated on: Wed, 16 November 2016 12:26] by Moderator
FUDForum. Page generated in 0.11346 seconds
