Home » Modeling » QVT-OML » Refine profiled model in QVT-OML
Refine profiled model in QVT-OML [message #1746829] Sat, 05 November 2016 05:44 Go to next message
Hi, guys.
Is it possibile to refine a profiled UML Model in order to add some elements without modify anything else in a qvt-oml transformation? Thank you for the answer.
Re: Refine profiled model in QVT-OML [message #1746831 is a reply to message #1746829] Sat, 05 November 2016 05:59 Go to previous messageGo to next message
I don't see why it should not be possible.
Ed Willink
Re: Refine profiled model in QVT-OML [message #1746841 is a reply to message #1746831] Sat, 05 November 2016 11:07 Go to previous messageGo to next message
I'm trying to do this operation with a inout profiled model as parameter of the transformation , but i lose the stereotypes applied. Can you explain me How to do this operation in the right manner? Can you show me some example? Thanks.
Re: Refine profiled model in QVT-OML [message #1746846 is a reply to message #1746841] Sat, 05 November 2016 19:28 Go to previous messageGo to next message
Solved
Re: Refine profiled model in QVT-OML [message #1746848 is a reply to message #1746846] Sun, 06 November 2016 03:58 Go to previous messageGo to next message
HI
Good. Other users may make the similar mistakes and developers can learn from the mistakes users make, so please share the secret of your solution, no matter how stupid you may feel about it.
Ed Willink
Re: Refine profiled model in QVT-OML [message #1746918 is a reply to message #1746848] Mon, 07 November 2016 11:40 Go to previous message
in transformation FooBar(inout mymodel : UML);
property stereotype_bla_bla  : Stereotype =  mymodel.objects()[Stereotype]![name = 'BlaBla'];
didn't work properly.
I solved the problem adding the profile.uml as input parameter and writing
property stereotype_bla_bla  : Stereotype =  profile.objects()[Stereotype]![name = 'BlaBla'];
I thought it was not necessary to pass the profile as additional input because the model was already profiled.
Previous Topic:How to set tagged values after applying a profile
Next Topic:set XMI id of object during a QVTo transformation
Current Time: Mon Jul 21 07:25:57 EDT 2025
Powered by FUDForum. Page generated in 0.07592 seconds
