Upgrade Mars 32-bit to Neon 64-bit [message #1746842] |
Sat, 05 November 2016 11:22  |
Good morning:
I'd like to upgrade an existing 32-bit Mars installation to 64-bit. Neon. Before I shoot myself in the foot, I thought I'd ask whether there are any special considerations when making such an upgrade. Is there anything special I need to do? I've already downloaded and installed the required Java JRE.
Oh... I'm running 64-bit Windows 7.
Thanks!
Kenton
Re: Upgrade Mars 32-bit to Neon 64-bit [message #1748540 is a reply to message #1747340] |
Thu, 24 November 2016 03:22  |
Kenton Smith wrote on Sat, 12 November 2016 15:31Thanks, Eric, for your very complete and very informative reply! I have successfully installed the Neon release.
One of the things I had failed to notice is that the Eclipse installation directory name includes the Eclipse release, thus each Eclipse installation is self-contained within its directory. And since Eclipse stores no Windows Registry and/or ProgramData entries, it is OK to simply remove the obsolete installation directory. Which I did.
Moreover, as Nitin implied, Neon converts Mars workspaces to a new format, hence the recommendation to save Mars workspaces before upgrading. Which I did.
Thanks also for the heads up regarding the need to reinstall plugins. That prompted me to check which ones I had installed and to verify that versions were available for Neon. Which I did.
Best,
Kenton
Thanks for your advise.
FUDForum. Page generated in 0.14533 seconds
