Read sequence diagram by its Xmi [message #1746584] |
Tue, 01 November 2016 08:04  |
I am trying to read sequence diagram xmi generated by IBM Rational software architect , by using EMF but i still can't read the xmi file. Is it possible to read the sequence diagram xmi file using EMF ?!
Re: Read sequence diagram by its Xmi [message #1746615 is a reply to message #1746584] |
Tue, 01 November 2016 15:43   |
You will have to be more specific about what you are trying to do.
By "read the sequence diagram XMI file" do you mean to read it not using the Eclipse UML2 and Eclipse GMF Notation model APIs? I would strongly recommend using these APIs; anything else will result in tearing your hair out.
Are you trying to read the semantics of the UML Interaction that is pictured in a sequence diagram, or are you trying to analyze the diagram, itself (the visualization of the interaction as a sequence diagram)? In the latter case, you should know that RSA sequence diagrams are "canonical" and often omit much if not most of the actual layout information, including even which lifelines, messages, and various interaction fragments are shown in the diagram. It can be extremely difficult to reconstruct the visual content of the diagram outside of the RSA environment, and I cannot begin to help with that.
Also worth noting is that RSA uses a very old version of the Eclipse UML2 API, one that implements OMG UML 2.2. UML is up to version 2.5 by now and has changed considerably. The current Eclipse UML2 API can read and convert the contents of an RSA model, but the results may sometimes have a few surprises. See the migration guides from release to release on the UML2 pages in the Eclipse Wiki.
Christian
Re: Read sequence diagram by its Xmi [message #1746616 is a reply to message #1746615] |
Tue, 01 November 2016 16:01  |
Hi Christian,
Thank you so much.
to be more specific, i am trying to build a tool. The input will be sequence diagram generated by RSA and read
the .xmi content to get its nodes (lifeline, messages,..) and the user can select which lifeline or messages
want to delete from the diagram, and the output to generate another sequence diagram based on the actions which
the user did (some nodes will be deleted).
I used before eclipse UML2 and GMF with class diagrams generated by papyrus, but for sequence diagrams i still
have problems of how to get the nodes (lifeline, messages).
can you please recommend me a tutorial about how to do that, my .xmi file look like this:
<uml:Package xmi:id="_TGHOYJuGEeapgJGdwfQEkw">
<packagedElement xmi:type="uml:Collaboration" xmi:id="_TGTboJuGEeapgJGdwfQEkw">
<ownedBehavior xmi:type="uml:Interaction" xmi:id="_TGTboZuGEeapgJGdwfQEkw">
<ownedConnector xmi:id="_bTJhQJuGEeapgJGdwfQEkw">
<end xmi:id="_bTJhQZuGEeapgJGdwfQEkw" role="_Xx4Z8JuGEeapgJGdwfQEkw"/>
<end xmi:id="_bTKIUJuGEeapgJGdwfQEkw" role="_UyvvUJuGEeapgJGdwfQEkw"/>
</ownedConnector>
<lifeline xmi:id="_UxZrgJuGEeapgJGdwfQEkw" name="Property" represents="_UyvvUJuGEeapgJGdwfQEkw" coveredBy="_bTF24JuGEeapgJGdwfQEkw _bTI6MpuGEeapgJGdwfQEkw"/>
<lifeline xmi:id="_Xx3y4JuGEeapgJGdwfQEkw" name="Property2" represents="_Xx4Z8JuGEeapgJGdwfQEkw" coveredBy="_bTGd8JuGEeapgJGdwfQEkw _bTITIJuGEeapgJGdwfQEkw _bTI6MJuGEeapgJGdwfQEkw"/>
<fragment xmi:type="uml:MessageOccurrenceSpecification" xmi:id="_bTF24JuGEeapgJGdwfQEkw" covered="_UxZrgJuGEeapgJGdwfQEkw" message="_bS5CkJuGEeapgJGdwfQEkw"/>
<fragment xmi:type="uml:MessageOccurrenceSpecification" xmi:id="_bTGd8JuGEeapgJGdwfQEkw" covered="_Xx3y4JuGEeapgJGdwfQEkw" message="_bS5CkJuGEeapgJGdwfQEkw"/>
<fragment xmi:type="uml:BehaviorExecutionSpecification" xmi:id="_bTITIJuGEeapgJGdwfQEkw" covered="_Xx3y4JuGEeapgJGdwfQEkw" start="_bTGd8JuGEeapgJGdwfQEkw" finish="_bTI6MJuGEeapgJGdwfQEkw"/>
<fragment xmi:type="uml:MessageOccurrenceSpecification" xmi:id="_bTI6MJuGEeapgJGdwfQEkw" covered="_Xx3y4JuGEeapgJGdwfQEkw" message="_bTI6MZuGEeapgJGdwfQEkw"/>
<fragment xmi:type="uml:MessageOccurrenceSpecification" xmi:id="_bTI6MpuGEeapgJGdwfQEkw" covered="_UxZrgJuGEeapgJGdwfQEkw" message="_bTI6MZuGEeapgJGdwfQEkw"/>
<message xmi:id="_bS5CkJuGEeapgJGdwfQEkw" name="message1" receiveEvent="_bTGd8JuGEeapgJGdwfQEkw" sendEvent="_bTF24JuGEeapgJGdwfQEkw" connector="_bTJhQJuGEeapgJGdwfQEkw"/>
<message xmi:id="_bTI6MZuGEeapgJGdwfQEkw" name="message1" messageSort="reply" receiveEvent="_bTI6MpuGEeapgJGdwfQEkw" sendEvent="_bTI6MJuGEeapgJGdwfQEkw" connector="_bTJhQJuGEeapgJGdwfQEkw"/>
</ownedBehavior>
<ownedAttribute xmi:id="_UyvvUJuGEeapgJGdwfQEkw" name="lifeline1"/>
<ownedAttribute xmi:id="_Xx4Z8JuGEeapgJGdwfQEkw" name="lifeline2"/>
</packagedElement>
<profileApplication xmi:id="_TUK4gJuGEeapgJGdwfQEkw">
<eAnnotations xmi:id="_TVIh0JuGEeapgJGdwfQEkw" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbnfB2L_5w"/>
</eAnnotations>
<appliedProfile href="pathmap://UML_PROFILES/Standard.profile.uml#_0"/>
</profileApplication>
<profileApplication xmi:id="_TVS54JuGEeapgJGdwfQEkw">
<eAnnotations xmi:id="_TVTg8JuGEeapgJGdwfQEkw" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="pathmap://UML2_MSL_PROFILES/Default.epx#_fNwoAAqoEd6-N_NOT9vsCA?Default/Default?"/>
</eAnnotations>
<appliedProfile href="pathmap://UML2_MSL_PROFILES/Default.epx#_a_S3wNWLEdiy4IqP8whjFA?Default?"/>
<profileApplication xmi:id="_TVTg8ZuGEeapgJGdwfQEkw">
<eAnnotations xmi:id="_TVUIAJuGEeapgJGdwfQEkw" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="pathmap://UML2_MSL_PROFILES/Deployment.epx#_4OVBUD0TEeKt-L0gyEptgQ?Deployment/Deployment?"/>
</eAnnotations>
<appliedProfile href="pathmap://UML2_MSL_PROFILES/Deployment.epx#_vjbuwOvHEdiDX5bji0iVSA?Deployment?"/>
</uml:Package>
FUDForum. Page generated in 0.05769 seconds
