Home » Eclipse Projects » Eclipse Scout » [NEON] Error deploying a helloworld app(simple deploy, dificult error right now)
[NEON] Error deploying a helloworld app [message #1746125] Sat, 22 October 2016 12:38 Go to next message
Hi expert, now I'm focused on scout and all my time is in order to learn too much about it.
So, I'm trying to deploy an helloworld simple aplication but I'm facing problem.
This is the error triggered.
I'm checking the pom file inside the helloworld.ui.html and I can't see any problem.
Can you put me in a right way to solve this issue?
thank you so much.
this happend when I run the maven project using deploy parameter.
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.8.2:deploy (default-deploy) on project helloworld.ui.html.app.war: Failed to deploy artifacts: Could not find artifact xgc.commons.apps.example:helloworld:pom:1.0.0-20161022.162229-1 in repo.eclipse.org (https://repo.eclipse.org/content/repositories/scout-snapshots/) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.8.2:deploy (default-deploy) on project helloworld.ui.html.app.war: Failed to deploy artifacts: Could not find artifact xgc.commons.apps.example:helloworld:pom:1.0.0-20161022.162229-1 in repo.eclipse.org (https://repo.eclipse.org/content/repositories/scout-snapshots/)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
[Updated on: Sat, 22 October 2016 13:30] by Moderator
Re: [NEON] Error deploying a helloworld app [message #1746136 is a reply to message #1746125] Sun, 23 October 2016 03:29 Go to previous message
ok, I'm going to assume that it was a command issue.
If I use INSTALL command, OR CLEAN VERIFY the result is right.
I'm able to reproduce the error just if I use DEPLOY command.
Previous Topic:deploy app with tomcat, server error
Next Topic:server's session and UI's session
Current Time: Sat Jul 26 00:35:37 EDT 2025
Powered by FUDForum. Page generated in 0.03072 seconds
